Brake Job Help Plz!!
Discussion in '4th Gen 4Runners (2003-2009)' started by samw5400, Sep 8, 2020.
  1. Sep 8, 2020 at 7:40 AM
    samw5400
    samw5400 [OP] New Member
    Sam
    2009 Silver 4Runner Limited 4WD
    Cold air intake, Modified Exhaust, New Radio
    So I was recently putting lubricant on my front brake pads because of some squeaking, and I came to find out that my front left brake caliper had a bottom right piston seize up! I tried my hardest to get it to unseize, but I couldn’t get it unstuck... I realize that I should probably buy a new brake caliper, but I thought to myself if I should just buy a whole new caliper, pads, and rotor set for the front! The pads right now are about 50 percent life left, and the rotors seem to be fine... but the car was a northern car so it has some rust problems on the edge of the rotors.
    Can I get some opinions if I should just go for these options:
    1: Just one remanufactured caliper (W/WO new pads)
    2: Just one New Caliper (W/WO new pads)
    3: Or a whole new set??
    thanks again guys!!
  2. Sep 8, 2020 at 9:16 AM
    trlhiker
    trlhiker Lazy Bum
    1992 4Runner SR5 V6 4X4
    I would go with a whole set. Why do half the job?
    Rainier42 and Thatbassguy like this.
  3. Sep 8, 2020 at 9:26 AM
    If it's not too expensive, I would do complete sets on both sides. You'll thank yourself when you don't have to mess with the other side again in a year.
    Otherwise, at a minimum I would do pads on both sides so that one side shouldn't need replacing before the other.
  4. Sep 28, 2020 at 8:14 PM
    GalacticOwl
    GalacticOwl New Member
    Ryan
    Metro ATL, GA
    2008 Galactic Grey 4Runner Limited 4.7
    3/2 lift on Bilstein 5100 and OME springs 5th gen trail edition wheels Pizza Cutters (255/80r17) Toyo Open Country A/TIII Bolt on sliders BudBuilt stage 1 skid plate system
    I'd check the forums to see if any of the 5th gen guys up north have issues with seizing calipers. No issues with rust down here in GA but I did have a driver front seize up on me and opted to replace all 4 corners with 5th gen calipers and braided SS brake lines as it seemed to be a slight upgrade and everything bolted right up no problem. Might save you doing the job again in the future if it seems the that 5th gens hold up better to the elements.
    Only issue I had with this swap was that I ended up needing to stick with 4th gen rear rotors. Center hole diameter on the 5th gen rotor was slightly larger keeping it from centering itself on the hub. 4th gen rotors were the same or close enough in dimension to work just fine with 5th gen calipers.
  5. Jan 27, 2021 at 12:14 PM
    fdemike
    fdemike New Member
    2017 TRD
    I joined this forum to see about this. I have a 2017 4Runner and it only has 46,000 miles and had 2 seized calipers with plenty of pad left. Had to replace all 4 calipers and they didn’t warranty it with my extended warranty.
  6. Jan 31, 2021 at 10:43 AM
    captsolo
    captsolo New Member
    Tom
    nassau bahamas
    2005 SR5
    I watched a good mechanic doing the brake calipers on my 2005 4runner (150,000 mils) struggle for over an hour to free the pistons only to have them freeze up again. I'd buy rebuilt one from Amazon next time. The price for both calipers is good, and they fit my car. Make sure you put in the year, type etc. into the Amazon site so you get the right calipers.
    Amazon.com: A-Premium Front Wheel Brake Caliper with Bracket Replacement for Toyota 4Runner Lexus GX470 2003-2009 with 17 inches Wheelbase Left Right Set of 2: Automotive
    • 1 year unlimited-mileage quality guarantee
    If only one of your BRAKE calipers is "stuck" just replace it and leave the other for NOTHER DAY IMO.
  7. Nov 16, 2022 at 11:58 AM
    Keukasmallie
    Keukasmallie New Member
    Bob
    2019 Silver SR5 Premium
    2019 4runner Premium 18,400 miles. Brake pistons froze, cost $1,400 + to replace them as well as pads that were worn uneven as a result. Dealer said it happens often and will happen again unless brakes are "cleaned" at least every second oil change.
