Brake pads - Should front and rear be the same?
Discussion in '5th Gen 4Runners (2010-2024)' started by tonymac, Jan 25, 2022.
  1. Jan 25, 2022 at 7:50 AM
    tonymac
    tonymac [OP] New Member
    Anthony
    Whacko Texas (Waco for the PC)
    So I am replacing the rear rotors and pads. I bought a kit and ceramic pads are included. My question is, should I keep semi-metallic to match the front OEM pads or will it matter if the rear pads are ceramic?
    I have always replaced front and rear at same time, however fronts are in very good condition.
  2. Jan 25, 2022 at 3:36 PM
    Squatting Pigeon
    Holden
    North Texas
    I don’t think it’s going to make a difference in braking performance. They’ll wear differently though, and you’ll probably never be in sync replacing front and rear at the same time.
    Mtbpsych likes this.
  3. Jan 25, 2022 at 3:44 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    I don't think it matters. When I replaced my fronts my rears looked borderline new. I ended up replacing them all because I bought four but ill know for next time to check wear first.
  4. Jan 25, 2022 at 4:14 PM
    tonymac
    Anthony
    thanks, appreciate the replies...I'll just stick with what is in the kit and use the ceramics.
  5. Jan 25, 2022 at 6:48 PM
    a47chuck
    a47chuck New Member
    Central Oregon
    '19 Limited Nightshade, Midnight Black Metallic, front leveling kit, 265/60-20 KO2's and Magnuson Supercharger.
    I would keep the same type pad material front and rear. That would keep the proportioning front to rear the same as OEM, so as not to lock up one or the other prematurely. JMHO.
