Bf Goodrich KO2 285/70/17 vs Nitto Ridge Grappler 285/70/17
Discussion in '5th Gen 4Runners (2010-2024)' started by Roland, May 18, 2021.
  1. May 18, 2021 at 7:22 PM
    Roland
    Roland [OP] New Member
    Which one?
    1. Ride noise on the Freeway
    2. Off-Road capability
    3. Life (miles)
    4. Snow
    5. Rain
    6. Mud
  2. May 18, 2021 at 8:01 PM
    You should add a poll to get the best results.
    I liked my KO2's but heard good things about the Nittos as well.
    1- I was pretty happy with the noise on the K02. Not like an all season, but not bad at all.
    2- either one should be pretty good for basic off-road use
    3- I have seen KO2's go 80K miles. Mine had 80% of their tread depth at 29K miles.
    4- I think both are 3PMSF tires, but neither will be anywhere near as good as a winter tire.
    5- based on what I've read I would give this to the Nittos
    6- neither will be very good in mud. My KO2's did fine in shallow mud, but anything besides a true mud tire will struggle in deep mud.
  3. May 18, 2021 at 8:18 PM
    Roland
    Yeah, I had BF Goodrich KO 37" on my other vehicle (not a Toyota) they where realy good on all kinds of different roads. No vibration, silent on the Freeway and good Off-Road, just don't know how well they behave on a 4runner. Right now the rig has Nitto Terra Grapplers 265/70/17 which are OK, not so good Off-Road, just ok.
  4. May 18, 2021 at 8:32 PM
    Mtbpsych
    Mtbpsych New Member
    Coming from the KO2’s to the nittos, 100% nitto. The KO2’s did seem to hold up a little better tread wise, but everything else about the nittos is much better IMO.
  5. May 18, 2021 at 11:19 PM
    I've got Nitto RG's, 17,000 miles, so far, so good. No complaints.
  6. May 19, 2021 at 4:25 AM
    21Venture
    21Venture Roof Rat
    Bryan
    Edinburg, TX
    2021 4R Venture Super White & 2007 FJ
    4R-TerraFlex Falcon Sport/Tow 2/1 Lift/Level, Nise Rack Crossbars, KO2 LT265-70-17 FJ- Icon Stage 3, 4.56 gears and 10k winch
    I'm running both of these. Have LT265/70/17 on my 4R and LT285/70/17 on my F J. Both are good tires and wear well. The KO's do not make as much noise. Part of that could also be a 2007 FJ vs a 2021 4R. I think the KO2 will have an edge in the side wall department.
    Most of the off road I encounter here in the valley is sand at the beach. No issues with either tire. Never have been stuck with these. Did do a week long trip to Big Bend with the FJ/ Nitto RG's mixed with mud and desert terrain. No issues did everything.
    Both tires look good. I guess in reviewing what I wrote, look at which ever tire has the best deal. Really the only positive of the KO2 is less road noise. IMHO
  7. May 19, 2021 at 10:41 AM
    Roland
    This is a good indication; I do not like to much noise on the freeway. I drive around 90-95% on the Freeway & City. My vacations are Off-Road (the 4 corners) mostly rock in Moab and somethimes encountering washboard.
  8. May 19, 2021 at 10:44 AM
    Roland
    What about the noise on the Freeway?
  9. May 19, 2021 at 10:45 AM
    Roland
  10. May 19, 2021 at 10:55 AM
    Mtbpsych
    Mtbpsych New Member
    No issues there, they’re a really quiet tire IMO.
    Running a 295/70/17, E load and it’s incredibly quiet for what it is and for a nice aggressive tread pattern.
  11. May 19, 2021 at 11:32 AM
    rickystl
    rickystl New Member
    Rick
    St. Louis, MO
    2021 TRD/Off-Road Premium
    I have no experience with the Nitto's. But I had three sets of KO2's on my FJ over 11 years. Never an issue. Good side wall strength, good mileage, and reasonably quite on the highway. And they look good. LOL Going to put a set on my 21' 4R soon.
    Rick
  12. May 19, 2021 at 11:35 AM
    diverdon
    diverdon New Member
    Don
    Florida
    21 t4r sr5 premium
    I’ve got a few hundred highway miles on my ko2s there quiet
  13. May 19, 2021 at 12:13 PM
    What noise?
    Seriously they are very quiet for the type of tire.
    Mtbpsych likes this.
  14. May 19, 2021 at 12:21 PM
    koukimonster
    koukimonster DYNO4
    Appalachia
    Midnight Venture
    I'd go with the K02 in C load and save a good bit of weight over the Ridge Grapplers.
    Roland[OP] likes this.
  15. May 20, 2021 at 12:31 PM
    Roland
    I have experience as well with the KO, on a different vehicle. They are verry good. Thinking about it. Thanks for the feedback.
  16. May 20, 2021 at 12:33 PM
    Roland
    Thinking about it, I had good luck in the past with them.
  17. May 20, 2021 at 12:34 PM
    Roland
    Which size do you have?
  18. May 20, 2021 at 12:41 PM
    diverdon
    diverdon New Member
    Don
    Florida
    21 t4r sr5 premium
    285/70-17 load range c
  19. May 20, 2021 at 1:18 PM
    Roland
    Hello Don,
    Which lift setup do you run to be able to fit the 285/70/17?
  20. May 20, 2021 at 2:14 PM
    diverdon
    diverdon New Member
    Don
    Florida
    21 t4r sr5 premium
    Right now I have corn fed spacers. Will be swapping out the rear spacer for a 2” coil and eventually swap out front shocks. I only wanted a 2” lift so I wouldn’t have to mess with a lot of other things.
  21. May 20, 2021 at 2:37 PM
    Roland
    Did you neede to do some cutting on the front end, If I may ask.
  22. May 21, 2021 at 3:54 AM
    diverdon
    diverdon New Member
    Don
    Florida
    21 t4r sr5 premium
    I didn’t do any cutting at all
  23. May 21, 2021 at 8:54 AM
    Daytonaviolet
    Daytonaviolet TRD Bro
    Bay Area, CA
    Blizzard Pearl TRD Bro
    I’m installing 295/70/17 load E RG’s today. Previously had same tire but 285 size. it’s a great daily driver all terrain tire but has mud terrain tire looks and ride characteristics.
    Roland[OP] and Mtbpsych like this.
  24. May 21, 2021 at 10:18 AM
    Roland
    Do you have after market wheels? I have the TRD Pro wheels. Any info on your caster settings?
  25. May 21, 2021 at 10:26 AM
    Roland
    Which lift do you have? Do you have after market wheels? If I may ask.
  26. May 21, 2021 at 10:36 AM
    diverdon
    diverdon New Member
    Don
    Florida
    21 t4r sr5 premium
    I have my sr5 wheels
  27. May 21, 2021 at 10:46 AM
    Mtbpsych
    Mtbpsych New Member
    They do pretty good in muddy conditions, and tuck in nicely:101010:
  28. May 21, 2021 at 11:39 AM
    Roland
    Nice setup. How did you fit the tires in the front without rubbing? They are about 33.6" if I'm not mistaken.
  29. May 21, 2021 at 11:43 AM
    Mtbpsych
    Mtbpsych New Member
    Thanks! Yep, they’re almost a 34” tire. And a decent amount of chopping up front is needed along with upper control arms to adjust caster.
  30. May 21, 2021 at 12:42 PM
    Daytonaviolet
    Bay Area, CA
    Suspension is kings. Currently have trd pro wheels (17x7 et4) w/ 285/70/17 & 1.25” spidertrax spacers.
    New wheels will be 17x9 et-38 w/ 295/70/17.
