Backwards windshield washer fluid
Discussion in '5th Gen 4Runners (2010-2024)' started by 4RunningAway84, Feb 8, 2024.
  1. Feb 8, 2024 at 12:52 PM
    4RunningAway84
    4RunningAway84 [OP] New Member
    2016 4Runner sr5 premium
    I have a 2016 4Runner that I just bought & everytime I pull back the lever for the windshield washer fluid it sprays out the back. Every time I twist the knob on the lever for what should be the rear washer fluid, it comes out the front. They are completely backwards! Anyone else ever have this happen & if so, how did you fix it?!
  2. Feb 8, 2024 at 1:10 PM
    Too Stroked
    Too Stroked New Member
    Tom
    South shore of Lake Ontario
    2021 SR5 Premium
    Sounds like somebody replaced the control stalk and got the wiring reversed. Or maybe they used a cheap aftermarket part that's wired wrong internally.
    Rocko9999 likes this.
  3. Feb 8, 2024 at 1:56 PM
    BS67 New Member
    My wife tells me I was put together backwards...........my feet smell.........and, my nose runs!
    whippersnapper02 and steelevo like this.
  4. Feb 8, 2024 at 2:32 PM
    steelevo
    Utah
    Could also be the washer fluid pump was replaced and wired incorrectly or the hoses were installed in the wrong ports.
  5. Feb 8, 2024 at 2:50 PM
    My vote is there was work done on the washer fluid reservoir and the pumps' wiring got switched. Unless that's not possible.
    4RunningAway84[OP] and Rocko9999 like this.
  6. Feb 8, 2024 at 2:57 PM
    I'm sure this isn't the case, but it wouldn't surprise me if it was wired wrong from the factory. I mean, just look at the steering wheel controls! Right is vol up, Left is vol down...
  7. Feb 8, 2024 at 3:17 PM
    Glenn Goodlett
    Glenn Goodlett New Member
    Glenn
    2020 TRD Pro
    Paid for
    My bet would be two clear tubes are reversed on the pumps on the reservoir.
  8. Feb 8, 2024 at 5:25 PM
    Swap the tubes around.
  9. Feb 8, 2024 at 7:04 PM
    Oakboro, N.C
    Second on the tubes swapped,any history of accidents on your 4Runner?
  10. Feb 8, 2024 at 7:59 PM
    Or that.
  11. Feb 9, 2024 at 7:52 AM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    Is the pump easy to access?
  12. Feb 9, 2024 at 4:34 PM
    4RunningAway84
    @RumHamRunner73 Clean carfax so I don’t think it was in any accidents. Def seems like it would be as simple as tubes being switched but I know zero about cars lol
  13. Feb 9, 2024 at 5:54 PM
    alittleoff
    alittleoff New Member
    Steve
    406
    '16 TP
    It sounds like the rotary and pull back lever/stalk are working correctly. And the pumps are also working.
    I'd bet that the tubes for the fluid are just on the incorrect pump.
    If you're located in Western Montana, I could help you correct this.
  14. Feb 9, 2024 at 8:56 PM
    Ding! Ding! Ding!
    Sounds like a pump replacement error.
  15. Feb 10, 2024 at 9:03 AM
    Everyone here's trying to help, but we're not getting much feedback. Where are you located, in case someone in your area could swing by and try to help you out? Also, do you feel up to looking under the hood and attempting to swap the hoses, or do you know of anyone that might be willing to help you do this? It sounds like a simple solution, but I know you mentioned you are not too car savvy...
    alittleoff and steelevo like this.
  16. Feb 10, 2024 at 10:55 AM
    steelevo
    Utah
    Agree with this. I’m in Utah and always happy to help.
