Brake pad life
Discussion in '5th Gen 4Runners (2010-2024)' started by morfdq, Jul 23, 2023.
  1. Jul 23, 2023 at 2:24 PM
    morfdq [OP] New Member
    Hey guys
    I am having surgery Monday and will be laid up for a while. I’m trying to get everything done to the rig now. I have a 2022 with 38k miles. I can’t jack the vehicle or take the tire off because of my shoulder injury. I do have a buddy I trust to change my brakes if needed but was just wondering when people were doing their first brake job. Thank you for any replies
  2. Jul 23, 2023 at 2:29 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Hey, my 2016 was probably around 5 years, 60,000k
  3. Jul 23, 2023 at 2:32 PM
    Toyota 4Runner brake pads usually last between 30,000 and 70,000 miles. Rotors often replaced same time as pads for maximum pad life. Toyota rotors are said to live approx 80,000 miles
    ecoterragaia likes this.
  4. Jul 23, 2023 at 2:53 PM
    7Runner
    7Runner New Member
    2018 Silver SR5P
    2018 SR5 with 102K miles. Still on original pads. Keep an eye on them every time I rotate tires.
    I drive approximately 80-85% highway miles and am a very light braker.:)
    I bought some Akebono pads and Centric rotors feeling I will eventually need to
    replace them. That was 2 years ago.
    Slopemaster and 08TXRunner like this.
  5. Jul 23, 2023 at 3:34 PM
    Daddykool
    Replaced rear brakes on my 2019 at 92k miles. Fronts are due shortly. At around 115 k on those right now.
  6. Jul 23, 2023 at 3:36 PM
    08TXRunner
    08TXRunner New Member
    '20 SR5P
    You sure shouldn't need pads at 38K.
  7. Jul 23, 2023 at 3:42 PM
    Wow. Thank you everyone for the replies. I do all the work myself and would hate for them to start squeaking and I wouldn’t be able to fix them. I saw one person recommended akebono pads. I came from owning a 4R from Honda Pilot. Akebono was all I put on my Hondas and loved them. I am from the school of swapping rotors and pads at the same time. On the Pilot I always used the Bosch rotors and loved this as well. I only have 3k miles on my oil but I’m planning on changing the oil this week. With shoulder surgery I don’t know when I’ll be able to do it next.
  8. Jul 23, 2023 at 3:46 PM
    DirtyHairy
    DirtyHairy Card-holding Member
    Central NY
    2014 FJ Cruiser; 1978 FJ40; 2023 ORP MGM with KDSS
    Good luck with the shoulder surgery. I’ve had both labrum and one rotator cuff done in my shoulders.
  9. Jul 23, 2023 at 3:47 PM
    Amen. Sounds like you know how to do brakes. I do all of that as well. Relube the pins. It takes me about an hour a side. Not because I’m stupid but because I clean everything up and grind any rust off. The wife may disagree about the stupid part
    RingSteel likes this.
  10. Jul 23, 2023 at 3:51 PM
    steelevo
    Utah
    I sold my 2016 with 110k miles and still had at least 30% pad life left. My 2020 had 75% at 40k miles.
  11. Jul 23, 2023 at 4:09 PM
    Thank you. The surgeon said the surgery is really easy. It’s the recovery part that sucks. I already am signed up for physical therapy 3x a week for the first month.
  12. Jul 23, 2023 at 8:59 PM
    My rears lasted around 45k miles before hitting the squealers. The fronts still had some life but Input on new pads anyway. I’ve been through muddy water on more than one ocassion. I’m not a super light braker, but generally take it as easy as I can on brakes.
    Toyota OE replacement pads are akebonos. They have two lines of OE pads apparently. Factory replacement, and just replacement versions. I asked for factory replacements, but ended up getting the cheaper versions (metal backing is stamped akebono) because I didint check the part number. They do fine however.
  13. Jul 23, 2023 at 9:35 PM
    Tama1968
    Tama1968 New Member
    Florida
    T4R SR5 in Classic Silver
    Best of luck. I mainly work cardiac rehab but did ortho for several years. shoulders tend to take a while but stick with the program and you'll likely do well. about the truck, my 2019 has 75k on the odometer with the original brakes and Im just about at mininums, planning to do them in the next 2-3 weeks.
  14. Jul 23, 2023 at 9:46 PM
    2016Pro
    I change my oil every 10k.... on my Tacoma I haven't been paying attention.... at 17k now. I need to get busy!
  15. Jul 24, 2023 at 5:20 AM
    Mt last set of pads lasted 80k when I changed them (could have gone further), but yours could be different. Driving style and type are big variables. I do a lot of highway miles, so I may go miles at a time without touching the brakes.
    I also changed my front calipers when I did pads, one was seized and I couldn't get the pins out of the other. I'm thinking calipers are probably part of the front brake job the second time around (this was at 155k).
    Daddykool likes this.
  16. Jul 24, 2023 at 5:30 AM
    2016Pro
    Over 200k on my Tacoma, no worries with synthetic oil if I let it go longer. I've had a few Blackstone analysis done all good. Oh and i always use the cheapest synthetic I can find.
  17. Jul 24, 2023 at 5:34 AM
    Glenn Goodlett
    Glenn Goodlett New Member
    Glenn
    2020 TRD Pro
    Paid for
    I replaced pads at 80K and could have gone much more.
  18. Jul 24, 2023 at 4:12 PM
    beedee
    beedee Member
    I'm at 67k, been looking to do my brakes as well, been hearing some squeals when cold, but eventually goes away. I bought the 4R used, with 46k on it. I'll be doing both pads and rotors.
