Can I replace these hose with coolant hose?
Discussion in '2nd Gen 4Runners (1990-1995)' started by marucus, Feb 8, 2021.
  1. Feb 8, 2021 at 6:28 PM
    marucus
    marucus [OP] New Member
    This vacuum hose has cracks on the connections and I am not sure to use coolant hose to replace it or need to buy it at dealer. What is the name of this hose
    Thanks
  2. Feb 8, 2021 at 6:41 PM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    If you're not sure. Remove them and any automotive store will match them up for you.
  3. Feb 8, 2021 at 6:43 PM
    marucus
    I did at Autozone and oreiley. They do not have it
  4. Feb 8, 2021 at 6:44 PM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    Unreal. Try NAPA.
  5. Feb 8, 2021 at 7:49 PM
    Dezman92
    Dezman92 New Member
    Doug
    Norcal
    1994 Green 4runner
    It depends. You can just use bulk coolant hose. You should use PCV/Fuel rated bulk hose. The smaller hose is for the a/c idle up valve and the larger one is for the PAIR injection. If you’re in California a smog inspector will fail it visually if it has coolant hoses, I know, because I’m a smog inspector in California. If you don’t have a smog inspection where you’re at, just run the cheapest bulk hose on it.
  6. Feb 8, 2021 at 9:05 PM
    marucus
    Thanks dezman92
    I will get some tomorrow
