Blue Lock Tite on bolts when installing sliders?
Discussion in '5th Gen 4Runners (2010-2024)' started by Havanabama, Mar 4, 2021.
  1. Mar 4, 2021 at 12:16 PM
    Havanabama
    Havanabama [OP] New Member
    2021 White TRD Pro
    Anybody use Blue Lock Tite on the bolts when installing RSG Sliders?
  2. Mar 4, 2021 at 12:18 PM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    My installer did.
    Havanabama[OP] likes this.
  3. Mar 4, 2021 at 12:31 PM
    ruiz4251
    George
    TEXAS
    16 Trail Premium
    Always good to have for peace of mind
    I didn't tho
  4. Mar 4, 2021 at 2:27 PM
    Havanabama
    2021 White TRD Pro
    Well knowing what my Pro is going to do, I figured it’s cheap insurance.
  5. Mar 4, 2021 at 2:34 PM
    ruiz4251
    George
    TEXAS
    16 Trail Premium
    Yep I take my trail on real trails and haven't had issues
    But yes use is for peace of mind
  6. Mar 4, 2021 at 2:36 PM
    Havanabama
    2021 White TRD Pro
    And now I know how to spell Loctite!! Lol
    a47chuck, ruiz4251 and Moon Landing like this.
  7. Mar 4, 2021 at 4:10 PM
    wdsteven
    wdsteven New Member
    Blue Loctite is a Medium strength thread lock retainer and is good for the size bolts that are used for Sliders and BTW more is NOT better with Loctite I really do know because I work for the manufacture of Loctite.
  8. Mar 4, 2021 at 4:12 PM
    Havanabama
    2021 White TRD Pro
    Thank you. I have usually used just enough for 1/4 to 1/2 of the threads. Good to know.
  9. Mar 4, 2021 at 8:28 PM
    Starr
    Jonathan
    SouthEast Maui
    Yes.
  10. Mar 4, 2021 at 9:35 PM
    NotaTRD
    NotaTRD It’s my wife’s 4R, she just lets me drive it
    CA
    2017 SW SR5
    Feel free to ask
    Nope, I just recheck them the night before heading out and retighten if needed.
  11. Mar 5, 2021 at 4:14 AM
    Havanabama
    2021 White TRD Pro
    I have a follow up question I hope you folks can help me with. Looking at my frame there are several plastic hole covers. Some round and some rectangle. Should I remove them? They are raised from the frame so will they just get crushed upon tightening all the bolts? Thanks
  12. Mar 5, 2021 at 6:00 AM
    NotaTRD
    CA
    2017 SW SR5
    Feel free to ask
    Yes, you will need to remove those plastic pieces for the sliders to sit flush on the frame.
    ruiz4251 likes this.
  13. Mar 5, 2021 at 8:39 AM
    ruiz4251
    George
    TEXAS
    16 Trail Premium
    Tip:
    Spray the frame with bedliner where the sliders will bolt on
    Hezael619 likes this.
  14. Mar 5, 2021 at 10:18 AM
    NotaTRD
    CA
    2017 SW SR5
    Feel free to ask
    I’ll probably do some kind of rust preventative next time I remove my sliders for touch up.
  15. Mar 5, 2021 at 10:31 AM
    kbp810
    kbp810 rebmem wen
    Nearly every external bolt I touch either gets loctite or antisieze. Antisieze if it’s a bolt that may need to be removed again soon (like skid plate or suspension), loctite for most everything else.
  16. Mar 5, 2021 at 11:37 AM
    koukimonster
    koukimonster DYNO4
    Appalachia
    Midnight Venture
    wut.
    I've been told specifically to NOT do that, by the manufacturer of my sliders (C4 Fabrication). Bedliner is thick and won't allow the sliders to sit flush against the frame.
    Do you guys not remove your sliders annually for clean up and touch up (of the frame)?
    I believe what you want to put on your frame before bolting up the sliders is Fluid Film.
  17. Mar 5, 2021 at 11:55 AM
    kbp810
    kbp810 rebmem wen
    Agree with bedliner not being a good idea... before install, I do clean the area, and hit it with a fresh coat of rattle can clear; but anything that adds bulk or could cause gaps, or allow the slider to move at the mounts, would be a bad idea.
    I do not remove my sliders annually; but I will occasionally re-spray clear or touch up the edges/contact points. I only remove if I notice any flaking or significant surface rust appearing near contact points, or signs of rust staining on the frame immediately below (or if the slider needs a significant strip/repaint).
    koukimonster[QUOTED] likes this.
  18. Mar 5, 2021 at 11:57 AM
    ruiz4251
    George
    TEXAS
    16 Trail Premium
    Never had a problem before
    My sliders are linex'ed and bloted to frame no issues
    I also wheel the Funk out of my ride as you can see in my album
  19. Mar 5, 2021 at 12:17 PM
    koukimonster
    koukimonster DYNO4
    Appalachia
    Midnight Venture
    @ruiz4251 What sliders do you have? It probably depends on the sliders, to an extent. My sliders wrap around the frame.. I don't think I could even get the bolts in the holes if there was bedliner applied.
    Regardless, I would wager that you wouldn't really want any bedliner there, at least if it's "thick," because any movement between the slider and the frame, where they meet, would be very bad for the bolts that hold them together. But if the liner isn't to thick, and isn't flexible, then whatever I guess lol.. seems to be working for ya! It's not like every bolt is critical, anyway. I have many holding each slider in place.. just look for rust and check for tightness periodically.
    IMO, locktite is not necessary as long as appropriate hardware is used.
  20. Mar 5, 2021 at 12:23 PM
    ruiz4251
    George
    TEXAS
    16 Trail Premium
    OPOR sliders 5years no problems 0
  21. Mar 5, 2021 at 12:26 PM
    koukimonster
    koukimonster DYNO4
    Appalachia
    Midnight Venture
    Gotcha, thanks. Yeah, those only bolt to the "face" of the frame, so bedliner application wouldn't be as much of an issue. That style would also be easier to maintain as you can see more of the frame for rust inspection without removing the sliders.
  22. Mar 5, 2021 at 12:32 PM
    ruiz4251
    George
    TEXAS
    16 Trail Premium
    ;) you got it
    always think ahead
  23. Mar 8, 2021 at 8:01 PM
    I used anti-seize on mine, because New England.
    Moon Landing and ruiz4251 like this.
  24. Mar 8, 2021 at 8:07 PM
    I don't remember which YouTuber but there was a video when he removed the sliders there were rust on the frame. Even though I sprayed rust proofing I will remove the sliders and see if there's any rust. So imo it's not good tighten forever..
    koukimonster likes this.
  25. Mar 8, 2021 at 8:24 PM
    Cowboy59
    Cowboy59 Enjoy the Adventure
    N. Florida
    I just installed my RCI sliders. I wiped on fluid film to the frame and slider. I also removed the plastic frame inserts to ensure a flush mount. I did not, nor would I advise, spraying on bed liner if you have KDSS. The hydraulic lines, while not bolted to the frame, are very tight to the frame. It took me and a friend to mount the driver side due to the KDSS lines. When the frame of the slider goes underneath the KDSS lines, the lines are even more tight. I would not risk putting more tension on those lines by adding bed liner. It could over stress the KDSS lines and lead to a failure. I don't think thread locker is necessary, as the pressure on the bolt is such that I don't think they would ever back out. But anti-sieze could be a good idea, especially if you live where they salt roads in the winter.
    koukimonster and Moon Landing like this.
