Brake Question - Replacement Rotors & Pads
Discussion in '5th Gen 4Runners (2010-2024)' started by smatson, Jan 15, 2023.
  1. Jan 15, 2023 at 12:52 PM
    smatson
    smatson [OP] New Member
    Scott
    2019 TRD PRO
    Westcott lift / Mickey Thompson Baja Boss AT’s / S&B CAI/ Sprint Booster / DDS3 Max PODS / TRD Exhaust
    Soon, I will be replacing my rotors and brake pads.
    Does anybody have thoughts and/or replacement recommendations?
    Specifically, should I just go with OEM replacements or are there better aftermarket options that offer improved overall performance as it relates to stopping power?
    I have a 2019 TRD Pro with a Westcott lift and 285’s on factory wheels.
    Thank you!
    djshway likes this.
  2. Jan 15, 2023 at 12:55 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    I have aftermarket stuff and I vote OEM. The extra cost just isn't worth it in my opinion.
    This is specifically in reference to direct OEM fit components, not big brake kits or other custom fab setups.
    POWERPLANTHOMER and 2Toys like this.
  3. Jan 15, 2023 at 1:02 PM
    Lockdown
    Lockdown New Member
    Los Angeles
    2023 ORP Lunar Rock
    You're going to see divided response.
    There will always be the OEM camp. OEM brake pads, oil filters, air filters etc.
    Autozone's ceramic brake pads have served me well for the last decade.
  4. Jan 15, 2023 at 1:22 PM
    smatson
    Scott
    2019 TRD PRO
    I should have added - this is my daily driver and I travel about “70” miles per day round trip for work.
    I’m in in the PNW and while I don’t consider myself an aggressive driver I deal with rain and a lot of high speed highway stop-n-go due to traffic, etc.
    Anything, within reason, to improve braking would be welcomed…
  5. Jan 15, 2023 at 4:03 PM
    What are you looking to improve? If it’s durability, or stopping power, OEM is hard to beat.
    In my experience, there are some aftermarket options that will be as good as OE, but the price will be close to the same.
    The fit of the parts is pretty much guaranteed with OE, which makes it a lot nicer when you are doing it yourself.
  6. Jan 15, 2023 at 4:37 PM
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    I was rotating the tires every year .. then inspect the brake pads . also clean the brakes .my 2016 runner is around 40K miles and the brakes are not much wear pads . also bleed the brake fluid .
    you are probably not doing the runner maintenance ...
  7. Jan 15, 2023 at 4:38 PM
    tblt44
    tblt44 New Member
    Todd
    Tampa
    2021 4 runner
    N/A
    Do you need rotors.
    If thre in good condition I believe pads only will serve you well
  8. Jan 15, 2023 at 5:34 PM
    j cat
    j cat New Member
    massachusetts
    the brake pads are removed .. new brake pads ... then the sand paper is 220 ....rotate the rotor brake disc area rotation ...clean the mineral spirits then wipe it off and then do the job ..brakes working .. if the rotors are damaged distortion then the new rotors ..
  9. Jan 15, 2023 at 5:48 PM
    smatson
    Scott
    2019 TRD PRO
    I do all maintenance ahead of schedule including rotating the tires every 4K to 5k miles.
    Just wanting maximum stopping power / performance for safety purposes and peace of mind so if that means sticking with OEM I won’t question that…!
    I just assumed I’d replace the rotors and pads at the same time…
    McSpazatron likes this.
  10. Jan 15, 2023 at 5:54 PM
    j cat
    j cat New Member
    massachusetts
    the rotors are distorted and you are the brake pedal is doing the heavy pedal ...
  11. Jan 16, 2023 at 6:49 AM
    Startrek
    Startrek New Member
    any rust on caliper piston? periodic cleaning of calipers, front and REAR!!!, mitigate most brakes problems. "distortion" of rotors are easily to check by dial gauge on lockable magnetic base.
  12. Jan 16, 2023 at 7:06 AM
    Foothills
    Foothills New Member
    As others have said if rotors are good clean calipers of any rust and replace both front and rear pads, make sure new pads are lubed correctly when installed. I use Akebono ceramic pads on our vehicles for zero fade and good brake feel when mountain driving and minimal brake dust. Akebonos are made in Japan and said to be the oem manufacturers for some Toyota vehicles and maybe some years of 4runner.
    Check brake fluid moisture content with Brake Fluid Tester pen, I usually change fluid when it gets around 2% moisture content, some change at 3% or more. Brake Fluid Tester Pen costs about $10 and can last a lifetime.
  13. Jan 16, 2023 at 7:30 AM
    J0hnny
    J0hnny New Member
    Upgrade the pads when running heavier tires. Porterfield R4S are great, just bed them properly and they won't chew up your rotors. Expect some increased dust and watch your first cold stop as they need a little heat in them
  14. Jan 16, 2023 at 8:39 PM
    OEM. Just bed in the pads correctly.
  15. Jan 16, 2023 at 9:40 PM
    Powerbrake...big "boy" brake kit has my vote. I know expensive and maybe flashy...but seems like they don't disappoint on performance. I don't run these but wish I could.
  16. Jan 16, 2023 at 10:12 PM
    okietundra18
    okietundra18 New Member
    2018 SR5 PREM
    I've always had good luck with OEM.
  17. Jan 17, 2023 at 7:05 AM
    MAXIM
    MAXIM New Member
    OEM New Rotors and TRD Pads. Best combination for me. I had EBS Rotors with Hawk pads, OEM rotors with Hawk pads, EBS rotors with OEM pads and many other combos over last twenty years. New OEM rotors well made (still made in Japan) and affordable around $60 each. If you don't mind trading brake dust for superior braking performance expressed in killer initial bite, then TRD pads will not disappoint.
  18. Jul 7, 2023 at 3:48 AM
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    What's the part # for TRD front and rear pads? Can't find any listed for 2021 4R. Thank you fellas.
  19. Jul 7, 2023 at 12:18 PM
    Number16
    Number16 New Member
    2021 4runner
    Do you have the part number for these? I put Akebonos on my wife's BMW and for the minimal dust alone, they were worth it.
  20. Jul 10, 2023 at 9:25 AM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    Akebonos
  21. Jul 10, 2023 at 7:46 PM
    smitty93
    smitty93 New Member
    2019 Silver sR5 4Runner
    Powerstop is usually priced well. I just installed Powerstop Rotors and pads on the front and rear. They feel great! I got mine from Rockauto.
