Brake Pad choice for 16 ‘ TRD Pro?
Discussion in '5th Gen 4Runners (2010-2024)' started by Skeeterzx195c, Jan 2, 2024.
  1. Jan 2, 2024 at 12:58 PM
    Skeeterzx195c
    Skeeterzx195c [OP] New Member
    North Jersey
    16’ TRD Pro, 17’ ORP
    Hi, I need a set of solid brake pads for my 2016 TRD Pro….. I tow about three days a month ( 6 months a year) with a 2900lb bass boat. For those guys with fifth GEN 4 runners that do some towing do you have a recommendation on a better than stock brake pad? What is the call? Just looking to see if there is a specific brand guys tend to use if better than stock brake pads?
  2. Jan 2, 2024 at 1:07 PM
    This thread may help you decide: https://www.4runners.com/threads/brake-pad-suggestions.25192/
  3. Jan 2, 2024 at 3:21 PM
    3JOH22A Toyota Gigolo
    OEM pads are the best compromise between initial bite, friction consistency at different temps, dust, and noise. OEM pads typically also have the best corrosion resistance. So stick with OEM or Advics aftermarket pads. If you want more initial bite, get Stoptech slotted rotors. Slotted also helps with water evacuation driving out of a boat launch or water crossing on the trail.
  4. Jan 2, 2024 at 7:04 PM
    alittleoff
    alittleoff New Member
    Steve
    406
    '16 TP
    I'm a firm believer in OEM brake pads and rotors as designed.
    All the towable trailers that I drag around have electric brakes.
    I don't know if your bass boat with tandem axles is equipped with electric or surge, or if at all.
    That would be your best bet as to assist your 4R in its braking duties while towing.
  5. Jan 3, 2024 at 7:12 AM
    Skeeterzx195c
    North Jersey
    My dual axle trailer has brakes. I was doing some additional research and I see many guy suggest towing in S4 gear with a 4 runner -this way the vehicle is not hunting for gears on the highway. Does that sound accurate ?
    Great info on sticking with the OEM brake pads as that is what I will do
    alittleoff likes this.
  6. Jan 3, 2024 at 11:51 AM
    alittleoff
    Steve
    406
    '16 TP
    Yes, most 4R owners tow in S mode. I've done it for thousands of miles towing a loaded enclosed 6x10 cargo trailer or a 14' car carrier.
    And I'll add, gas mileage be damned.
    But I've never checked mine in all the years of ownership of this 4R, or any other vehicle I've owned. It's all about the smiles I get from the past Toyota P/U's, FJ-40's, '98 4R and currently the '03 TJ.
