Bilsteins 6112 lift question
Discussion in '5th Gen 4Runners (2010-2024)' started by jeytrn, Dec 25, 2020.
  1. Dec 25, 2020 at 10:28 PM
    jeytrn
    jeytrn [OP] New Member
    New member here! Bought a 2021 4runner trd off road that's coming in February and already have a set of Bilstein's 6112/5160 along with KO2's in stock size.
    I tried searching the forums before making this post but couldn't find any pictures of 4Runner's running the 6112 with a 1.2 or 1.6 setting as well as a stock rear coil. So I'm hoping the community can post some pictures
    I plan on keeping the coils on the rear stock and mostly looking for a leveled look.
  2. Dec 25, 2020 at 11:08 PM
    Mtbpsych
    Mtbpsych New Member
    You can probably find pictures of 1” or 1.5” in the front with a stock rear.
    .2” won’t make a difference in appearance for lift height.
    nimby likes this.
  3. Dec 26, 2020 at 3:10 AM
    Welcome to the forum from; Wisconsin!
  4. Dec 26, 2020 at 8:22 AM
    doc4216
    doc4216 New Member
    Shannon
    The Land of Cle
    2015 SR5 Premium
    Dasaíta HU, Bilstein 5100s, AT Tires, Coveted grill lights
    I did the same but with 5110's so I'm not sure how that will change the look.
  5. Dec 26, 2020 at 9:14 PM
    Welcome to the forum!
    Not exactly what you're looking for, but 6112's @2.3" in front with 1.5" lift coils in back, and stock size KO2's.
    LPFE42, 2Toys, Roland and 3 others like this.
  6. Dec 27, 2020 at 5:40 AM
    Tomiboy
    Tomiboy New Member
    Tom
  7. Dec 27, 2020 at 12:52 PM
    Redned
    Redned New Member
    2019 MGM Off Road Premium w/ KDSS
    Bilstein 6112/ 5112 suspension. RCI sliders, ARB skid plates, Icon UCA’s, Icon 2” rear coils, TRD LED fog lights, 30” LED light bar. TSO Grille. 285/70/17 BFG KO2’s, Icon Vector 6 wheels. Weathertech floor mats. 2.5”/ 2” lift. K&N CAI.
    Bilstein 6112/ 5160 at 1.6” setting with stock rear coils. FC1DF434-671D-4DB4-BE6E-19FABF30E182.jpg
    Pentangler, 2Toys, nimby and 2 others like this.
  8. Dec 27, 2020 at 12:55 PM
    jeytrn
    Looks really good! Is there any front rake or do the rears sag when you have passengers in the back?
  9. Dec 27, 2020 at 1:07 PM
    Redned
    Redned New Member
    It was dead level to my eye- no forward rake, sagged a bit when fully loaded in back and with passengers, but that is going to happen if you go for the leveled look. 1.2” would give you a bit of rake and avoid sag when loaded. But if you want to replace coils later, 1.6” might be the way to go.
  10. Dec 27, 2020 at 1:10 PM
    Living the dream
    Living the dream New Member
    ABQ
    2019 T4R Off-Road KDSS
    Don’t know if you have KDSS but it is different adjustments. 08E2F3C6-019F-4B57-B2E6-3287F949078C.jpg
    Just an FYI
  11. Dec 27, 2020 at 1:14 PM
    jeytrn
    Ohh okay thank you! I'm still debating between 1.2 and 1.6 now. But I'm leaning towards 1.6 because I won't be carrying passengers 95% of the time unless I'm going on snowboard trips. Also do you have kdss?
  12. Dec 27, 2020 at 1:15 PM
    jeytrn
    Yep got that chart as well! I have kdss, but I just wanted to see what the other members are running. Thanks though :)
  13. Dec 27, 2020 at 2:06 PM
    Redned
    Redned New Member
    Good point- I do have KDSS. I had it done in a shop and hadn’t seen this chart. I told them to put it at 1.6” but it probably was installed at 1.7”.
  14. Dec 27, 2020 at 2:43 PM
    jeytrn
    Thank you! Guess I'm pretty set on the 1.6 setting after seeing your 4Runner with kdss. Now the waiting game begins for my 4Runner!
  15. Jun 3, 2021 at 5:59 PM
    Toofine44
    Toofine44 New Member
    Do you have any more pictures of a side view? I'm finally getting mine installed this Monday (6112/5160) and I'm thinking of doing 2.5" in the front and 1.5" in the rear. Any suggestions?
  16. Jun 3, 2021 at 6:15 PM
    Here's the best I could find from when I had stock size tires, and a picture as it currently sits.
    I think 2.5"/1.5" is the perfect lift. I'm happy with the look. Did you order 1.5" coils for the rear?
    2Toys likes this.
  17. Jun 3, 2021 at 6:39 PM
    Toofine44
    Thanks for the extra picture. I'm embarrassed to say this, but I do not know what coils I got for the rear. I'll email the shop now.
  18. Jun 3, 2021 at 7:05 PM
    No problem!
    I only know which coils I have because I was looking for extra load carrying capacity. There are many options for height and load ratings.
  19. Aug 24, 2021 at 5:43 AM
    bargolio
    bargolio New Member
    For the 1.5" springs you have in the rear, did you get the "Heavy Load Package; 400lb Constant Weight"? Or just the standard 1.5" lift springs? I like your setup and have 6112 & 5160s on order but need to purchase some springs.
  20. Aug 24, 2021 at 6:17 AM
    I went with the +400# heavy springs. I have full armor, roof basket, and about 200# of tools and recovery gear at (nearly) all times.
    bargolio[QUOTED] likes this.
