Behind grille lights with TSS
Discussion in '5th Gen 4Runners (2010-2024)' started by Rabid Raccoon, Jan 10, 2020.
  1. Jan 10, 2020 at 5:47 PM
    Rabid Raccoon
    Rabid Raccoon [OP] New Member
    Pennsylvania
    2020 ORP
    Molle Style Window Panels LFD Crossbars 5100's all around (front set to .85) BAJA LP4'S behind the grille RCI Offroad full skids TRD exhaust TRD wheels All around LED replacements DD SS3 Fogs Some sweet decals AJT design key fob
    Any 2020's out there with round lights behing the grille? It seems like the only behind grille option with that TSS wall in the way. I have my brackets, just not sure which rounds to go with. Pics if you have them please.
    EvilBeagle and acet7 like this.
  2. Jan 10, 2020 at 6:05 PM
    bertom2000
    bertom2000 New Member
    I am looking also for light bar and behind grill bracket for a 2020 Toyota 4runner limited and haven't found any either. If anybody knows of anybody that makes them please let me know.
    acet7 likes this.
  3. Jan 10, 2020 at 6:12 PM
    Rabid Raccoon
    Pennsylvania
    2020 ORP
    Rago Fabrication makes the brackets. They are incredibly adjustable. But if you have the black square in your grille like I do, i don't think a light bar will work well. The middle will be completely blocked and it might throw light in weird directions in the engine bay
  4. Jan 10, 2020 at 6:26 PM
    bertom2000
    Thank you. Will check them out.
  5. Jan 12, 2020 at 7:22 AM
  6. Jan 12, 2020 at 7:52 AM
    Rabid Raccoon
    Pennsylvania
    2020 ORP
    nimby[QUOTED] likes this.
  7. Jan 12, 2020 at 7:58 AM
    MrBruns
    MrBruns New Member
    Matthew
    2020 T4R OR
    OME 3", 285/70/17 ko2s, RSG Sliders
    Yeah, I was thinking the same. Seen a 4r with these mounted behind the grill. Looked sharp. Didn't have the sensor but where they were mounting it wouldn't have been an issue.
  8. Jan 12, 2020 at 8:01 AM
    You sir have good taste :thumbsup:
  9. Jan 12, 2020 at 6:29 PM
    Rabid Raccoon
    Pennsylvania
    2020 ORP
    Thanks! I'll post pics afterwards
  10. Feb 11, 2020 at 9:10 AM
    MESHSOC
    MESHSOC New Member
    Michael
    2019 4Runner ORP
    This is exactly what I had in mind. You got any pics of this set up? I know it’s gonna look sick!!!
  11. Feb 11, 2020 at 9:11 AM
    Rabid Raccoon
    Pennsylvania
    2020 ORP
  12. Feb 11, 2020 at 9:12 AM
    Rabid Raccoon
    Pennsylvania
    2020 ORP
    Update.....the Rago bracket isn't that great. I went with NFAB
  13. Feb 11, 2020 at 10:02 AM
    siblue
    siblue Old member
    Ryan
    Socal
    24 Land Cruiser
    Updated pics with Nfab?
  14. Feb 11, 2020 at 10:02 AM
    Rabid Raccoon
    Pennsylvania
    2020 ORP
    That's what those pics are
    siblue[QUOTED] likes this.
  15. Feb 11, 2020 at 11:19 AM
    edgesalon
    edgesalon New Member
    Te
    18 FunRunner :-)
    thanks for the info that looks great i would like to do the same setup.
  16. Feb 11, 2020 at 12:18 PM
    showstoppersusa
    showstoppersusa New Member
    Branden
    Looks very good! :D
  17. Feb 11, 2020 at 7:10 PM
    RusPro17
    RusPro17 Back home again!!
    Don
    Pa.
    2023 TRD Pro Solar Octane
    SCS wheels and Westcott lift
    Speaking with Cali led bar I had this 32 inch bar in my Tacoma. Jake said it will still work in the 2020 4runner. But the issue I asked him and did not get a answer was the lower black piece that is below the safety sense will block out part of the section of the light which I think is about 6 inches. But I’m really looking at possibly if you take a router and router out the solid black pieces there it looks like it will not effect the safety sense since that is not connected to it. There is also another company that has 27 inch led bar to go about in the other section but the light is not as bright. If you look on Cali web site you can see the picture on the 2020 with the led bar installed. Not sure which way I will go. All I can tell you is when I had that bar in my Tacoma I loved it at night on the back roads especially when you have a lot of deer around you.
  18. Feb 11, 2020 at 7:12 PM
    RusPro17
    Don
    Pa.
    The link DRZoffroad for the 27 inch led bar for above the safety sense grille.
  19. Feb 27, 2020 at 7:51 AM
    Big B
    Big B Out Exploring
    Reno/Tahoe
    2020 TRDOR
    KINGS! w/ adjust Method Race Wheels, Good Year Ultra-terrains 285/70/r17, GOBI Rack, Baja-Designs/Cali-Raised LED Lights, SSO stealth front bumper, RSG Sliders, FACTOR 55 ultrahook Smitty Bilt x20 winch (syn.), TYT TH9800, X Bull Recovery Boards
    RR, does this nFab bracket allow for 2 lp6s to be mounted on each side of the sensor?(I want to do one yellow/white on each side)
  20. Feb 27, 2020 at 8:05 AM
    RusPro17
    Don
    Pa.
    Hey Rabid Raccoon, where you in Pa? I have all the same stuff in a invoice deciding to buy from Rago. I’m looking to do the same. Any install pics would help with hooking up the wiring. I plan on adding the push button inside the interior. How is the light output behind the grill? I’m going with the LP6’s
  21. Feb 27, 2020 at 8:07 AM
    RusPro17
    Don
    Pa.
    Also which bracket setup are you using? Rago said there’s will work.
  22. Feb 27, 2020 at 10:34 AM
    Rabid Raccoon
    Pennsylvania
    2020 ORP
    Hey Don, I'm in Hatboro. Don't use RAGO! Go with NFab. Trust me. I did both. There is no issue with the light output because of how bright the lights are. Mine are LP4's so the 6's will be even brighter. There really is no wiring to show. I used the LP6/LP9 heavy duty harness that Baja sells. It's totally plug and play.
  23. Feb 27, 2020 at 10:37 AM
    RusPro17
    Don
    Pa.
    Thank you. I will go with NFab if they are better. I sent you private message to discuss this so we don’t fill this all up.
  24. Mar 22, 2020 at 12:29 PM
    rpurkie
    rpurkie New Member
    Rob
    2020 4Runner Limited
    Hey guys, The bracket I see on Nfabs site is described a bumper mount. Did you mod their products?
    thanks
  25. Mar 22, 2020 at 2:20 PM
    RusPro17
    Don
    Pa.
    Hey Rob,
    Did not install mine yet. You need to pull the front bumper off. The NFab mount goes behind the bumper. I still did not order my bajadesigns lights.
    rpurkie likes this.
  26. Mar 22, 2020 at 3:06 PM
    Rabid Raccoon
    Pennsylvania
    2020 ORP
    Nope. Just bolts right on
    rpurkie[QUOTED] likes this.
  27. Sep 8, 2020 at 11:11 AM
    RAD_RNR
    RAD_RNR New Member
    Lucas
    2020 Venture Edition 4Runner
    Bilstein 2.5" Strut Kit 285/70/17R BFG K02 Spidertrax 1.25" Spacers RSG Metalworks Rock Sliders G.O.A.T Truck Armor Alpine Series Baja Designs S1 Ditch Lights with Cali Raised Low Pro Brackets
    Hey, did you connect the 2 wiring harnesses from each light together or are you just running the button switch for each one separately? Been dying to do this, and I’m glad I found this post
  28. Sep 8, 2020 at 11:44 AM
    RusPro17
    Don
    Pa.
    Hey Lucas, are you doing the LP4’s?
  29. Sep 8, 2020 at 12:00 PM
    RAD_RNR
    RAD_RNR New Member
    Lucas
    I was thinking LP6
  30. Sep 8, 2020 at 12:39 PM
    RusPro17
    Don
    Pa.
    I was planning on doing the 6’s but now I’m looking at a different route. I have the NFab mount. But mine is a Pro so I might being going with the 20 inch bajadesigns led bar. It will fit behind my grille up about the safety sense. But maybe I will add the LP4’s down the road.
    RAD_RNR likes this.
