Bed Lining Whole Body.. How Much?
Discussion in '2nd Gen 4Runners (1990-1995)' started by Erealia, Nov 28, 2016.
  1. Nov 28, 2016 at 10:12 AM
    Erealia
    Erealia [OP] New Member
    Kaitlynn
    1995 clean inside, ugly out, Red Runner
    Hi, I have an old 4runner that I love to death. Both heads were replaced a year ago, and she runs like a dream, but the outer body leaves a lot to be desired.
    It's mostly red with a black hood, and some of the red is more of a pink, as it's lost its clear-coat. It also has a large dent in the back panel that would cost tons to repair since it's all one piece, and would need repaired before a body shop would paint it. Since it has upwards of 240k miles on it I'm not wanting to put a few grand in it. When it dies I'll just get a third gen runner, so I'm not looking for input as to whether I should do it or not. I'll only be improving its look, I guarantee it. Yes it'll hold dirt, yes it'll weigh more than paint, yes it'll be dull. I just want to know from someone who has done it, how many gallons it took to cover the entire body, or if anyone has estimations.
    TL;DR: My truck is ugly and dented. I am going to put bed liner on the entire body. How much will I need to do the job, in gallons? 1995 Runner.
  2. Nov 29, 2016 at 7:45 AM
    UssMoGn
    UssMoGn That Vegas Dude
    1996 TaCoRunner
    Probably a gallon. I used little less to paint mine white. Only used i think 2 cans of Rustoleum truck bed liner to do the Stripe on the bottom. How ever you do it or whatever product you use, make sure you can spray it and go slow with many layers . You dont want to roll on bed liner unless you can lay everything flat.
  3. Nov 29, 2016 at 7:48 AM
    Erealia
    Kaitlynn
    Okay, thank you! Did you do white on top black in bottom? That's what I'd like to do. Does the roll-on drip?
  4. Nov 29, 2016 at 8:45 AM
    UssMoGn
    1996 TaCoRunner
    White is Rustoleum Paint. Bottom us Rustoleum truck bed liner. Roll on is hard to get to lay flat. Often you will roll on a vertical surface and it will run if your not careful. Most people use for there beds so they often dont care about drips or runs. But for side of a truck id assume you'd want it as flat as possible.
  5. Nov 29, 2016 at 8:51 AM
    UssMoGn
    1996 TaCoRunner
    Also you want to do some prep work, Might want to take some sand paper like 1000 Grit and rough up the clear coat(if there is any left) or take the clear completely off. Will help the truck bed liner stick better. You dont have to do this but it will help, Ive seen some truck bed liners get sprayed right on to clear coat and sticks.
    Also your dents on the rear can be pushed back out from the inside of the truck. Just use a hammer and 2x4.
  6. Nov 29, 2016 at 8:52 AM
    UssMoGn
    1996 TaCoRunner
    Oh and i did the whole truck white and sprayed the liner over the bottum. Check out my build page for pictures of step by step.
  7. Nov 30, 2016 at 10:32 AM
    Erealia
    Kaitlynn
    Oh, gotcha, it looks good! I like the Tacoma front end on yours. And yes I was planning on sanding everything to get it to stick better, if you put the liner on the bumpers would it stick or should I sand and or prime them? I couldn't find your progress pics..
    Would the dent trick still work if it has some rust on it? I haven't touched it because of that. I don't want to make holes.
  8. Nov 30, 2016 at 12:04 PM
    UssMoGn
    1996 TaCoRunner
    I put the liner right over the steel bumpers. Just made sure it was clean and oil free. The Truck bed liner will stick better then normal paint.
    Some rust might fall out... you can always use fiberglass or bondo to patch it. Not enough rust from what i can see that you couldn't tap it back out. Might be bend rust now but could be straight rust after...lol
  9. Nov 30, 2016 at 12:15 PM
    Erealia
    Kaitlynn
    Okay awesome I was hoping I could just
    put it right on them haha. And that's true, I could just patch it, I forget you can do that.
    Thanks so much for your help!
  10. Nov 30, 2016 at 12:29 PM
    UssMoGn
    1996 TaCoRunner
    NP, Keep us updated with pictures and make Her shine again!
  11. Nov 30, 2016 at 12:30 PM
    Erealia
    Kaitlynn
    Planning on it! I'll just be glad to not have to wax her every 3 months to make 'er all the same color
  12. Nov 30, 2016 at 2:15 PM
    Nicklovin
    Nicklovin Where Am I..
    Pedro the Precummer
    UssMoGn likes this.
  13. Nov 30, 2016 at 2:22 PM
    UssMoGn
    1996 TaCoRunner
    I looked at these. Cool stuff. I wanted to try it but Im a Rustoleum fan and it was easy to get too... FYI if you go with this there FAQ said
    Can Durabak™ be sprayed? Yes, with most conventional spray equipment but it requires a large tip (1/4") and should be thinned with Xylene approximately 10%
    So maybe something you want to look into.
    Also I like there main page has FJ40s on it :)
  14. Dec 1, 2016 at 10:03 AM
    Nicklovin
    Pedro the Precummer
    Oh rustoleum would definitely be easier. All depends what you want and how much effort you want to out into it really
  15. Mar 5, 2018 at 5:55 PM
    95_T4R_3VZE
    95_T4R_3VZE New Member
    BEN
    1995 Toyota 4Runner V6
    RAPTOR. LINER.
  16. Feb 8, 2023 at 4:17 PM
    Kaboomnash
    Kaboomnash One owner T4R
    1993 4Runner 4x4 3.0L 122K
    2.5" lift, Black Magic fan, Borla exhaust, Raptor Liner overspray,
    I purchased two liters of Raptor Liner black as a kit on Amazon with the spray gun to practice my techniques before over-spraying the entire truck. I removed and sprayed each component of the roof rack, rear air deflector and the front skid plate with the black liner. The items turned out great. I have also purchased 10 liters of tintable Raptor Liner (Amazon with the spray gun for $250) and a quart of PPG factory Pearl Garnet base tint ($121 at FinishMaster). It has been too cold in my shop to spray the red body, so while everything is removed from the roof, I lightly rolled the color matched Raptor Liner on the flat horizontal surface. On the roof I taped along the recessed body contour that runs the length above the doors to make the roll to spray transition less noticeable. This will protect the area under my roof rails and add some hail damage resistance. In preparation for the body and hood spray I have wiped down the entire surface with acetone to remove any wax before scuff sanding. I scuff sanded the entire red surface and wiped down again with acetone. When I spray the sides and hood, I will feather in the texture on the rolled area edges of the roof.
    I purchased this vehicle new thirty years ago, and this is a way to freshen it up for this awesome anniversary. It is not a show truck so this durable finish will be great.
  17. Feb 10, 2023 at 10:51 AM
    9MAJOR
    9MAJOR New Member
    2019 4Runner SR5 Premium
    Would this stick to a bug deflector if I sand it a little?
