Audio Upgrade
Discussion in '5th Gen 4Runners (2010-2024)' started by GRAYHAWKGLEN, Aug 27, 2023.
  1. Aug 27, 2023 at 8:46 AM
    GRAYHAWKGLEN
    GRAYHAWKGLEN [OP] New Member
    Glen
    2023 Off Road Premium
    Lift, wheels, exhaust and lighting.
    As we know, 4Runner audio lacks. Im in a brand new truck, and have no interest in doing anything or having anything done behind the dash to the head unit.
    Wondering if there are any popular solutions to enhance the audio while using my ORP stock stereo. A patch in amp with a set of better speakers?
    Thanks for any input. I know that there is a lot of experience here.
  2. Aug 27, 2023 at 8:54 AM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    Swap out all speakers to Infinity Ref. They will run through the OEM headunit. Get harness and adaptors and it's plug and play. And while you have the door panels off, add some sound deadening.
  3. Aug 27, 2023 at 9:07 AM
    OEM Audio + makes a full plug n play system or just the drivers for the Runner. You can add some Infinity 3.5” dash speakers with a bracket or mod the OEM ones or Trailgrid (not cartrim) sells Kicker replacement drivers. It all depends on how much you want to spend.
    waldo98 and Steely123 like this.
  4. Aug 27, 2023 at 11:24 AM
    This ^^^^^^
    1BAMF likes this.
  5. Aug 27, 2023 at 11:35 AM
    Tama1968
    Tama1968 New Member
    Florida
    T4R SR5 in Classic Silver
    I swapped the dashes for a set of Infinity reference tweeters, and put some Rockford Fosgate 6"s in the lift gait along with about 5 lbs of dynamat. that by itself made a huge difference
    MinaCon likes this.
  6. Aug 27, 2023 at 11:36 AM
    I was about to go this route before my TRD ORP was in a crash and no more have it. Else I would have done it. $400 labor is very reasonable imo for a full kit (speakers, amplifiers, subwoofer, etc..) and I love the fact OEM Audio customer service coordinate with their recommended installer. (So if anything goes wrong I'm not the one picked the installer).
    Below is a screen capture of the email and I hide my information and OEM Audio person info for privacy.
  7. Aug 27, 2023 at 11:37 AM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    Without replacing your head unit you will only get mediocre results (audio is only as good as its weakest component). Just a speaker upgrade wont do much but it is the cheapest way to "upgrade".
    That said there are some aftermarket kit "upgrades" people like. Anything is better than stock, but it will cost you ether way. I went all out, Kenwood head unit, 6 channel amp, separate components... Sounds amazing.
    MinaCon likes this.
  8. Aug 27, 2023 at 11:51 AM
    I could be wrong since I didn't do it personally, but I have a feeling that our stock made in Japan Panasonic headunit should not be that bad for a full Amp + matching speaker and subwoofer upgrade.
  9. Aug 27, 2023 at 11:53 AM
    Ripper238
    2019 TRD OR
    The key is the line out/low level so it can be amplified properly with little noise/distortion. An aftermarket head unit with low level outputs like Panasonic is fine.
    kmeeg[QUOTED] likes this.
  10. Aug 27, 2023 at 11:58 AM
    Twice their customer service has been really good for me. The first time their amp was dead so they had me head over since I’m local and installed the sub voltage knob where I wanted it and fixed the amp. Then the second time I had ordered the second sub but they had changed the wiring. I went to their new location and the owner himself put together a custom harness for it to work with my “older” system.
    I did the installation myself. It wasn’t too bad except bending your arm unnaturally behind the dash. There’s more room for my fat arm in there than I thought.
    MinaCon and kmeeg[QUOTED] like this.
  11. Aug 27, 2023 at 9:52 PM
    Nevin
    Nevin New Member
    Puyallup, WA.
    2022 TRD ORP
    PPF, Tint, Black out badges/Valances. Bilstein 6112's & 5100's
  12. Aug 27, 2023 at 10:02 PM
    waldo98
    waldo98 New Member
    Walter
    SoCalli
    2023 ORP Nautical Blue Metallic
    I've been pretty happy with the OEM+ audio speaker only upgrade and sound deadening on the doors, rear hatch and trunk floor. There are numerous installation videos out there if you are handy with your hands and have the time for it.
  13. Aug 29, 2023 at 6:19 AM
    sympley76
    sympley76 New Member
    2021 4Runner Limited
  14. Aug 29, 2023 at 8:23 PM
    Nevin
    Nevin New Member
    Puyallup, WA.
    2022 TRD ORP
    I do not have experience with sound quality on this particular system. Just another plug and play option.
  15. Aug 30, 2023 at 4:41 AM
    MO4RUNNIN
    MO4RUNNIN New Member
    Jason
    White, lifted.
    I purchased the Kicker 8 speaker plug and play. The instructional videos and plug and play adapters that are included in the kit make for a very easy install. I upgraded from just the factory paper cone speakers and not the JBL system, so mine was a very noticeable sound improvement over the factory speakers. I also upgraded the head unit. I agree with previous posts on sound quality with upgrading the factory components. The sound from the speakers will better improve with an upgraded head unit. If you really want an improved system, you’ll want to do an amplified system. Good luck with your upgrades!
  16. Aug 30, 2023 at 4:55 AM
    rphillips66
    rphillips66 New Member
    Allen
    Charleston SC/ Gastonia NC
    2017 SR5 Premium
    I waited a year and a half to upgrade the sound system in my truck. I went with the Sony floating head unit and 1 500 watt amp for rear channel and 1 700 watt amp for the front of the vehicle. I threw away the stock speakers and replaced with Hertz component speakers and threw in a JL Audio sub. I can make the mirrors rattle. Amazing clean sound! It was not cheap but well worth it!
  17. Aug 30, 2023 at 6:10 AM
    broken-giver
    broken-giver BFD
    I am surprised so many people think audio system sucks. I find it perfectly adequate. I swear its better than my 2015 honda pilot. I mostly listen to podcasts or audiobooks so I guess I don't really care for nicer sound system because it won't make a huge difference to me.
    In fact that is how I'd describe 5G: perfectly adequate :D
  18. Oct 15, 2023 at 6:54 PM
    regius123
    regius123 New Member
    Reginald
    2023 TRD ORP white
    Tri-color retro body decal; OME BP-51 front coilover; OME Nitrocharger Sport rear (stock height); TRD Pro bronze wheels, TRD skid plate.
    I need some advice on fitment brackets to buy from Crutchfield. I’ve experienced the OEM Audio Plus, the fitment is indeed bolt on and no issues, sound is slightly better so I want to do it differently this time. I could go for the Kicker bolt on set, but their YouTube videos always reveal that the rear door speaker screws are too long, and they end up drilling holes to the doors (NEVER do that! Rust from inside out waiting to happen). Why not just cut the screws shorter????!? Now, it’s seems that the screws Crutchfield provided are also longer… now the question is, can I cut the screws? Also I read about I have to buy the Metra brackets and not the default bracket… having to modify the bracket is not an issue with me as long as I don’t have to drill into sheet metal. So I guess I need some coherent and holistic advice. Thanks!
  19. Oct 15, 2023 at 7:09 PM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    SlvrSlug likes this.
  20. Oct 15, 2023 at 7:49 PM
    Nevin[QUOTED] and regius123 like this.
  21. Oct 15, 2023 at 7:59 PM
    regius123
    Reginald
    2023 TRD ORP white
    This is the set that come with a long screw that you have to cut.
  22. Oct 15, 2023 at 8:02 PM
    Thanks.
    Never in my life did I think I'd want a shorter screw!
    Flit04 and 1BAMF like this.
  23. Oct 15, 2023 at 8:06 PM
    regius123
    Reginald
    2023 TRD ORP white
    Instead of buying a set like the Kicker or OEM
    Plus, I decided to do it a La cart. I bought the Subraru kicker tweeters just now, then I may research some co-axial door speakers from Crutchfield. The key is bracket and right screw, which I think I got the answer now thanks @Lc200
  24. Oct 15, 2023 at 8:25 PM
    Nevin
    Nevin New Member
    Puyallup, WA.
    2022 TRD ORP
    Cut the hardware that's provided in the kit or do you cut the factory screws?
  25. Oct 15, 2023 at 8:28 PM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    Forget the Subaru tweeter. It's still a tweeter and really not an improvement. Get Infinity Ref or JBL 3.5 inch for the dash. With a little diy, it fits. Add the capacitor and that would change the whole audio quality up front.
    For the front doors look at 6x9. Infinity JBl, kicker JL etc. Keep an eye on sensitivity if you running them off the OEM head unit. Anything below 90db and the HU will be too under powered.
    Swap the rears for any 6.5. Of course same brand speakers to maintain cohesiveness.
    They are all plug and play with the right speaker harness.
    While swapping the speakers, add sound deadening to the doors.
  26. Oct 16, 2023 at 4:48 AM
    regius123
    Reginald
    2023 TRD ORP white
    Thanks! I noticed your truck is a pre-face lift, the 2023 non-JBL HU is quite powerful to me, there a lot of loudness with stock.
  27. Oct 16, 2023 at 6:16 AM
    kojak
    kojak New Member
    21 SR5P 4x4
    The non-JBL head unit is heavily tuned to the flimsy stock speakers and the car; this becomes an issue once you start adding amps and subs.
    This is solid advice, I'd strongly suggest a low pass filter for the door speaker though. Has anyone tried using a coax with clipped tweeter wires?
  28. Oct 16, 2023 at 7:15 AM
    backpacker
    backpacker New Member
    2023 TRD ORP
    Yeah, the only thing that really bothers me about the stock ORP is how boomy it is in the lower mid-range. I wish I could save some EQ presets or something.
    regius123[QUOTED] likes this.
  29. Oct 16, 2023 at 8:00 AM
    jasonmcelroy
    Jason
    San Jose, CA
    2021 Grey Trail
    The three-band tone controls in the stock HU have a really weird range and curve. Practically useless for making it sound better in my opinion.
    But otherwise, I'd love to be able to have a few good EQ curves at hand to switch between.
    Jason
  30. Oct 16, 2023 at 8:03 AM
    backpacker
    2023 TRD ORP
    That's how it seemed to me as well. I tried a few adjustments and didn't feel like they helped much. I wish I could get at the firmware.
    Number16 likes this.
