Baja design lights
Discussion in '5th Gen 4Runners (2010-2024)' started by Brother708, Aug 23, 2020.
  1. Aug 23, 2020 at 7:18 AM
    Brother708
    Brother708 [OP] New Member
    Austin
    Memphis
    2019 4Runner Off road premium
    *Kings Suspension* Gobi Rack*Shrockworks Bumpers & Sliders*ARB Compressor*Warn Winch* Baja Design lights*
    It looks like all of these come with a quick disconnect from the light to the harness. Is it a big issue if i cut that out and just hardwire to the harness?
  2. Aug 23, 2020 at 7:31 AM
    Agent_Outside
    Built 2011 T4R Limited
    No, but why?
  3. Aug 23, 2020 at 7:35 AM
    Brother708
    Austin
    Memphis
    Cut down in the bulkiness of the harness. I have 4 on front and 4 on back all wired into 1 main line to the power source.
  4. Aug 23, 2020 at 7:40 AM
    Agent_Outside
    You’d be better served to just cut, shorten, and resplice the harness to the length you want and keep the electrical connection so you can still remove them if you’re working on something or you have a warranty issue of something. It’s never ideal to install something in a way that you need to cut a wiring harness to remove a component.
  5. Aug 23, 2020 at 8:25 AM
    RusPro17
    RusPro17 Back home again!!
    Don
    Pa.
    2023 TRD Pro Solar Octane
    SCS wheels and Westcott lift
    Just curious which Baja lights are installing? I plan on doing the LP4’s or S8’s . I ordered a push button switch to wire up with my Baja lights.
