Brake question
Discussion in '5th Gen 4Runners (2010-2024)' started by Matty11781, Feb 19, 2024.
  1. Feb 19, 2024 at 5:24 PM
    Matty11781
    Matty11781 [OP] New Member
    Matt
    2019 4 runner
    Dirty life wheels
    So my wife's 2019 4 runners brake pedal goes almost to the floor and the steering wheel shakes pretty badly when pushing the pedal hard. She has no idea how long it's been doing this. I ordered new rotors and pads I haven't looked into it yet, we are on vacation and drove her vehicle 800 miles to south Carolina. I know this problem is typically tracked back to the master cylinder but are there any other problems it could be?
  2. Feb 19, 2024 at 5:58 PM
    RubiRunner
    RubiRunner New Member
    Sounds like warped rotors, which will cause pulsation during braking. Low pads can cause a soft pedal and excessive heat which can also contribute to warping. If it were me I would bite the bullet and get them checked/changed before a 800 mile return trip.
  3. Feb 19, 2024 at 6:21 PM
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    2023 Supercharged 4Runner TRD
    I'd be hesitant to trust it that long. IMO, you should consider getting it into a shop asap.
    MEski4x4 and 2Toys like this.
  4. Feb 19, 2024 at 6:31 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    Probably wouldn't take a trip in a vehicle having brake problems, but here we are...
    First check fluid level. Brake booster, air in lines, leaks, could all be the reasons you are having issues. Inconsistent braking force will cause uneven wear on pads and rotors.
    2Toys likes this.
  5. Feb 19, 2024 at 7:25 PM
    Startrek
    Startrek New Member
    need 4 new calipers! and rotors. has nothing to do with "master cylinder" - whatever it means. but first with dial gauge check run-out of hub
  6. Feb 20, 2024 at 10:38 PM
    Gripster
    Gripster New Member
    2016 Trail Premium
    You have two problems. 1) warped rotors causing shaking when brakes are applied. 2) air in the lines probably from water moisture boiling in brake lines. A brake fluid flush is very easy to perform and you don’t need any fancy tools. If I was on vacation I would probably take it to a shop and have the brake fluid changed. It is so easy I would be surprised if they charge more than $100.
  7. Feb 21, 2024 at 4:04 AM
    4R4L_2023
    4R4L_2023 New Member
    24' XP UndGrnd 23' XP Mag Grey
    Staying Stock
    Pulsing/shaking when pushed hard is definitely warped rotor. Change the rotors and pads yourself first, you'll save tons.
  8. Feb 22, 2024 at 6:32 PM
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    Just keep driving. You’ll be fine. It’ll work itself out. ;)
  9. Feb 23, 2024 at 6:17 PM
    Check torque on the wheels!!! Loose wheel means loose rotor which wobbles/shifts and pushes the pistons on the caliper in, then you get soft pedal. I never thought a loose wheel could do that until a friend on the TW forms said they had that happen to him!
    2Toys likes this.
  10. Feb 23, 2024 at 6:25 PM
    steelevo
    Utah
    Welcome. The shaking is warped rotors. The soft pedal feel is due to the pads being worn, which in turn causes low fluid levels. Change out the pads, rotors, and do a brake flush. Don’t forget to bed the pads and rotors properly.
  11. Mar 4, 2024 at 2:01 PM
    PHML
    PHML New Member
    Pete
    2018 4runner SR5 Premium 4x4
    All kinds
    Is the rig still under warranty? If so, take it in.
    Otherwise, do a brake line flush...then I would check the pistons if any are seized. If seized, buy a rebuild kit from the dealer...its relatively cheap. Its a DIY project. Lastly, I would check and replace the pads and rotors if warped.
  12. Mar 4, 2024 at 3:16 PM
    Matty11781
    Matt
    2019 4 runner
    Dirty life wheels
    Thanks for all the responses, I ordered rotors and pads when I got to south Carolina. They were here when I got home. When I started changing them I noticed the inside pads were seized to the pins so only the outside of the caliper was pushing on both driver and passenger side. So I sent my wife to autozone to get new pins, cut the old ones out, new rotors and pads and problem solved.
    2Toys likes this.
  13. Mar 4, 2024 at 4:23 PM
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    Not to be picky. I’d use only Toyota pins in there my friend.
    2Toys and TrailSpecial22 like this.
  14. Mar 4, 2024 at 4:30 PM
    TrailSpecial22 New Member
    PA
    use a thin coat of high temp anti seize on the pins
    2Toys and raimieb like this.
  15. Mar 4, 2024 at 4:31 PM
    3JOH22A Toyota Gigolo
    Toyota pad retention pins are just as bad as aftermarket - they all need a coat of grease to keep rust from seizing.
