Burning through CV boots
Discussion in '4th Gen 4Runners (2003-2009)' started by Bmxer06pa, Sep 14, 2023.
  1. Sep 14, 2023 at 9:46 AM
    Bmxer06pa
    Bmxer06pa [OP] New Member
    I have the icon dynamics stage 3 lift set at 2-2.5 inches. I seem to go through CV boots every few months. I have the RCV orange boots and the All-Pro off-road 4Runner High Angle Outer CV boot kit. I know when the ribs touch, they wear through very quickly, but I can't seem to stretch them out enough for that not to happen. Any suggestions on making these work or different boots I should look into?
  2. Sep 14, 2023 at 10:00 AM
    OEM
    Whats your CV angle look like. 2 - 2.5 should be no problem.
  3. Sep 14, 2023 at 10:29 AM
    Bmxer06pa
    Hopefully this pic helps. I keep getting told it should be fine, but it keeps not lol2FB9C114-6EF9-43BB-8C1E-FE499029A36C.jpg
  4. Sep 14, 2023 at 10:36 AM
    You sure you only got 2.5" of lift?
    I had damn near 3 on mine and was no where near that bad. I forgot my measurements but this was my CV.
    dillusion-albums-2018-trd-or-picture5482_c122313f3e043fa2e0b0051d9d057e64d0b8e131.jpg
  5. Sep 14, 2023 at 10:53 AM
    Bmxer06pa
    I’m pretty sure I have 2 1/2 inches or so. My kit only goes up to 3.5 maxed out and I still have some threads left on the shock body. So worst case I would imagine it’s three.
    is there a way to measure lift without a stock tire size? I’m on 35’s.
    Yours is definitely at a less severe angle than mine! That’s very weird. Did you do a diff drop?
  6. Sep 14, 2023 at 11:41 AM
    No diff drop.
    I measured center of hub to fender before and after the lift. Let me see if I can find those measurements.
  7. Sep 14, 2023 at 11:45 AM
    Bmxer06pa
    Thanks brother!
  8. Sep 14, 2023 at 11:45 AM
    xtremewlr
    xtremewlr New Member
    Todd
    Tucson, AZ
    2003 4Runner V8 Limited 4WD
    Lots with more in the works
    JYou need to take a new pic with all 4 tires on the ground. That appears to be at full droop, even if the tire is on the ground still.
  9. Sep 14, 2023 at 11:48 AM
    Heres what I got out of mine this was same time I took that pic of the CV angle.
    Measurements Before Lift (Center of hub to fender)
    Both Rear's - 22"
    Passenger Front - 19"
    Driver Front - 19 3/4"
    After
    Rear - 24”
    Front - 22”
  10. Sep 14, 2023 at 2:01 PM
    Bmxer06pa
    Yikes, I’m at 25 & 1/4”. If anyone has an icon set up, can you tell me how many inches of threads are exposed above the upper spring mount? Maybe I’m at the full 3.5, but it still seems like a big difference over the 3” pic posted. image.jpg
  11. Sep 14, 2023 at 2:24 PM
    25 1/4" in the front?
    For sure more than 3".
    I don't have the 4R anymore to measure but something is off.
  12. Sep 14, 2023 at 2:28 PM
    xtremewlr
    Todd
    Tucson, AZ
    I guarantee yours had that. It's not a spacer, it's how the shock is bolted into place. The shock itself is universal and requires that adapter plate to bolts into the OEM shock tower.
  13. Sep 14, 2023 at 2:28 PM
    Yeah I looked again its there.
    Heres what mine was set at.
    dillusion-albums-2018-trd-or-picture5482_21039b8980746abd0a4c373b346acf3ff0a4dfd2.jpg
  14. Sep 14, 2023 at 2:47 PM
    Bmxer06pa
    It might just be the angle in the pics, but it looks like I have significantly more coil above my control arm than you do.
    once I finish my rear springs and air bumps, I’ll get my truck back on the ground and see if that changes anything.
  15. Sep 14, 2023 at 3:07 PM
    xtremewlr
    Todd
    Tucson, AZ
    You can't determine CV angles being too high without the truck on the ground.
  16. Sep 14, 2023 at 3:20 PM
    Bmxer06pa
    If I want to keep the same amount of lift and don’t want a diff drop does anyone have any other ideas?
  17. Sep 14, 2023 at 6:54 PM
    Bmxer06pa
    If I had an extra 10 grand, I would have long traveled already lol. I think the truck rides great! Does awesome on and off road.
  18. Sep 14, 2023 at 7:45 PM
    Bmxer06pa
    The front tires are on the ground, and the rear of my frame is supported by jackstands, basically at ride height, so I can’t imagine it changes the CV angle that much. But even if it does, it does not change the fact that my boots keep tearing apart, and I would like to remedy that. I would like to keep the same amount of front lift as I have so I’m hoping for a remedy to that.
  19. Sep 14, 2023 at 7:58 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Hey, a lot of great help already replying here, but your angle does look pretty steep. I'm running 33's with 3" lift and a diff drop mind you, but diff drops have been proven to barely drop your angle. I've never had a boot tear. I suspect it's something to do with your geometry via lift & 35's?
    Goodluck!
  20. Sep 15, 2023 at 7:08 AM
    xtremewlr
    Todd
    Tucson, AZ
    His truck is on jackstands, so of course the angle is too steep. This is why I keep repeating that he needs to have all 4 wheels on the ground and the full weight of the vehicle on them before posting a picture like that.
  21. Sep 15, 2023 at 7:16 AM
    Bmxer06pa
    Everyone seems very concerned that my truck is on jackstands, which makes the CV picture not accurate. I understand that, but it doesn’t change the fact if it was not on jackstands, it keeps ruining boots.
    And like I mentioned , although the back is on jackstands, it’s within an inch of to a ride heigh.
  22. Sep 15, 2023 at 7:50 AM
    xtremewlr
    Todd
    Tucson, AZ
    Just based off this picture, you have WAY too much preload on those springs. Take a good inch out of that, at least. Ride height in the front should not be set with spring preload.
    The back being on jackstands, whether within an inch of ride height or not, changes the front geometry enough that your pic is useless to determine the actual angles. If you're saying that the CV angle showing in that pic is the same as normal ride height, then you have the suspension setup completely wrong or have extra lift stuff in there that we aren't seeing, like spacers or something. Your first pic, I see something that appears to be raw aluminum near the lower ball joint. Are you also running some kind of spacer lift?
  23. Sep 15, 2023 at 7:55 AM
    xtremewlr
    Todd
    Tucson, AZ
    What is this?
  24. Sep 15, 2023 at 8:01 AM
    xtremewlr
    Todd
    Tucson, AZ
    This is my 4runner, running ADS suspension which is 2.5 to 3" of lift over stock. Virtually no preload on the springs either.
  25. Sep 15, 2023 at 8:03 AM
    Bmxer06pa
    Good eye! That is actually a billet ABS sensor cover. I’m not sure if ripping out the sensors are actually a problem, but I thought they looked pretty cool, and couldn’t help myself lol.
    If I lessen the spring preload how can I recover the height I lose. Is there a way I can keep my lift height but lessen the CV angle?
  26. Sep 15, 2023 at 8:05 AM
    Bmxer06pa
    I see your inner boot ribs are actually touching a little. Do yours blow out?
    I wouldn’t be surprised if I’m doing something wrong, I just don’t know what it is yet lol
  27. Sep 15, 2023 at 8:10 AM
    xtremewlr
    Todd
    Tucson, AZ
    No, those boots have been on for close to 50k miles since I replaced them. I should have installed the small ends a little further out to prevent that rubbing but it really hasn't been an issue.
    These are the inner boots I'm running - https://www.offroadsolutions.com/products/high-angle-inner-cv-boot/
  28. Sep 15, 2023 at 8:20 AM
    xtremewlr
    Todd
    Tucson, AZ
    Again, never use spring preload to make up ride height. You can use a little extra preload to level out the truck side to side, meaning one side might have slightly more preload than the other. Front to rear ride height should be done with small spacers or shims that go between the upper shock mount and the shock tower.
    If you are trying to maintain the clearance for the 35" tires, then you need to either do some cutting of body parts to make that clearance or install a 1" body lift. Or a combination of the 2. I've done a combination of the 2 and have also adjusted the front caster so the front tires are as far forward as I can get them with my current setup. I also have a body mount chop and have new front body mounts to weld in that will give me more clearance between body mount and tires up there.
    Keep in mind that burning through CV boots is bad, yes. But you will also end up burning through CV axles faster because of those angles. The CV joints are also wearing out at a faster rate due to the angles.
  29. Sep 15, 2023 at 8:23 AM
    Bmxer06pa
    I’ve done everything you mentioned aside from the upper strut, spacers, and the body lift. How difficult was the body lift? And is there one you would recommend?
  30. Sep 15, 2023 at 8:30 AM
    xtremewlr
    Todd
    Tucson, AZ
    I went with the Toytec lift - Not hard to do as long as you have a floor jack and a couple pieces of 2x4 handy. I did it in my garage without any help.
