Battery Drains
Discussion in '3rd Gen 4Runners (1996-2002)' started by dkm3033, Jun 6, 2023.
  1. Jun 6, 2023 at 12:16 PM
    dkm3033
    dkm3033 [OP] New Member
    2000 Silver 4Runner
    Just replaced an alternator and belt on my 2000 2.7L 4Runner for not starting. After replacing the alternator it started and seem to run while parked without an issue. The next day started it up and it ran for 5 minutes before it stopped. The battery was being drained again. Out of ideas. Does anyone have other areas in which to look?
    Thanks.
  2. Jun 6, 2023 at 12:37 PM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    I have to assume you have a new battery and didn't just replace alternator and belt first?
    If it started then died right after it may be a fuel issue? Once started it should keep running even with a dead battery.
  3. Jun 6, 2023 at 2:34 PM
    dkm3033
    2000 Silver 4Runner
    Yes, it's a new battery. It got drained after startup. I waited a few months before I changed the alternator and belt. I charged the battery with a jump for about half-hour 45 min. Then it started. I let it run for 5 min or so without the jump cables. I do have a battery indicator light on.
  4. Jun 6, 2023 at 2:51 PM
    Oakboro, N.C
    Have you had the "newer battery" load tested. There is possibility it could have a defect.
  5. Jun 6, 2023 at 3:50 PM
    Daddykool
    Are you sure the original alternator was bad? Assuming it’s a refurb, have you checked the brushes on the replacement?
  6. Jun 6, 2023 at 9:58 PM
    Get a multimeter and check for voltage drops across fuses and find the circuit that is the issue.
    Disconnect all non factory electronics. These are almost always the source.
    Don't just throw parts at it until you know.
