Best Entry level Suspension
Discussion in '5th Gen 4Runners (2010-2024)' started by Gabe 2017SR5, Nov 9, 2020.
  1. Nov 9, 2020 at 11:37 PM
    Gabe 2017SR5
    Gabe 2017SR5 [OP] Gabe
    Gabe
    Inland Empire
    2017 4Runner Storm Trooper
    TRD Pro grill, LED interior lighting, and a bunch of mistakes with plasti dip (luckily can be removed).
    Hi, I am new to this Forum.
    I have a 2017 4Runner SR5 and am looking for the best entry level Suspension (3”Front, 1.5 or 2” rear) What do you recommend?
    Also, I wanted to try and fit a 34” tire. Is this possible ?
  2. Nov 10, 2020 at 2:04 AM
    Welcome from Wisconsin! From what I hear on the forum you'll be doing a few mods to fit a 34" tire. Body mount chop, cutting/ trimming/ adjustment to inner fender liners and such. Someone with 1st hand knowledge will have more answers than I do. It should look great when you're done.
    Gabe 2017SR5[OP] and Thatbassguy like this.
  3. Nov 10, 2020 at 5:57 AM
    CowboyTaco
    CowboyTaco New Member
    Michael
    2011 Tacoma DCSB
    Even going to a 33" tire will likely require some minor trimming.
    For entry level suspension, I'd probably look at OME, Dobinsons (15% off for Black Friday IIRC) or Ironman4x4 (20% off for Black Friday IIRC). You could also look at the ToyTec website or Headstrong and see what they are offering. I've had good experience with both of those companies. If the look is all you care about, then spacers should be fine. If you plan to go off road, stick with suspension lifts.
    1Louder and Gabe 2017SR5[OP] like this.
  4. Nov 10, 2020 at 6:50 AM
    KSapanza4Runner
    KSapanza4Runner New Member
    Ken
    2018 Silver Toyota 4runner SR5
    I’m running the Eibach pro truck lift(2.75 front,1 in rear) with 285/70/17 MTs. No rubbing from what I can see.
  5. Nov 10, 2020 at 7:28 AM
    Welcome to the forum.
    Gabe 2017SR5[OP] likes this.
  6. Nov 10, 2020 at 7:36 AM
    CowboyTaco
    Michael
    2011 Tacoma DCSB
    Interesting. Are you running spacers on the wheels or anything? Have you checked the upper and lower control arms for signs of rubbing?
  7. Nov 10, 2020 at 7:36 AM
    travelinscout
    travelinscout New Member
    2020 TRD ORP MGM
    Welcome!
  8. Nov 10, 2020 at 8:05 AM
    KSapanza4Runner
    Ken
    So originally I was just going in for a fit test for the Cooper MTs that I was checking out, but after the fit test(I checked for rubbing all around and did a full turn test both sides to check for any other rubbing) I still found I had enough room all around. I am planning to get aftermarket UCAs since that was my biggest concern but as of right now, there is no rubbin g that I’m concerned about.
  9. Nov 10, 2020 at 8:21 AM
    packetcollision
    packetcollision New Member
    MN
    '20 4Runner TRD-ORP
    Does your use case include functionality/performance of the suspension or purely appearance?
  10. Nov 10, 2020 at 8:56 AM
    Gabe 2017SR5
    Gabe
    Inland Empire
    I am looking for a good suspension set up to go off-roading with.
  11. Nov 10, 2020 at 8:57 AM
    Gabe 2017SR5
    Gabe
    Inland Empire
    I was gonna buy the Eibach stage 1 pro lift. How does it do Offroad ?
  12. Nov 10, 2020 at 9:37 AM
    KSapanza4Runner
    Ken
    It definitely helps with overall clearance and stability through the trails. I hit a lot of bumpy/rocky terrain here in NM and the Eibach kit handles it all very well. Plus it levels out the 4Runner pretty nicely as well.
    Pic below with my rig with lift and new tires. I’ll get better ones later
  13. Nov 10, 2020 at 9:41 AM
    travelinscout
    2020 TRD ORP MGM
    Looks great!
  14. Nov 10, 2020 at 9:45 AM
    KSapanza4Runner
    Ken
    Thank you! Next upgrades will be sliders and Grill swap.
  15. Nov 10, 2020 at 10:00 AM
    Mtbpsych
    Mtbpsych New Member
    Check out my build thread: https://www.4runners.com/threads/another-sr5-build.13098/
    I’d consider it a entry level kit, and it’s been great on the trails. It’s a 3” front lift, 2” rear lift and I’m running 33.3” tires. I plan on upgrading in the future, as I do more trails and trips and zero in what kit will fit my needs the best.
    LoadedGrayMagORP likes this.
  16. Nov 10, 2020 at 10:52 AM
    CowboyTaco
    Michael
    2011 Tacoma DCSB
    Very nice. Looks good!
  17. Nov 10, 2020 at 11:17 AM
    LoadedGrayMagORP
    LoadedGrayMagORP BFYBSKR
    2021 ORP
    @toyotausa •'21 TRD ORP •TRD skid •oem hood protector @ironman4x4america •3"/2" Foam Cell Pro - Stage 3 •Air Champ Pro •Air Champ Smart Deflator @maverickpowdercoat •custom bronze chrome coil springs @falkentire •285/75/17 Wildpeak AT3Ws @summitoffroad •Raptor 17x9, -12 @kseriesparts •Muteki SR48 lug nuts/locks @spidertrax •1.25" spacers @westcottbuilt •20° sliders •rear hatch ladder @kustom54lighting •AB6 headlamps @sibi.built •suspension install •BMC •Viper cut •preload adjustment @runnin4tacos •Lower Control Arm skids •side mirror sequential turn signals •GoPro load bar mount @apexoverland •recovery points @cali_raised_led •dual rear window molle panels w/ cargo tray @gopro •Hero4 Silver @anzousa •smoked sequential tails @sherpaec •Crestone full rack •Smiley hooks •HiLift mounts •Adapt plate @joesoriginalequipment •SLAPv2 [driver side] @ecotechne •hood rack @4wdadventures.usa •Recovery boards (hood) @hiliftjacks •60" jack lift @ultimate9usa •iDrive throttle controller @ellisprecision •custom shift knobs @rotopaxofficial •1 & 4g gas/1g H2O •DLX •LOX •EXT @ssahaus •laser alignment @thedecalgarage •roll call decals @xtreme_tint •5% all around @avs_autoventshade •lo pro window visors @4runnerlifestyle •pro grille •raptor lights •exterior chrome delete @ajt_design /@mesocustoms •interior chrome delete @revteksuspension •rear mud flap delete @arb4x4usa •rear diff breather @ss_offroad •washer fluid reservoir cover @laminxfilms •amber fog film @cali_raised_led •injection fob @tuffskinz •steering wheel carbon
    not suspension related but, did you plastidip your front valance? or did you go with truck bed liner spray...?
  18. Nov 10, 2020 at 12:37 PM
    Antman
    Antman New Member
    Anthony
    When you say entry level, do you have plans of upgrading again in the future? If so it may be better to spend once cry once now. Rather than later.
    for a budget lift I’d do Bilstein 6112’s in the front. Bilstein 5160’s in the rear along with icon 52700 rear springs. As well as spc UCA’s
    if you want to drop a little bit more I’d do Kings front and back. Icon 52700’s and spc ucas.
    to fit a 285/70/17 or larger you’ll need to trim your fender lining, a BMC and do your pinch weld.
    I’ve had both combos I listed above and there both good. However king>anything else.
    here is my vehicle on kings and 285/70/17.
  19. Nov 10, 2020 at 1:04 PM
    Mtbpsych
    Mtbpsych New Member
    BMC and pinch weld are not needed for 285’s depending on his wheel choice. I’m running 295’s and haven’t had much trouble with the pinch weld except for a few cases (should be remedied with adjusting caster).
    @ThePnsh3r i believe has no mods besides lift and UCA’s with his 285’s.
    SlvrSlug and Thatbassguy like this.
  20. Nov 10, 2020 at 3:33 PM
    Antman
    Antman New Member
    Anthony
    probably varies vehicle to vehicle. Mine rubbed, however i have -38 lol.
  21. Nov 10, 2020 at 3:51 PM
    Mtbpsych
    Mtbpsych New Member
    Yeah, -38mm offset will rub on almost a vehicles I’d say. I have them as well and there’s no way they’d fit properly without modifications.
  22. Nov 10, 2020 at 3:54 PM
    LA260
    LA260 New Member
    define entry-level
  23. Nov 10, 2020 at 5:20 PM
    ATrn
    ATrn New Member
    2018 4runner TRD Off Road
    I'm running a rough country 3" lift with 285/55 and surprisingly the rides not terrible.
    Thatbassguy and A&P like this.
  24. Nov 10, 2020 at 5:32 PM
    Antman
    Antman New Member
    Anthony
    burn it with fire. :bananadead:
  25. Nov 10, 2020 at 5:47 PM
    ATrn
    ATrn New Member
    Lol:laugh:
  26. Nov 10, 2020 at 5:49 PM
    ThePnsh3r
    ThePnsh3r New Member
    2020 TRDOP
    That is correct. I am running Ironman foam
    Cell pro stage 2 kit and had zero trimming to do when using BFG KO2s on stock TRD off road premium wheels.
  27. Nov 10, 2020 at 6:41 PM
    edgesalon
    edgesalon New Member
    Te
    18 FunRunner :-)
    may be he means low budget or not expensive
    If your going to do this just do it right the first time get all that you want out of your ride do not cheat your self look at your needs for suspension change what are you going to use it for and get what it needs good luck
  28. Nov 10, 2020 at 7:28 PM
    @Gabe 2017SR5 there is a lot of good feedback here on the Eibach kit. It's one of the most popular midrange options here.
    I am running 6112's in front at 2.3" and 5100's rear with Bilstein 1.5" lift springs. I am quite happy with this setup so far (I have about 15K miles on them). It rides well on the street, and has taken my level of off-roading abuse very well.
    34" tires will require a bit of work. Even with lift (which on it's own doesn't actually clear tires), you'll be rubbing.
  29. Nov 11, 2020 at 6:25 AM
    DEO runner
    DEO runner New Member
    4runner
    none yet
    i would suggest putting in a nice foundation that can be built on. Icon 2.5 coilovers up front and spc uppers and in the rear 2.0 icon shocks and springs. this is a great foundation for future upgrades. since the icon coilovers can be sent back to have reserviors added and even adjustable res added. really nice to be able to upgrade what you have already paided for. fox also offers this but only res to adjustable res.
  30. Nov 11, 2020 at 7:41 AM
    OP is asking about entry level shocks. Aside from that, I would avoid ICON due to known leakage issues.
    CowboyTaco and nimby like this.
