Bilstein help??!
Discussion in '3rd Gen 4Runners (1996-2002)' started by 01SR5underlandingggg, Dec 16, 2021.
  1. Dec 16, 2021 at 9:06 PM
    01SR5underlandingggg [OP] New Member
    Don't know anything about shocks to keep it real
    So took my.01.sr5 2wd to the shop he's saying I need new shocks immediately
    Can't really afford anything brand new at the moment so looking around on Craigslist& offerup and someone is selling a set of bilstiens off a 2015 4runner
    wondering if anyone knows if that would fit on mine? Asked the guy who's selling them and he doesn't know
    Here's the pic of what they look like
  2. Dec 16, 2021 at 9:19 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    They won't work without some fabrication, i.e. cutting and welding.
  3. Dec 16, 2021 at 9:22 PM
    That's what I thought what about these?
  4. Dec 16, 2021 at 9:23 PM
    And what's the difference why would the first one be so much cheaper and the full set versus the second one is just the front and way more expensive?
  5. Dec 16, 2021 at 9:28 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    The $150 set looks like an OEM takeoff, literally just the stock stuff on the truck.
    The $400 set was purchased aftermarket and has a spacer on the top, it also has adjustable ride height options.
    I imagine that's the reason for the price difference. Neither set will work for you however.
    Try this link, if you need shocks now and price is a concern, you can get basic replacement shocks fairly cheap
    https://m.tirerack.com/suspension/Susptabl.jsp?autoMake=Toyota&autoModel=4Runner SR5 4wd&autoYear=2001&autoModClar=
  6. Dec 16, 2021 at 9:41 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    Woops gave you 4wd info... here's 2wd components
  7. Dec 17, 2021 at 4:40 AM
    slixx1320
    slixx1320 New Member
    The 1st set is the same as the second set. Both are bilstein 5100 and are adjustable. Prob the reason is because they're from diff sellers? Also the 2nd set is 7months old, doubt it's even still available.
    If funds are tight, need something to get you through, don't plan to off road, don't want a lift, look into some off brand from Amazon. Something that'll get your by. This kit it complete except the rear springs (which you don't need) you can reuse your OEM rear springs. I don't know the quality so buy at your own risk. I rather go this route vs buying 2nd hand that looks to be offroad and used to hell.
    Amazon.com: DTA 70015 Full Set 2 Front Complete Struts with Springs and Mounts + 2 Rear Shocks 4-pc Set Compatible with V6 and 4WD 4 Runner Only : Automotive
