Auto headlights
Discussion in '5th Gen 4Runners (2010-2024)' started by Luvrv8, Feb 26, 2023.
  1. Feb 26, 2023 at 8:31 PM
    Luvrv8
    Luvrv8 [OP] New Member
    2021 4Runner
    So our new to us ‘21 SR5 doesn’t have auto headlights. I know on my past Tundras I was able to replace the turn signal stalk with one from a limited, add a light sensor and it worked (works on Tundras if the screen has the adjustments). Has anyone done this in a 4Runner or know if it would work?
  2. Feb 26, 2023 at 8:57 PM
    Silversr5
    Silversr5 New Member
    @Luvrv8 Do you have the part number for the turn signal stalk with the auto function?
  3. Feb 26, 2023 at 9:11 PM
    Luvrv8
    2021 4Runner
    Not at the moment. I’ve found a post where 2 part numbers were listed but haven’t looked at them. Also, I reading that possibly a wiring harness (on couple wires) might be missing from the body control module.
  4. Feb 26, 2023 at 9:13 PM
    Is this thread about the dimming dash display, or a switch that allows your headlights to come on automatically as daylight fades?
  5. Feb 27, 2023 at 5:24 AM
    LuLu
    LuLu New Member
    Utopia
    2022 TRD Sport
    2022/2023 works differently. I have tested these.
    Mod not needed on 2022/2023.
    Not sure about 2021
    kmeeg[QUOTED] likes this.
  6. Mar 6, 2023 at 5:50 PM
    Willmo272
    Willmo272 Member
    William
    2021 4Runner SR5 Premium
    Not exactly the same topic as this thread, but has anyone else noticed their auto high beams not working very well? I constantly find them turning on at the wrong time and blinding the person in the oncoming lane, this might just be because of the fact that I live in an area with many hills and the position of the sensor isn't set up for it.
  7. Mar 6, 2023 at 6:25 PM
    I’ve only tried it a few times but I was impressed by how well it seemed to work.
    Willmo272[QUOTED] likes this.
  8. Mar 6, 2023 at 6:40 PM
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
    Can't help out with this exactly but I just run my headlights on all the time. They turn off automatically after x amount of time or you can hit lock button twice to turn them off (at least with 2019).
    I do have to manually turn the wheel up/down between day/night and the over dash clock is always dim, but works good enough for me
  9. Jul 20, 2023 at 1:29 PM
    HyperWaveRNR
    HyperWaveRNR New Member
    What do you mean by this? My 23 has the dummy light sensor, and I just ordered https://www.amazon.com/dp/B0B73ZPNFH. Is it not going to work? OR do you mean I just add this and head light switch 84140-35171 and have fully functional auto headlights?
  10. Jul 20, 2023 at 1:36 PM
    LuLu
    LuLu New Member
    Utopia
    2022 TRD Sport
    Its not compatible with newer models.
    Check with Toyota Parts
    Dash dimming Functionality is built in. I have tested it out.
    The sensor has nothing to do with 'auto headlights'
    Its for dimming the Dash
  11. Jul 20, 2023 at 2:39 PM
    Texas4Runner
    Texas4Runner New Member
    Dallas/Fort Worth Texas
    2023 4Runner ORP+ CSM and Ice Cap
    This part is just for the HID and light cluster on dash.
    Looks like that part number has been replaced with
    AMBIENT LIGHT SENSOR - TOYOTA (89121-0E060)
  12. Jul 20, 2023 at 3:12 PM
    ReRunner
    ReRunner Fred Berry Enthusiast
    2022 MGM ORP
    HyperWaveRNR likes this.
  13. Jul 20, 2023 at 8:12 PM
    HBJ32
    HBJ32 New Member
    Anyone try and add the auto headlights from the trd pro to other models? Thought you needed an ecu module along with sensor and stalk
  14. Jul 21, 2023 at 8:25 AM
    Texas4Runner
    When did you order and who from on Ebay would be greatly appreciated? Did you have to pay any addition fees such as import and duty fees?
    Thank you!
  15. Jul 21, 2023 at 2:06 PM
    ReRunner
    2022 MGM ORP
    In March. The seller was jpanime2014. I also got my FJ Transmission knob from them last year. Just checking, they currently have one sensor left for $50 including shipping. No extra fees as I suspect they are a import warehouser.
  16. Jul 21, 2023 at 3:00 PM
    Texas4Runner
    That's who I ordered from. Price was $42 plus $8 shipping and $4.13 tax total $54.13. Thanks
  17. Jul 21, 2023 at 3:08 PM
    ReRunner
    2022 MGM ORP
    @Texas4Runner
    No problem. Be sure and use a zip tie between the wires to avoid losing the wire behind the dash. I believe @kmeeg has a video about this.
    kmeeg likes this.
  18. Jul 21, 2023 at 3:14 PM
    Sadly, As far as I've heard the sensor I used not work for 2020+. Older sensor is pretty cheap though.
  19. Jul 21, 2023 at 3:35 PM
    ReRunner
    2022 MGM ORP
    @kmeeg
    Yeah and I just rewatched your video where you went all gangsta and didn't bother with the zip tie. My bad. I used the zip tie method because this is the exact easy thing to do that I seemingly always mess up. haha.
    kmeeg likes this.
  20. Jul 21, 2023 at 3:39 PM
    Texas4Runner
    The model I used is compatible (#89121-30020 OEM) to work in 2022 and 2023's not sure about 2021. There is a new part number that replaces #89121-30020 which is #89121-0E060. I called Toyota dealership parts and they verified they are the same part.
  21. Jul 21, 2023 at 3:43 PM
    Texas4Runner
    Do you have link to his video...I'd like to watch it. Thanks
  22. Jul 21, 2023 at 3:46 PM
    ReRunner
    2022 MGM ORP
  23. Jul 21, 2023 at 4:00 PM
    ReRunner
    2022 MGM ORP
    @Texas4Runner
    What I did is slide a zip tie between the wires under the base of the sensor's plug. That way you can release it without it falling back through the dash. Snap the sensor into the plug, remove the zip tie, and push it back in the dash. Will be a bit more snug than the blank, so ensure it seats properly.
    And for anyone else. The replacement part# 89121-0E060 is over $100. Don't waste your money and find the old #89121-30020 for your '20 & up. Still plenty of inventory around. Not sure about the '19s and earlier availability of #89121-50020.
    kmeeg likes this.
  24. Jul 21, 2023 at 4:04 PM
  25. Jul 22, 2023 at 10:24 AM
    HyperWaveRNR
    I Just got mine in today and it worked beautifully. I have a 23 SR5P, and I purchased part # 89121-30020 off Amazon.
  26. Oct 30, 2023 at 8:00 AM
    trail_runner_93
    trail_runner_93 New Member
    South Central PA
    Has anyone tried installing this: Multi-Function Switch - Toyota (84140-35171) on a 2023 SR5P to have Auto Headlights? I already did the sensor install and that got me the auto dimming of the dash with the headlights on - wondering if swapping the light control stalk will get me auto headlights?
  27. Oct 30, 2023 at 8:36 AM
    This is what you want. I just installed it in my SloRunner:
    https://www.amazon.com/dp/B0B73ZPNFH?ref=ppx_yo2ov_dt_b_product_details
    trail_runner_93 likes this.
  28. Oct 30, 2023 at 8:51 AM
    HuskyMike
    HuskyMike New Member
    I've been tempted to try this. I read somewhere that it was tried on a Tacoma (or Tundra) and it didn't work. I'd have to look at a wiring diagram before I ordered the part. Even a detailed image of the part would be helpful to see if it has the same connectors.
  29. Oct 30, 2023 at 9:08 AM
    trail_runner_93
    South Central PA
    Yes - I did just put that in to get the auto dimming of the dash and it works great. I am now trying to figure out if there is a simple/cheap way to get auto headlights.
  30. Oct 30, 2023 at 9:11 AM
    You can't. I know you can't do it cheap, and I'm kind of sure you can't do it at all. You'd have to replace the stalk coming off the steering column.
