Best coolant
Discussion in '5th Gen 4Runners (2010-2024)' started by 1mulebarn, Sep 13, 2023.
  1. Sep 13, 2023 at 4:04 PM
    1mulebarn
    1mulebarn [OP] New Member
    Ben
    2023 SR5
    Looking for advice, appropriate/best coolant.
  2. Sep 13, 2023 at 4:12 PM
    Thats easy, stick with OEM.
    If it ain’t broke, don’t fix it.
  3. Sep 13, 2023 at 4:17 PM
    2021venture
    2021venture New Member
    Todd
    2021 Venture
    Stick with OEM if your doing a drain fill. If doing complete flush it's fine to use an aftermarket that meets specs. I don't like mixing incompatible fluids.
    1mulebarn[QUOTED][OP] likes this.
  4. Sep 13, 2023 at 4:19 PM
    2023_lunarrock-ORP
    2023_lunarrock-ORP Pistolero
    Brandon
    Pacific Northwest
    2023 lunar rock orp
    agreed OEM coolant is always the safest option. There is quite a few brands that make the Toyota red type coolant these days though.
    1mulebarn[OP] likes this.
  5. Sep 13, 2023 at 4:30 PM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    OEM all day, everyday.
  6. Sep 13, 2023 at 5:04 PM
    OEM or Zerex or any brand that's Asian vehicle compatible. I suggest premix so you don't have to and it's distilled water already which is what should be used to prevent buildup.
  7. Sep 13, 2023 at 5:10 PM
    TrueTexas
    TrueTexas New Member
    The Woodlands, TX
    OEM. Toyota Super Long Life Coolant. You just need to do routine drain and fills since I don't believe you drain the block. Haven't done mine as I only have 14k miles on it but recently did my daughter's 2016 Camry and it was just a drain and fill. My dealer charged me $18 / gallon for toyota oem. No reason not to use it.
    I also just got done flushing my daughters boyfriends coolant in his Nissan. 5 drains and fills to get it close to clear as someone put green coolant in at some point. Ridiculous waste of time because someone didn't bother getting the right coolant.
    1mulebarn[OP] and Slopemaster like this.
