Biggest tires with out modding 2022 trd pro?
Discussion in '5th Gen 4Runners (2010-2024)' started by Atomfuji, Nov 7, 2022.
  1. Nov 7, 2022 at 6:26 AM
    Atomfuji
    Atomfuji [OP] New Member
    2022 4 runnner trd pro
    I have a TRD Pro 2022 and I feel like I can go bigger than 265/70R17 without modding. Whats the biggest I can go no mod?
  2. Nov 7, 2022 at 6:45 AM
    I think some people have gone with 275’s.
    Prepare yourself, your probably gonna get a hundred different answers. ;)
  3. Nov 7, 2022 at 6:52 AM
    JustATallDude
    JustATallDude New Member+
    2019 Toyota 4Runner TRD Pro
    Gibson Single Exit Exhaust - Magnuson Supercharger - Sprint Booster - GTR Ultra2 Highs - Evil Headlights w/ Morimoto LED - Anzo Black Smoked Tail Lights - LED Interior Lights - A-Pillar Phone Mount Mod - CTH Side Mirrors - Eibach TRD Pro-Lift Springs - Falken Wildpeak A/T3s 285/70/17 - FSW F246 17x8.5 - Lasfit LED Turn Signals - DDI Seat Jackers - Apex Overland Front Recovery Points - Big Red's Turn Signal Mod and AMD Mod - R4T Blackout Turn Signals - BlackVue DR590 Dashcam and more to come...
    Even with 275s you'll probably have to do some cutting to the bumper. At least moving the fender liner a little more forward. I had to put in the Eibach pro lift springs, move the fender liner, cut a little off of the bumper, ziptie the mudflaps back, and get the caster into spec to fit 285s. Good luck.
  4. Nov 7, 2022 at 6:54 AM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    You can fit 37's but you won't be able to turn.
    Mtbpsych, Toffees, NEguy and 2 others like this.
  5. Nov 7, 2022 at 6:57 AM
    Atomfuji
    yea bet it will look awesome
  6. Nov 7, 2022 at 7:23 AM
    Lockdown
    Lockdown New Member
    Los Angeles
    2023 ORP Lunar Rock
    Based on this video, 285's barley fit.
    275 should be ok.
  7. Nov 7, 2022 at 7:30 AM
    Lockdown
    Lockdown New Member
    Los Angeles
    2023 ORP Lunar Rock
    How many money did the tire shop give you when you turned in your OEM tires?
  8. Nov 7, 2022 at 7:43 AM
    Ha ha.. Totally..!!
    It is sad 275/70R17 don't have good choice, mostly Load E tires and Load C option is heavier than Load E. In
    255/80R17 its even worse, everything is Load E :frustrated:
  9. Nov 7, 2022 at 8:33 AM
    Toffees
    Toffees Stuff and things
    Micah
    LA
    16 LE
    Well, given there are multiple sizes for each "size" tire, and each manufacturer has tires that fit differently, it's fair to say that no two tires will fit the same, or YMMV as some like to say. Best to find a tire you like and read install stories, etc, or wade through the different threads. The two mods that are most likely are flap cutting/removal (likely) and BMC (do you want to go there?). After that if it rubs, see post #4. Also, there is this helpful guide (it's only a guide) from another forum:
    Atomfuji[OP] likes this.
  10. Nov 7, 2022 at 9:13 AM
    Atomfuji
    Thanks, this is great
