***Brakes question***
Discussion in 'Wheels & Tires' started by cheapobro, Jan 27, 2024.
  1. Jan 27, 2024 at 1:27 AM
    cheapobro
    cheapobro [OP] New Member
    Zach
    2006 v6 4Runner 4wd
    I recently bought a used 06 with 170,000 miles and have 2 questions I hope someone can give me some input
    1. One rear brake pad was worn down to the metal on the inner side and the rotor is worn as well only on one side of the rotor. I’m going to replace both rear rotors and pads. Should I replace the calipers too since the rotor was unevenly worn?
    2. Thoughts on transmission drain and fill at 170k if service history is unknown?
    bonus question: TRQ Chinese brakes, does anyone have experience with using them?
  2. Jan 27, 2024 at 3:55 AM
    Guppy1301
    Guppy1301 New Member
    Silver 2019 TRD ORP
    I would get everything needed to replace the rear brakes. Minus the caliper if you think it's still good. By your avatar it looks like you're in snowy area. Maybe replace calipers??? Try looking at Brakeperformance.com. They have everything you would need at pretty good prices and free shipping. Good luck!
  3. Jan 27, 2024 at 6:49 AM
    Daddykool
    Welcome! I would try to free up the stuck caliper. If it takes too much effort or seems to be too far gone, replace with OEM. If you want to stay out of those brakes for a long time, consider replacing both calipers, rotors and pads with OEM. Genuine OEM parts can be a little more expensive, but I've never had early failure of an OEM part, nor fitment problems.
  4. Mar 4, 2024 at 4:12 PM
    PHML
    PHML New Member
    Pete
    2018 4runner SR5 Premium 4x4
    All kinds
    If you have access to an air compressor, consider rebuilding the calipers yourself. Buy a rebuild kit from the dealer (inexpensive) Lots of youtube video on how to do this...fairly simple.
