Better way to lube lower track bars?
Discussion in 'Suspension' started by Thacrow, Mar 24, 2023.
  1. Mar 24, 2023 at 3:51 PM
    Thacrow
    Thacrow [OP] New Member
    2021 ORP
    Speed holes
    I've got Icon lower track bars with the flush / needle fitting. The lower mount is int he way so I have to disconnect them to lube them up. I use a couple ratchet straps so it's easy to align the hole to get the bolt back in but it would be real nice to be able to pub them while onthe vehicle.
    I was thinking of just cutting a notch in the metal so they are easier to get ti. Maybe weld some metal above so it's more stable. Anyone do anything like this?
  2. Apr 8, 2023 at 10:13 AM
    TrailSpecial22 New Member
    PA
    can you flip the around so its on the bottom?
  3. Apr 8, 2023 at 9:28 PM
    Thacrow
    2021 ORP
    Speed holes
    Technically yes but then the "Icon" would be upside down, the e-brake line would not have a hole to mount to and there's these plastic strips on the bottom that are replaceable and meant to take damage instead of the aluminum. and those would be on he top.
  4. Apr 8, 2023 at 11:52 PM
    Thacrow
    2021 ORP
    Speed holes
    I have to drop the control arm to lube it. Dropping the suspension almost doesn't move that valve.
  5. Apr 9, 2023 at 7:48 AM
    PA
    got it
