Busted Grill :(
Discussion in '5th Gen 4Runners (2010-2024)' started by Caltech90, Apr 14, 2020.
  1. Apr 14, 2020 at 5:44 AM
    Caltech90
    Caltech90 [OP] New Member
    '19 TRD OR
    I had a softball size something bust my grill on the interstate yesterday. Are the $150ish TRD grills decent or junk??
  2. Apr 14, 2020 at 5:50 AM
    Oldtoyotaguy
    Oldtoyotaguy Paid cash for it
    2018 Toyota 4 Runner Offroad
    For sure, they’ll look better than a softball sized hole! Apparently they have a gap at each end of the cross bar piece that can bother some compulsive obsessives but from 10’ you can’t tell the difference from OEM. It’s just a piece of plastic. I’m not into aesthetic mods, but I’d buy one for a repair.
    Caltech90[QUOTED][OP] likes this.
  3. Apr 14, 2020 at 6:58 AM
    Mtbpsych
    Mtbpsych New Member
    I just bought one from Cartrimhome and it’s good quality. Has a very small gap on the ends as mentioned but you can’t tell whatsoever from a distance.
    I did redo the letters as I screwed them up the first time and were crooked.
    Caltech90[OP] likes this.
  4. Apr 14, 2020 at 7:48 AM
    Agent_Outside
    Built 2011 T4R Limited
    skull likes this.
  5. Apr 14, 2020 at 12:25 PM
    Drababan
    Drababan New Member
    2020 4Runner TRD Pro (Pickle Rick)
    FYI...all heritage grills, including factory, have gaps. The knock-off ones seem to have a decent reputation, the only downside is you have to attach the letters yourself and you might mess it up and install them uneven.
  6. Apr 14, 2020 at 12:27 PM
    Drababan
    Drababan New Member
    I hope this picture was taken before you re-attached the letters. If not, they are still messed up. Your "O" are not properly aligned. They are not perfect circle, they are oval inside and you have them pointing the wrong way.
  7. Apr 14, 2020 at 12:28 PM
    Mtbpsych
    Mtbpsych New Member
    Yes, I have since then redone the letters as I noticed how horribly I screwed it up lol.
    KSJ08 likes this.
  8. Apr 15, 2020 at 8:16 AM
    Caltech90
    '19 TRD OR
    Do the letters have an alignment dowel?
  9. Apr 15, 2020 at 9:05 AM
    Mtbpsych
    Mtbpsych New Member
    Yes they do.
  10. Apr 15, 2020 at 9:12 PM
    Ryp
    Ryp New Member
    Canada
    2016 Nautical Blue Metallic Toyota 4Runner Limited
    Would this grille fit on the Limited?
  11. Apr 16, 2020 at 6:17 AM
    Oldtoyotaguy
    I think you’d need to change out the bumper cover too. That sounds like a big job, but it isn’t really. It’s amazing how easy it is to remove. Also, it’s not a expensive part. The most expensive part of it would probably be to match up the paint. I’m not sure why you would want to do this, though. Limited’s have a look of their own, kind of cool.
    Ryp[QUOTED] likes this.
