Camping and audio/video question
Discussion in 'General 4Runner Talk' started by nondescriptive123, Mar 26, 2023.
  1. Mar 26, 2023 at 9:26 PM
    nondescriptive123
    nondescriptive123 [OP] New Member
    DFW, TEXAS
    2021 White 4Runner TRD pro
    '21 TRD Pro 4Runner MAGNUSON SuperCharger | NashFabCo Rear Ladder | OEM Center Console Safe | OEM Brake Caliper Covers | CanvasBack CargoLiner | Morimoto XB Tail Lights | Cali Raised Rock Sliders | Cali Raised Roof Rack Diode Dynamics SS3 Fog Light | Apex Overland Recovery Points| Agency 6 Recovery Shackle Block | Red 3/4" D-Ring Recovery Shackle | Morimoto XB White Head Lights | Teton Workshop Shiftknob and Transfer Case
    I was looking to do a movie night on a camping trip. If I have a projector and screen, is there anyway to hook it up to the car audio system for sound? The normal sound from the projector and most output is not very good on a camping trip.
    If not, is there any alternative?
  2. Mar 27, 2023 at 1:02 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Hey so 2016 had an AUX 3.5mm audio input on the dash, but newer such as 2021 do not. I do audio visual for a living. Most projectors have AUX audio out, that prolly would have been the easiest solution. Without AUX I think you may need a projector with Bluetooth capabilities, or an AUX/RCA audio to Bluetooth adapter. Because otherwise it's hard to get audio to play Bluetooth on your truck if your phone or laptop is wired into the projector for the video. It wants to play through one or the other; the internal projector speakers or your truck speakers
    Captain Spalding likes this.
  3. Mar 27, 2023 at 1:07 AM
    nondescriptive123
    DFW, TEXAS
    What about something like this?
  4. Mar 27, 2023 at 1:24 AM
    Sure usb to 3.5mm is worth trying. You're right 2021 there is the usb input still where AUX used to be as well. Sometimes usb just likes flash drives, but that's just fine. It's possible it works out of devices too
  5. Mar 31, 2023 at 9:44 AM
    danco
    danco New Member
    Dan
    2004 4Runner SR5
    Ham Radio Install
    Not much help here, but in my 2004 4Runner, I have to use a cassette tape adapter to pipe in any external music to my stereo... :D
  6. Mar 31, 2023 at 7:07 PM
    KYFHO
    KYFHO Generic Scumbag
    UT
    2017 SR5P with some stuff
    27” tv, Raspberry Pi, and a 1TB hard drive plugged in to the inverter works pretty well
    Ricphoto, scottiezilla and djwantke like this.
  7. Mar 31, 2023 at 7:10 PM
    nondescriptive123
    DFW, TEXAS
    What is the inverter? Can you walk me through the process
  8. Mar 31, 2023 at 7:13 PM
    KYFHO
    UT
    The power outlet in the cargo bay. 400w was enough to power that setup, although I’d run the engine for a little bit after the movie was over to avoid killing the battery.
  9. Mar 31, 2023 at 7:28 PM
    Excellent setup!! Coming from an audio visual tech
  10. Mar 31, 2023 at 7:37 PM
    KYFHO
    UT
    That was the last time we used that setup, 3 years ago. I’ve since streamlined my gear (and continue to do so). I’ve since come up with other solutions that involve a mount for a tablet in the cargo area and also in the tent. My kids are more about running around like drunk idiots at the campsite than sitting and watching movies. Now movie time is when we turn in for the night
  11. Apr 5, 2023 at 10:21 AM
    HotelMedicis
    HotelMedicis No Commercial Interests
    Might that work? I have a Sirius XM radio that I want to tether to the infotainment system and I need an AUX IN jack but none to be found on my 2023 4Runner. I'm wondering if I need to order a bluetooth TX / RX dongle to get it to tether with bluetooth.
