Braking Issue
Discussion in '5th Gen 4Runners (2010-2024)' started by salskins, Dec 7, 2023.
  1. Dec 7, 2023 at 8:11 PM
    salskins
    salskins [OP] New Member
    2019 TRD Off Road
    Hey everyone, I’m new to the forum so hello from Staten Island. I really could use some help with a braking issue I’m having. I have a 2019 TRD Off Road. Changed my FRONT pads and rotors for the first time at around 48k miles. I didn’t go OEM… At about 60 mph and above when braking on highway my steering wheel shakes pretty violently and truck has poor braking ability at this speed. Any info on this issue would be greatly appreciated. Thank you
  2. Dec 7, 2023 at 8:13 PM
    HuskyMike
    HuskyMike New Member
    Was it doing this before you changed the front pads and rotors?
  3. Dec 7, 2023 at 8:19 PM
    salskins
    2019 TRD Off Road
    No sir. Only after I replaced the front pads and rotors. I did my rear pads and rotors a year prior and no issues with that. I find it strange my rears went first but who knows.
  4. Dec 7, 2023 at 8:24 PM
    Tama1968
    Tama1968 New Member
    Florida
    T4R SR5 in Classic Silver
    couple possibilities...pads not seated, warped rotors, sticking calipers,loose lugs, maybe dropped a wheel balancing weight..
    and just curious, were your brakes worn out at 48K? or just changed as a precaution
    salskins[OP] likes this.
  5. Dec 7, 2023 at 8:25 PM
    HuskyMike
    Probably best to pull the wheels off and check to make sure everything looks ok. e.g. no loose bolts, pads in correctly, no residue on the rotors etc.
    If all that looks good, it sounds like you got a bad rotor.
    Re: rears wearing first. A mechanic told me the rears went first on my 3rd gen because of how they have the brake bias set. The rears engage first to help avoid nose dive. Not sure if that's true or not.
  6. Dec 7, 2023 at 8:36 PM
    salskins
    2019 TRD Off Road
    @Tama1968 thanks for the feedback. I actually still had a little meat left on the pads so just changed as a precaution. I also returned the first set of new rotors to see if another new set would solve the problem. It did not.
  7. Dec 7, 2023 at 8:38 PM
    salskins
    2019 TRD Off Road
    @HuskyMike, thanks. I’d like to say I checked everything several times but I’m still stumped as I’ve never come across this problem before.
  8. Dec 7, 2023 at 9:00 PM
    salskins
    2019 TRD Off Road
    I also spun (by hand) each side before I put the tires back on to see if anything was rubbing or seemed warped. Each side had the same exact feeling of somewhat easier to spin then slightly harder to spin then back to easier as I turned by hand.
  9. Dec 8, 2023 at 6:33 AM
    Nmscuba
    Nmscuba New Member
    Anthony
    2020 4 runner
    None
    Did you clean your hubs before putting the rotor on ? Also did you use any anti seize? If so remove it
    McSpazatron and Startrek like this.
  10. Dec 8, 2023 at 6:46 AM
    salskins
    2019 TRD Off Road
    Yes. I took a wire brush to both hubs before I put rotors back on. A decent amount of sediment came off. No I didn’t use any anti seize. Very puzzling to me.
  11. Dec 8, 2023 at 7:35 AM
    Daddykool
    Rear brakes do go first these days due to bias changes, as mentioned earlier. They contact the rotors just barely before the fronts do. I also have a 2019. Replaced rears first time at about 92k miles, fronts around 115k. I left the rotors alone in both cases, as they don't wear out very fast. I get my parts from a dealership, not aftermarket. Regarding the rotors, warp is extremely rare unless you get the rotors red hot. From all I've read, it's more likely pad material deposited unevenly on the rotor(s) that makes them feel warped. You could re-install the original rotors as a test, if they're still in good shape. I've read that bedding-in new brakes is a good idea to prevent this build-up, but haven't done that myself.
  12. Dec 8, 2023 at 8:16 AM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    How many miles on the new front brakes before they started vibrating while stopping?
  13. Dec 8, 2023 at 8:51 AM
    Stupid question: did you clean the shipping/storage grease off of new rotors?
  14. Dec 8, 2023 at 9:41 AM
    One mistake I made when dealing with brakes on my Tacoma was never bedding them in and thinking the rotors were warping.
    salskins[OP] and Daddykool like this.
  15. Dec 8, 2023 at 12:35 PM
    salskins
    2019 TRD Off Road
    @Daddykool, thanks for all the info. Unfortunately I threw out the original rotors. Regretting that now. I was thinking about getting OEM pads just to see if that would do anything. As far as bedding thats something I haven’t done and will have to look into as well.
  16. Dec 8, 2023 at 12:58 PM
    salskins
    2019 TRD Off Road
    @Rocko9999, this happened immediately after replacing pads and rotors.
  17. Dec 8, 2023 at 1:01 PM
    salskins
    2019 TRD Off Road
    @SR5 Limited, yes cleaned rotors with brake parts cleaner.
  18. Dec 8, 2023 at 1:20 PM
    Rocko9999
    2011 Limited
    Hmm. Doesn't seem like a 'warping' or uneven pad material deposit issue if it happened immediatley. Even with poor quality pads/rotor it usually takes some time or a really hot/hard braking event to cause this. I would suspect install issue.
    salskins[QUOTED][OP] likes this.
  19. Dec 8, 2023 at 1:25 PM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    Is there high humidity or rain? I had my dealer do a brake pad change with OEM and i happened to go down south where it rained and was hmid after sitting and i got the same thing. Went away after a long trip and fine ever since.
    Helpfully you broke them in properly?
  20. Dec 8, 2023 at 1:37 PM
    surfingbuddhist
    surfingbuddhist New Member
    Glen
    2020 4Runner
    It sounds like you have unequal deposit of pad material on the rotors. Bedding is very important and much harder get right when you're mating two brand new surfaces. Try taking a scotch brite pad to the rotors to remove any of the deposited pad material. Bedding in should be done in an area where you're not going to get a ticket or come into contact with other drivers. Basically you're trying to transfer an equal amount of pad material to the rotors without stopping - from 50mph brake to 10mph with firm pressure w/o engaging ABS, don't come to a stop, speed back up to 50mph and repeat 8-10 times. I work for Brembo Italy.
    salskins[OP], Daddykool and Ripper238 like this.
  21. Dec 8, 2023 at 2:28 PM
    Nmscuba
    Nmscuba New Member
    Anthony
    2020 4 runner
    None
  22. Dec 8, 2023 at 2:29 PM
    Nmscuba
    Nmscuba New Member
    Anthony
    2020 4 runner
    None
    Time to get a dial indicator out take the tire off put it on the rotor and spin it see what your run out is
  23. Dec 8, 2023 at 2:32 PM
    I didn't see you post it but what brand?
    I saw you didn't go with OEM. Could just be crap.
  24. Dec 8, 2023 at 2:33 PM
    Daddykool
    OEM pads on those rotors may not fix anything. If you buy anything, I’d buy rotors or get yours turned to remove any high spots.
  25. Dec 8, 2023 at 2:46 PM
    Redwood
    Redwood New Member
    2022 4Runner TRD Off Road
    Yes this. Sounds like a warped rotor issue especially since it wasn't there before. I have a 3M hub cleaning attachment for my drills that fits over the wheel studs and does a beautiful job of cleaning the hubs so that they are flat. Also aftermarket brake rotor and brake pad quality is all over the board. Generally you get what you pay for. Stick with premium aftermarket rotors and pads preferably made in North America. Have pulled many "Made in China" brake rotors that were warped right out of the box. As well as cheap Chinese brake pads that were downright dangerous and I mean smoking and not stopping at all when hot. I can usually tell just by the machined finish on the new brake rotor. A quality rotor will usually have a swirled fine micro finish on them. As for brake pads unless OEM I always use ceramic pads. Just relating my experiences after hundreds of brake jobs.
  26. Dec 8, 2023 at 3:26 PM
    Rocko9999
    2011 Limited
    I feel like even decent aftermarket rotor brands that had a good reputation are now all poor quality. I have seen many warped/out of round rotors/drums on new aftermarket stuff. Sad state.
    salskins[OP] and Redwood[QUOTED] like this.
  27. Dec 8, 2023 at 5:10 PM
    salskins
    2019 TRD Off Road
    I’m ashamed to say I bought Duralast from Auto Zone. They weren’t cheap though.
  28. Dec 8, 2023 at 5:30 PM
    salskins
    2019 TRD Off Road
    Yes. I agree. That hub cleaning attachment sounds like a good tool to have. Appreciate all the feedback.
  29. Dec 8, 2023 at 5:39 PM
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    2023 Supercharged 4Runner TRD
    How much did you save by not buying OEM?
  30. Dec 8, 2023 at 6:14 PM
    Last time I bought brakes at autozone, I got their best duralast one, black oxide finish. They did fine. But were not much cheaper than OEM rotors.
