Best Jack/Stand Combo
Discussion in '5th Gen 4Runners (2010-2024)' started by Dougie, Mar 22, 2020.
  1. Mar 22, 2020 at 4:29 PM
    Dougie
    Dougie [OP] New Member
    '19 TRD ORP
    Looking to kit out my garage so I can do more maintenance & projects myself. What would y'all recommend as far as a setup? Currently running stock, but would like to go up ~3in in the future with 33s. I've been going over the following points:
    • Floor vs. bottle
    • Pretty sure I want to go heavier duty on the stands (6 ton)
    • max versatility
    • safety
    • good brand
    Thanks!
  2. Mar 30, 2020 at 11:24 AM
    kaosonline
    kaosonline shadow member
    Graham, WA
    King Off Road lift front/rear; Dobinsons rear springs; 285 75R17 Nitto Trail Grapplers on FUEL D666 rims; Hefty Fabworks sliders; Relentless Stingray w/20" Rigid light front bumper; Expedition One dual gate rear bumper; Factor 55; WARN winch; RCI skid plates; tinting; LED and HID lights all around inside/out; Front Runner rack + light, iKamper RTT
    No idea if this is 'the best', but after my lift, tires, and added weight, I looked for something to get my 4R off the ground for regular maintenance, and decided on a pair of these: Powerbuilt 620471 6000lb, Unijack 6000Lb Unijack I like them because they're jackstands & bottle jacks in one unit. They're just about the right height for most things, but if you need/want more clearance once jacked, you may want something taller.
    https://www.amazon.com/dp/B00GJJZ5NI/ref=twister_B077GD5PJ8?_encoding=UTF8&psc=1
    WesMatthews2 and wmdtech like this.
  3. Mar 31, 2020 at 3:23 PM
    wmdtech
    wmdtech Send MOD Money!!
    Nate
    Mid TN
    18 TRD ORP
    I dig it, but $90 for just one is too much for me
  4. Mar 31, 2020 at 3:30 PM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    What kind of maintenance? I can do oil, transfer and differential fluid without any jacks or ramps on stock height.
    If anything, get 4 equal height ramps.
  5. Apr 3, 2020 at 2:51 PM
    akkording
    akkording New Member
    HTX
    2012 blizzard pearl sr5 4x4, 03 Tacoma sr5 dcsb v6
  6. Apr 5, 2020 at 2:47 PM
    Backwoods
    Backwoods New Member
    2019 silver SR5 4x4
    Personally I'd never recommend or trust the drive on ramps...
    I have 4, 3 ton Jack stands. And 4, 6 ton Jack stands, and a Daytona floor jack.
    The 3 ton stands I use on my wife's car, or anything small... Fully extended they won't hold my lifted 4runner up high enough to get the tires off the ground.
    The 6 ton stands work great though. I bought all 4 for under 100 bucks on Amazon.
    Torin Big Red Steel Jack Stands: Double Locking, 6 Ton (12,000 lb) Capacity, 1 Pair https://www.amazon.com/dp/B00026Z3DQ/ref=cm_sw_r_cp_apa_i_bhLIEb2G2KHN5
  7. Apr 5, 2020 at 2:52 PM
    ForRun
    ForRun 4Runner
    2020 orp
    Ive got that Daytona jack and wished I bought it years ago. Got old using a chunk of 4x4 wood just to get the height for a truck
    A&P and Backwoods[QUOTED] like this.
  8. Apr 5, 2020 at 2:54 PM
    Backwoods
    2019 silver SR5 4x4
    Yea man I love it. Doesn't take much to get it lifted either. It's quick.
    A&P and ForRun[QUOTED] like this.
  9. Apr 7, 2020 at 11:23 AM
    08TXRunner
    08TXRunner New Member
    '20 SR5P
    I use pin-style stands. I don't like the ratchet style stands because the whole weight of the truck is on a relatively small catch and lever. But I'm a little paranoid when it comes to yanking on stuff under a car that's off the ground. These are the exact ones I have, 22 tons each. The pin is 1" OD tool steel :D
    A&P and alittleoff like this.
  10. Apr 7, 2020 at 11:28 AM
    Backwoods
    2019 silver SR5 4x4
    Those look nice! My ratchet style stands have a thick pin that goes through them as well... They're dual locking.... Well the 6 ton are, not the 3 ton.
  11. Apr 7, 2020 at 12:01 PM
    08TXRunner
    '20 SR5P
    They're heavy af. Something like 70 lbs each! If you look them up, they're actually for forklifts.
  12. Apr 7, 2020 at 3:55 PM
    Libagui
    Libagui New Member
    Librado
    2006 Silver 4runner limited.
  13. Apr 7, 2020 at 4:02 PM
    Jynarik
    Austin Texas
    2019 trd pro voodoo
    I would rather have 4 drive on ramps than trust 4 jack stands.
    taco_runner likes this.
  14. Apr 7, 2020 at 7:51 PM
    Backwoods
    2019 silver SR5 4x4
    If you are talking about 4 permanent, anchored, drive on ramps, with room for tire chocks, sure.... 4 plastic mobile ramps... No way. They are not even allowed to be used in lots of shops, or in auto tech college because they are not as reliable. You also cant do tire work with drive on ramps. No changing tires, no rotations, no suspension work.... they are less useful. Im not saying i have never used them..... Im just saying i wouldnt buy them. If you are only changing oil... It might be OK.... I would still rather jack stands personally. But jack stands should have lock pins also, my 6 tons do.
  15. Apr 7, 2020 at 9:48 PM
    Agent_Outside
    Built 2011 T4R Limited
    I also have and like the yellow Daytona jack, it’s a great value.
  16. Aug 11, 2020 at 8:52 AM
    SlvrRnnR
    SlvrRnnR New Member
    18 4R TRD ORP
    Stock Size KO2's - TRD CAI - TRD Exhaust, KC HiLites Hidden 20" Lightbar, Ditch Lights, Back Up Led Pods, ARB Dif Breather, ScanGauge III, OEM Rock Rails
    Ive been looking at these, man - look solid. 19" is what I can find for max height is this tall enough for standard 4R? Have KO2's but stock size (no lift). My other thought was the ProLift that max out at 23" tall. I do like the this pin type better though. Not as young and crazy as I use to be!
  17. Aug 11, 2020 at 9:20 AM
    mcat707
    mcat707 MURDERED TRD
    NOR*CAL - Solano County
    2015 TRDPro - Attitude Black Metallic 218
    I use the Sunex 10ton jack stands along with a Daytona 3ton long reach low profile rapid floor jack. The Sunex are perfect if you have a lift. IMO, Those ratchet style jack stands are risky on a heavy rig like a T4R. Especially with all the Harbor Freight jack stand failures and injuries going around. I wouldn’t risk any life with those type of ratcheting jack stands.
    quoted from a post I made in another forum:
    Here are the Sunex 10ton jack stands that I have. I have the steel pin in the first hole and the tire is about 3-4inches above the ground.
    2nd pic is the show the size compared to my 285/70/17 tire. They are about 60lbs each.
    The 3rd and 4th pic is to show the 3/4” thickness of the solid steel pin and platform stand.
    These jack stands are stout and solid. 028C726D-8DDB-435A-A588-CBB65522D104.jpg D0EADDD8-4A1A-4F20-84F4-6AC8DDE6A80D.jpg 78E27889-9445-4AFC-AA14-D367BF48B580.jpg 00A296A2-D8FB-4652-8261-A820D627A356.jpg
  18. Aug 11, 2020 at 9:25 AM
    Red_5
    Red_5 New Member
    Are you using the Sunex Standard or High stands?
  19. Aug 11, 2020 at 9:30 AM
    mcat707
    I’m using the medium height jack stands #1310
    I think they have 3 heights for the 10 ton stands, low, medium and high.
    Red_5[QUOTED] likes this.
  20. Aug 11, 2020 at 10:24 AM
    SlvrRnnR
    SlvrRnnR New Member
    18 4R TRD ORP
    I like these also, do you think the bottoms would be ok on an asphalt driveway? I'd try to avoid extreme hot days...learned years ago with motorcycle side stands to pay attention to the heat or to have a pad.
    Sunex also has the 22 ton (I know this overkill) but I like how compact they are and they have a solid square base.
    https://www.northerntool.com/shop/tools/product_200610848_200610848?cm_mmc=Google-pla&utm_source=Google_PLA&utm_medium=Automotive > Jacks > Jack Stands&utm_campaign=Sunex Tools&utm_content=39058&gclid=EAIaIQobChMIrPKMidaT6wIVCm6GCh1d3Qm2EAQYAiABEgL78fD_BwE
    I've got a ProEagle jack coming (gift:bananadance:) and want to just start doing my own tire rotations. No lift, so trying to figure out if 19.7 inches of a jack stand will be enough.
    Will rotate front > back/back > front so trying to keep to two jack stands?
    Aware of Toyotas recommended jack points = (front middle back of skid plate ((or under the skid if removed, Ive got the Pro TRD skid plate )) and rear center pumpkin) and support points = front at frame where it angles in and rear diff axle.
    I haven't seen any great video showing where to jack and how to place stands to lift one side only? I guess jack from th recommended front point and place front jack stand then jack from rear and place rear jack stand so one side of the vehicles tires are off the ground at the same time. Any suggestions on that would be appreciated.
    mcat707[QUOTED] likes this.
  21. Aug 11, 2020 at 10:36 AM
    mcat707
    Those look solid. I would definitely get those over any ratcheting jack stand. Sounds like the height will work for you but for others with lifts, probably not.
  22. Aug 11, 2020 at 12:15 PM
    08TXRunner
    '20 SR5P
    My truck is lifted 2/1 and these stands will keep front or back wheels off the ground without issue.
  23. Aug 11, 2020 at 3:51 PM
    WesMatthews2
    WesMatthews2 New Member
    Matt
    I want your garage!
    Backwoods[QUOTED] and Red_5 like this.
  24. Aug 11, 2020 at 4:51 PM
    Oldtoyotaguy
    Oldtoyotaguy Paid cash for it
    2018 Toyota 4 Runner Offroad
    Nice clean shop, beauty!
