Bilsteins @ 1.75 with .4 OME rear spacers?
Discussion in '5th Gen 4Runners (2010-2024)' started by jdSnake, Apr 30, 2021.
  1. Apr 30, 2021 at 5:54 PM
    jdSnake
    jdSnake [OP] New Member
    2021 4TOR
    many to come
    Has anyone tried this set up? Got both on the way and was initially planning to run the bilsteins at .85 with the .4 spacers in the rear bc I like the rake but if this would give me a slight rake at 1.75 I might try that. Thanks for any incite.
    -JD
  2. Apr 30, 2021 at 7:19 PM
    You'll still get a slight rake with 1.75 F and 0.4 R.
    jdSnake[OP] likes this.
  3. May 3, 2021 at 7:04 AM
    21TOR
    21TOR New Member
    2018 4Runner
    Some
    I am going with 1.6 F and .75 R..........if my order ever shows up then I would know if it looks and rides good.
  4. May 3, 2021 at 1:30 PM
    Fortuner
    Fortuner New Member
    CA
    2021 4Runner TRD Off Road Premium w/KDSS
    I did pretty similar setup using Eibach Pro-Truck Sport Shocks...they adjust using perch's just like the Bilsteins. Slightly different, but close enough where the info should be helpful...I think you'll definitely still have visual rake.
    I set the front's to the 1.6" setting on the Eibachs and used a ¾" Cornfed spacer in the rear. What's funny is I had ordered the OME 10MM "trim packer" from ToyTec to use instead of the Cornfed, but changed my mind last minute. The trucks still got a considerable amount of rake to it on level ground...in retrospect I wish I had just kept the OME 10MM spacers.
    I just received my Dobinsons c59-300 order for the front. Going to lower the Eibach perch's to "zero" and swap out the stock spring, while retaining the Cornfed lift in the back.
    jdSnake[OP], 21TOR[QUOTED] and nimby like this.
  5. May 3, 2021 at 1:48 PM
    21TOR
    21TOR New Member
    2018 4Runner
    Some
    "I think you'll definitely still have visual rake"
    That is my hope, I think the 4runner looks better with a little rake.
    TomVedra, jdSnake[OP] and Fortuner like this.
  6. May 3, 2021 at 3:49 PM
    jdSnake
    2021 4TOR
    many to come
    You got a side pic by chance?
  7. May 3, 2021 at 4:13 PM
    Fortuner
    Fortuner New Member
    CA
    This is the best I have at the moment.
    arnette64, 21TOR and jdSnake[OP] like this.
  8. May 3, 2021 at 4:15 PM
    jdSnake
    2021 4TOR
    many to come
    That looks great, thanks
    Fortuner likes this.
  9. May 3, 2021 at 5:58 PM
    jdSnake
    2021 4TOR
    many to come
    You running 265s or are they 275s??
  10. May 3, 2021 at 6:37 PM
    Fortuner
    Fortuner New Member
    CA
    275/70/17 KO2's
    arnette64 and jdSnake[OP] like this.
  11. May 3, 2021 at 7:07 PM
    21TOR
    21TOR New Member
    2018 4Runner
    Some
    Perfect
