best highway trip PSI for LT285/70R17 load-e 5500lbs curb weight?
Discussion in '5th Gen 4Runners (2010-2024)' started by djwantke, Dec 17, 2024.
  1. Dec 17, 2024 at 12:30 AM
    djwantke [OP] New Member
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    please recommend from experience what PSI you prefer to run for highway trips (almost 400 miles).
    tires are LT285/70R17 load-e aggressive AT’s, 5500lbs curb weight.
    much appreciated
  2. Dec 17, 2024 at 7:26 AM
    wow, 500lbs heavier than mine with all skids from a-arm to rear diff + sliders. I would assume your have front and rear bumpers, winch, rear drawer system and many more..
  3. Dec 17, 2024 at 8:28 AM
    Steel sliders yes, steel bumpers no , I know it sounds heavy but that’s what the scale says. The weight comes from 4 skids, roof rack w/ gear, emergency box, full-size spare, and my heavy ass wheels & tires.
    2400kg before full-size spare, steel sliders
    kmeeg[QUOTED] likes this.
  4. Dec 17, 2024 at 8:55 AM
    Stoney Ranger
    Stoney Ranger Lockers? Pffft
    Dave
    Driftless Area
    '18 SR5 Nauti Blue
    4x Rockers/Skids-Dobi-275's-F/R Bpr-Winch-Stickers-ALF
    When I bought the 275/70 17 Wildepeak AT/3's, Discount Tire set them at 42 psi. The tires have 65,000 miles on them and the centers are worn to 9/32. The edges are at 10/32. The info I could find, they were 18/32's when new. I am very happy with the wear.
    ALF is fully armored. Front and rear bumpers, winch, steel sliders, belly skids, shock skids, and recovery gear. Weighs 5520# with a full tank of gas.
    Jedi5150 and djwantke[OP] like this.
  5. Dec 17, 2024 at 9:01 AM
    @Stoney Ranger ahh I see good to know, very helpful Stoney. Sounds like pretty even wear at 42psi, maybe ever so slightly high
  6. Dec 18, 2024 at 2:50 AM
    Kyblack76
    Kyblack76 New Member
    Layton, Utah
    18 TRD O.R
    E ? Jesus, put 75psi in em if you feel like it. Sheesh.
  7. Dec 18, 2024 at 9:02 AM
    Supremely helpful @Kyblack76 you should chill, guy.
  8. Dec 18, 2024 at 9:12 AM
    just found dis thread ^ stealing ya’lls advice
  9. Dec 18, 2024 at 10:34 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-675v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered. Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights LasFit Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Started running 34psi front 38psi rear. Seems to ride a little smoother since I've got some pretty stiff coils up front.
    35-40 should work just fine for you. The link Thatbassguy posted is a great recourse!
    djwantke[QUOTED][OP] likes this.
  10. Dec 18, 2024 at 10:50 PM
    Gripster
    Gripster New Member
    2016 Trail Premium
    djwantke[OP] likes this.
  11. Dec 19, 2024 at 6:44 AM
    Kyblack76
    Layton, Utah
    18 TRD O.R
    No worries. With that load, 5 or 20 lbs wont matter at all. With that link you are fond of, you do see the max PSI for E load, go up to 80.,.. Right? Just checking.
    Edit- cheers and enjoy.
  12. Dec 19, 2024 at 12:54 PM
    Hey bro thanks, yeah I think you’re right the max is 80. I think I’ll drop down on my next tires to C or D
  13. Dec 20, 2024 at 12:47 AM
    Jasonst4r
    Jasonst4r New Member
    Jason
    2021 offroad barcelona red
    275 70 17 at3w
    only true way to find the correct psi for your specific rig is a chalk test. pick a psi to start at test/adjust until you get to the correct chalk markings. very simple process.
  14. Dec 20, 2024 at 1:12 AM
  15. Dec 20, 2024 at 1:14 AM
    Ah yes the classic chalk test. I’m gunna have to try this for first time
