Can my SPC UCA's adjust past 3.7⁰ caster, between 4-5⁰ perhaps?
Discussion in '5th Gen 4Runners (2010-2024)' started by djwantke, Jul 2, 2023.
  1. Jul 2, 2023 at 1:00 PM
    djwantke [OP] New Member
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Currently sitting at 3.4⁰-3.7⁰, 0.2⁰ camber.
    3/2 lift, 5100's w/ upgraded springs
    285/70R17 load E
    17" 0 offset/5 backspace
    *edit: (9" width rims)
    1.25" Spidertrax, BMC
    [grinding/rubbing noise when turning hard and flexing up an incline. I'm trying to figure out if I'm still rubbing BMC'd body mounts, I've masked them off for evidence. Or, could it be my SPC ball joints that were assessed 6 months to live this spring by 4WheelParts. Maybe there's metal on metal now in the socket? Masking tape seems untouched so far, before taping I thought I saw a clean mark on the inner most edge of body mount representing possible rub. But iunno yet
  2. Jul 3, 2023 at 10:53 AM
    Old Tanker
    Old Tanker New Member
    Keith
    "Matilda" 2019 ORP
    Front: Hefty. Rear: LFD. Sliders: RSG. Armor: LFD and Bud Built. Tires: KM3. Switchpro.
    More caster on the UCAs will just bring the rear closer to the firewall.
  3. Jul 3, 2023 at 12:40 PM
    Thanks dude
    I think I follow
  4. Jul 3, 2023 at 1:18 PM
    nova
    nova New Member
    mike
    Prescott Valley - Arizona
    slightly modified LE
  5. Jul 3, 2023 at 2:01 PM
    I'll take a look now during baby nap time haha
    Thank-you!
  6. Jul 3, 2023 at 2:08 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Unless its all over the highway and doesn't track straight there's no reason to adjust the caster. If it rubs the body mount, just chop it.
  7. Jul 3, 2023 at 2:08 PM
    and just fyi for ya'll, the front bumper is max high clearance cut, fender liner chopped straight across from bottom of leading fender edge.
    my body mounts are chopped nicely.
    also fender mount pinch welds have been chopped welded & painted. rear of front fender liners cut in trajectory, and wheel wells hammered in that area.
  8. Jul 3, 2023 at 7:40 PM
    Old Tanker
    Keith
    "Matilda" 2019 ORP
    The SPCs adjust caster from the top (obviously), so increasing your caster angle from the UCA means shifting the top of the wheel rearwards. This will increase rubbing against the body mount. Normally not a big issue running 285 tires, but you have wide (9 inch?) wheels and 1.25" spacers, which probably makes for a badass look but it compounds your rubbing issues.
    Your 3 inch lift reduced your caster, the unequal 3/2 added some caster back in, and the SPC added some caster by pulling the top back. Maybe a skilled 4x4 alignment shop could add caster from the LCAs (shift the bottom forward - if there is any adjustment left) and let you reduce it a bit from the UCAs (move them forward as well), creating a little more space between wheel and body mount.
    djwantke[OP] likes this.
  9. Jul 3, 2023 at 7:44 PM
    Ahh see there ya go, thank you very much. Perhaps I should be saying I need more LCA caster not UCA.
    My LCA's are stock Toyota, same joints, same bushings, owned since new.
  10. Jul 10, 2023 at 12:31 PM
    And I've posted on here for help couple times now - there's a grinding/rubbing noise sometimes when I turn hard left or right going quick up an incline. Not getting any rubbing evidence elsewhere. Could this be the ball in socket metal on metal?
