Can’t remove rear diff drain plug
Discussion in '5th Gen 4Runners (2010-2024)' started by johnnyg182, Feb 5, 2025.
  1. Feb 5, 2025 at 6:23 PM
    johnnyg182
    johnnyg182 [OP] New Member
    2019 TRD Pro
    2” lift - SPC UCA - 285s - RCI skids - C4 Gas Skid - C4 Sliders
    I’ve done a decent amount of rock crawling in the 4Runner and thought a rear diff skid was a waste of money since the rear is all steel. But a few months ago, I went to change the fluid and noticed I couldn’t get a socket on the drain plug since the “surround” had been pushed against the plug. And now the plug started leaking after my most recent Offroad trip.
    Is it my best option to fix this by welding a nut onto the plug to remove it? Then grind the “surround” until there’s clearance for a socket? Or should I notch the plug and try to chisel it to loosen it—worried I may not be able to break it loose this way.
    Definitely buying a diff skid after I fix this :)
  2. Feb 5, 2025 at 6:35 PM
    ^It's leaking because the rocks caught a corner of the plug and slowly loosened it after repeated hits. Try chiseling first, if insufficient, grind the plug until you can fit a 24mm socket on it.
    The rock crawling circles have come up with an allen socket magnetic drain plug Trail-Gear P/N 140032-1-KIT for this purpose. I'm using one as a hand-me-down part from my Tacoma:
    1SilverRunner and Superdave1.0 like this.
  3. Feb 5, 2025 at 6:38 PM
    kouack
    kouack New Member
    Prov. Of Québec, Canada
    4Runner Limited 2024
    Bone stock
    I would just deburr the area to give you access with socket.
    Treggit, Ironguy, rockdoc4x and 2 others like this.
  4. Feb 5, 2025 at 6:44 PM
    Superdave1.0
    Superdave1.0 New Member
    LX470, 2025 Civic Si
    Weld it closed and drain/fill from the top hole. :devil:
  5. Feb 5, 2025 at 6:49 PM
    johnnyg182
    2019 TRD Pro
    I’m going to order this plug! Thanks!
    I’ll see if I can grind the surround without removing the plug but didn’t think I had any bits small enough to do so.
    Maybe I don’t need to spend $300+ on a diff skid now….
  6. Feb 5, 2025 at 7:07 PM
    Don't Allen head bolts have a tendency to strip out if difficult to remove?
    Slopemaster and alittleoff like this.
  7. Feb 5, 2025 at 7:29 PM
    ^Factory ones can be difficult to remove because they're installed dry and rust in place. If you're installing one yourself after draining the diff oil, the threads will be coated in oil, and subsequent removals won't be difficult. Just hammer in a good 10mm allen bit for removal.
  8. Feb 5, 2025 at 7:29 PM
    TrueTexas
    TrueTexas New Member
    The Woodlands, TX
    Maybe a thin walled socket???
    Or a combination of a little bit of grinding and a thin walled socket?
  9. Feb 5, 2025 at 8:07 PM
    In looking at the link you provided, it looks to be made out of hardened metal, like impact sockets, so it doesn't seem it would strip out.
    alittleoff and Saker like this.
  10. Feb 5, 2025 at 8:38 PM
    I would grind the mangled surround away from the bolt with a dremel until you can fit a socket on it.
    Treggit, alittleoff, icebear and 5 others like this.
  11. Feb 5, 2025 at 10:16 PM
    I used a cold chisel to cut away the metal that got dragged inside the ring. Couple of minutes work and I could slip a socket onto it.
    Powerstroke likes this.
  12. Feb 6, 2025 at 3:51 AM
    It has a black oxide coating. No idea if the steel used is harder than OEM. The magnet is stronger than OEM though.
  13. Feb 6, 2025 at 4:46 AM
    Irving Zisman
    Irving Zisman New Member
    Vegas
    2008 V8 4Runner
    This. Use a Dremmel tool and grind enough away so you can get a socket on it.
    alittleoff and catbrown357 like this.
  14. Feb 6, 2025 at 7:18 PM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    Have you tried a dremmel. Lots of cutting and grinding attachments that are small and can remove the steel pushed up to the plug and blocking your socket.
  15. Mar 23, 2025 at 7:23 PM
    johnnyg182
    2019 TRD Pro
    Finally got around to removing the drain plug by tapping it with a hammer and chisel. Then grinded the surround back a bit. Wish I didn’t since I ended up nicking the mating surface a bit. Installed the 10mm hex head drain plug recommended in this thread. No more leaking!IMG_0202.jpg
    McSpazatron, 3JOH22A, java and 2 others like this.
