Battery not charging
Discussion in '1st Gen 4Runners (1984-1989)' started by climbon, Jan 8, 2017.
  1. Jan 8, 2017 at 2:28 PM
    climbon
    climbon [OP] New Member
    Kenneth
    1988 4Runner
    30s
    Hi all. I am new to the forum. I have a 1988 4 cylinder 5 speed. It has about 250K on it and generally runs well although burns through a little oil. My main problem is the charge warning light has come on recently. The battery is definitely not getting sufficient charge. I pulled and fully charges the battery and fixed a loose negative terminal battery cable end (ground strap). I tested the output of the alternator with a multi-meter and it showed almost 14 volts. Can anybody help me get right to the problem or suggest a step by step procedure to resolve this? Thanks in advance! Ken
  2. Jan 8, 2017 at 5:30 PM
    climbon
    Kenneth
    1988 4Runner
    30s
    I have done some more searching and re-testing the voltage output. I can't find any faulty connections on the positive or negative side of alternator or battery. The output is actually 14.4volts which seems to be reasonable, although maybe toward the low end. I don't know if it could be a rectifier issue? Thoughts anyone?
  3. Jan 9, 2017 at 12:38 PM
    ajohnson
    ajohnson Glamorous
    Andy
    Charlotte, NC
    87 4Runner SAS and other stuffs, 07 Tacoma
    Things and stuff and such
    So you checked the positive link from the fuse box to the battery? They commonly break.
    climbon[OP] likes this.
  4. Jan 9, 2017 at 2:59 PM
    climbon
    Kenneth
    1988 4Runner
    30s
    I have not traced the positive link to the fuse box. I will after work tonight. Thanks!
    ajohnson likes this.
  5. Jan 14, 2017 at 4:09 PM
    TN_TRAIL
    TN_TRAIL New Member
    Noel
    2017 TRD OFF RD PREM
    oh the list....!
