brake controller
Discussion in '5th Gen 4Runners (2010-2024)' started by Uncle Dude, Aug 19, 2024.
  1. Aug 19, 2024 at 1:23 PM
    Uncle Dude
    Uncle Dude [OP] New Member
    mike
    2022 4runner sr5
    running boards, floor mats, brake controller
    I am trying to install a brake controller for my 2022 4runner SR5
    2nd try with a different controller / the brake controller works as it should but I have alarms on my dash for , anti lock brake system and anti crash system , can't get any answers from brake controller company
    would appreciate any help form anyone
  2. Aug 19, 2024 at 1:32 PM
    What's brand? Did you have to wire it up or plug n play?
  3. Aug 19, 2024 at 1:35 PM
    Uncle Dude
    mike
    2022 4runner sr5
    this one is a Rizz-Man , its plug and play
  4. Aug 19, 2024 at 1:52 PM
    Apparently not.
  5. Aug 19, 2024 at 2:00 PM
    Rizz is short for “charisma,” and it simply means an ability to charm and woo a person. I think you got your snake charmed. :spending:
  6. Aug 19, 2024 at 7:28 PM
    alittleoff
    alittleoff New Member
    Steve
    406
    '16 TP
    On my Tekonsha P-2, the dash lights freak out only when I apply the hand actuator. But once I got it fully adjusted to the particular trailer that I was towing that day, it worked without any other drama. I let the controller do its job and not use the thumb slide to test it.
    Maybe invest in a name brand BC.
  7. Aug 19, 2024 at 8:54 PM
    joshdub
    joshdub New Member
    2020 TRD ORP
    My redarc plugged right in with no issues. Sounds like the wiring isn't right on yours
    djdaves likes this.
  8. Aug 20, 2024 at 7:56 AM
    djdaves
    djdaves New Member
    SEPA
    2015 4runner SR5
    lift, wheels, tires, stuff.....
    I installed a redarc also. No issues. Plug and Play
  9. Aug 20, 2024 at 6:46 PM
    Uncle Dude
    mike
    2022 4runner sr5
    1st one was a Tekonsha 90160 Primus, I had the same issue with that one , sent it back because I couldn't get any on line help from the company
    tried calling and email , no response . the second one is Rizz-Man , same problem . they both work I just don't know why I'm getting these alarms .
    it's only 4 wires , hot, ground, signal from brake light , and output to trailer brakes, if any one of these were wrong, it wouldn't work ,
    maybe send this one back and try a Redarc. dealer want's $700 to install a brake controller , whoa !!!!
  10. Aug 21, 2024 at 6:00 AM
    djdaves
    djdaves New Member
    SEPA
    2015 4runner SR5
    I ordered rigjt from redarcs website. Super easy install. There's a video on youtubehttps://youtu.be/x8lN2IQzN08?si=aZxdC9L0v94wftx2. Very helpful. Save your self that 700. Diy!
  11. Aug 21, 2024 at 5:57 PM
    Uncle Dude
    mike
    2022 4runner sr5
    thanks guys , appreciate your input
  12. Aug 22, 2024 at 1:09 PM
    CalcityRenegade
    CalcityRenegade New Member
    Matt
    2023 T4R ORP KDSS
    Step 1 should be to purchase from a reputable manufacturer. Ran a Tekonsha in mine with absolutely no issues.
  13. Aug 22, 2024 at 5:24 PM
    Uncle Dude
    mike
    2022 4runner sr5
    wow !!! Arrow in the knee !!! that had to hurt !!!
    how'd that happen ??
  14. Aug 22, 2024 at 5:33 PM
    Oakboro, N.C
    Skyrim Reference..
    Using a Tekonsha with a 2022 via factory harness with no issues. I wonder if there is some type of impedance issue possibly with the LED lighting or connections. As stated, I have no issues currently on my 4runner.
  15. Aug 22, 2024 at 5:45 PM
    Nubes
    Nubes Toyota Addict
    I have a Redarc and have no problems. I did read that early on with the newer model Toyota's with the extra safety nanny sensors there was an issue if you manually applied the brakes via the controller it would throw codes on the dash. The fix was to put a diode in line to prevent the brake signal from being sent to the vehicle computer. The harnesses they send now has the diode pre-wired in.
    alittleoff and RumHamRunner73 like this.
  16. Aug 22, 2024 at 6:18 PM
    alittleoff
    Steve
    406
    '16 TP
    Interesting. Maybe that's why my P-2 disrupts the gauge cluster. Hmm
    Damn nanny's.
  17. Aug 31, 2024 at 1:24 PM
    Uncle Dude
    mike
    2022 4runner sr5
    OK !! 4th attempt , this time installed a REDARC Tow Pro Liberty
    WORKS GREAT and no issues yay !!! ( REDARC )
    Nubes and whippersnapper02 like this.
  18. Aug 31, 2024 at 1:32 PM
    Good to hear!
