Can I disable ABS for sand dunes?
Discussion in '5th Gen 4Runners (2010-2024)' started by calebw10, Jul 9, 2023.
  1. Jul 9, 2023 at 10:28 AM
    calebw10
    calebw10 [OP] New Member
    Caleb
    2014 4Runner SR5
    2014 SR5, I'm up at the Silver Lake sand dunes for the week. I need to disable the overly aggressive ABS system. If I don't make it up a dune, ABS immediately kicks in and prevents me from stopping as I start to roll backward. This has already created a couple of dangerous situations where I have been unable to control my vehicle's speed while moving down a hill in reverse.
    There are two fuses for the ABS system, and they are combined with a fuse for the secondary air injection pump (see pics). I was wondering if it would be possible to replace this combined fuse with 3 individual ones, allowing me to pull ABS but keep the air injection fuse. Or, what would happen if I disconnect one of the ABS sensors? I also need to make sure traction control and vehicle stability control (VSC) stays off as well. Pulling the ABS fuses seemed to disable the traction control off button on the ceiling. Would pulling ABS fuses inherently disable all traction control systems as well?
    I did see a kit from Dr. KDSS that would disable ABS, however this is sold out and I am looking for a solution that I can implement while I am up here this week.
  2. Jul 10, 2023 at 1:32 AM
    Brownspotz
    Brownspotz High Class Hyena
    2022 sr5 4runner
    Upper control arms , ECGS bushing
    As long as you create a fault in the system, it'll be disabled. ie: Unplug a wheel speed sensor.
  3. Jul 10, 2023 at 4:21 AM
    Dhein
    Dhein New Member
    I believe it is automatically disabled in low side 4x4. It is on my 3rd gen.
    MI-FL off roader likes this.
  4. Jul 10, 2023 at 5:27 PM
    MI-FL off roader
    Brett
    Merritt Island, FL
    03' SR5 Sport - 12' Limited
    You can push your Trac off button once, the dash will illuminate "Trac off", then push and hold that same button for 3-5 seconds, then you will see the dash illuminate with the "Trac off" and the car w the squiggly lines icon will say "off". It will stay in this mode until you shut the ignition off. Then repeat the process when needed.
    nova and Captain Spalding like this.
  5. Jul 10, 2023 at 6:26 PM
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    pushing the trac off turns off traction control.
    holding trac off for 3-5 seconds (not necessary to push it beforehand) turns off traction control, vsc and trailer sway control.
    I don’t know if it also turns off ABS? Have you tested it? It’s nice if it does!
  6. Jul 10, 2023 at 6:34 PM
    MI-FL off roader
    Brett
    Merritt Island, FL
    I can't confirm that, but it sure has been helpful in thick sand at moderate speeds, when normally the traction nanny is kicking in. The PO of my 4th gen installed a kill switch for the ABS. I leave it off all the time now. I know there is write up on it, I wonder if there is one for the 5th gen.
    semprenissart[QUOTED] likes this.
  7. Jul 10, 2023 at 8:33 PM
    semprenissart
    semprenissart Mèfi
    Yes, completely turning off traction control and anything else that kills power when it senses wheel slip is critical in deep snow, mud, sand ,etc…
    Having a button to shut off the ABS (mod or already installed from Toyota) is great in certain situations. Short of removing the fuse I don’t know if it’s possible without adding a kill switch mod
    POWERPLANTHOMER likes this.
  8. Jul 10, 2023 at 9:50 PM
    JETSPD1477
    JETSPD1477 New
    Typical 4Runner
    i’ve been out with some who unplugging at the abs unit.
    semprenissart likes this.
  9. Jul 10, 2023 at 11:58 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    It doesn't even turn off traction control. It just gives you less traction control. This is my biggest disappointment in the 4runner.
    So I doubt it turns off ABS.
  10. Jul 11, 2023 at 3:29 AM
    Gamma Ray
    2020 SR5 Barcelona Red
    I'd say hold the traction control button to do that level of disabling, get up to speed, make sure nobody else is around, and slam on the brakes. If it feels like ABS is off then you're good. ABS, traction control, etc. They're all controlled by the same system.
  11. Jul 11, 2023 at 3:39 AM
    MI-FL off roader
    Brett
    Merritt Island, FL
    I don't think it
    Yea, pretty sure the braking aspect of ABS is unaffected. But it allows the wheels to spin with out traction control kicking in.
    Being a Florida man (another term for redneck), doing fishtails and donuts is a right of passage. With traction control engaged, it's impossible to do either. With the Trac off, I can toss the back end of this thing all over the place. Turning the Trac off might help OP get through the week in the dunes. Maybe my 2012 is set up a little different than the newer models?
  12. Jul 11, 2023 at 3:55 AM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    You can disable abs, trac , and tss by disconnecting one of the 4 wheel speed sensors.
  13. Aug 8, 2023 at 12:34 AM
    POWERPLANTHOMER
    POWERPLANTHOMER New Member
    JAMES
    2020 TRD OR PREMIUM, 2021 TRD OR PREMIUM KDSS
    Just FYI, my ORP I use cactus, mud mode in 4Hi in the snow, it’s the only mode you can use in 4hi. You can take off from a stop pretty quick in the deep snow, and it doesn’t cut the throttle.
