Auto Climate Control. 3 mins to turn on
Discussion in '5th Gen 4Runners (2010-2024)' started by wakegolf33, Mar 23, 2023.
  1. Mar 23, 2023 at 8:07 PM
    wakegolf33
    wakegolf33 [OP] New Member
    Ryan
    2018 4Runner Limited
    I recently noticed that when I’m in AUTO for climate control it takes three minutes to start up. Meaning it will be set to 75. 50 degrees outside and the fan will be at zero speed. Obviously colder than 75 so the fan should be running. After three minutes a relay clicks and the fan starts. At speed one. A minute or so later it goes up to 2. Another minute three. It takes about 10 minutes for the auto mode to actually start trying to attempt at changing the temperature.
  2. Mar 23, 2023 at 8:17 PM
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    It’s always been like that to me. if I press auto on a cold morning the fan is going to be at the lowest and directed towards the feet. After a few minutes, when the air coming out is actually warmer, the fan will get higher and eventually be directed to the face
  3. Mar 23, 2023 at 8:19 PM
    wakegolf33
    Ryan
    The fan is at 0 for three minutes with nothing be blown out at the feet? Is it waiting for the heating elements to warm up before it blows air over them or something?
  4. Mar 23, 2023 at 9:50 PM
    5six
    5six New Member
    55_4Runner
    GTA, Ontario, Canada
    2022 Black TRD ORP
    I’m assuming this is being noted as an issue when the engine temp is indicated as being warm and not cold?
  5. Mar 23, 2023 at 9:51 PM
    wakegolf33
    Ryan
    Cold start after sitting for hours or overnight.
  6. Mar 23, 2023 at 9:58 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    This is a feature not a bug. It's so you're not blasted with cold air while the engine is heating up to provide warm air to the cabin via the auto climate system.
    DogoPilot and Toy4X4 like this.
  7. Mar 23, 2023 at 10:27 PM
    4oreigner
    4oreigner New Member
    2019 4Runner Limited
    Yep, my 2014 Ford Exploder does the same when set to auto.
    I never thought it was a timed thing but rather the system monitoring engine/coolant temps and engaging the heater when the source is able to minimally emit heat. It makes sense to not blast cold air throughout the cabin before trying to warm it.
  8. Mar 24, 2023 at 3:07 AM
    There are no heating elements. Coolant flows through the heater core, which is why it can't provide any heat until the engine warms up.
    PVT Pablo, DogoPilot and Toy4X4 like this.
  9. Mar 24, 2023 at 6:24 AM
    DogoPilot
    DogoPilot New Member
    St. Paul, MN
    2022 Black ORP w/KDSS
    That's how my 2000 Audi worked (only starts blowing after it has some warm air to blow), so I'm guessing that's what yours is doing.
  10. Mar 24, 2023 at 7:03 AM
    sympley76
    sympley76 New Member
    2021 4Runner Limited
    Mine does it as well. What I don't like about it is, if I get into very cold car(winter) all the windows fog up really fast as there is 0 air movement.
