Ass sag during acceleration
Discussion in '5th Gen 4Runners (2010-2024)' started by Daytonaviolet, Mar 10, 2021.
  1. Mar 10, 2021 at 6:54 PM
    Daytonaviolet
    Daytonaviolet [OP] TRD Bro
    Bay Area, CA
    Blizzard Pearl TRD Bro
    I’m having this strange issue where the front of the truck seems to get higher and the rear seems to get lower during acceleration. I see my headlights pointing higher during acceleration at night.
    i have kings 600lb spring rate fronts set to 3.5” lift and unknown spring rate icons (158506) 2” lift on the rears.
    im thinking the sag may be related to the icon springs. Perhaps the spring rate is too soft ? I’m thinking of switching to icon (52700). This seems to be the standard for icon 2” rear springs.
    Any thoughts or recommendations will be appreciated.
  2. Mar 10, 2021 at 7:06 PM
    NABeast
    NABeast New Member
    Paul
    2016 QS Pro
    I am new to the 4runner family, i have been driving tacomas for years and i was beginning to think this was a characteristic of the shorter wheelbase. Mine is lifted, I’m running toytec 2” standard weight coils in the rear, and spacers with the trd coilovers in the front. I am already panning a real front setup with UCSs, but was wondering if the rear springs were too soft and causing this feeling.
  3. Mar 10, 2021 at 7:38 PM
    Are you hauling a lot of weight regularly?
    I have Bilstein +400# coils and no such sag.
    Being Icon, I wouldn't be surprised if the coils sprung a leak. :laughing:
  4. Mar 10, 2021 at 7:56 PM
    Agent_Outside
    Built 2011 T4R Limited
    That’s what happens when you eliminate all the rack from the suspension...
    Daytonaviolet[OP] likes this.
  5. Mar 10, 2021 at 8:31 PM
    Daytonaviolet
    Bay Area, CA
    I have gobi rack, sliders and ladder. Nothing else heavy on the truck.
  6. Mar 10, 2021 at 8:32 PM
    Daytonaviolet
    Bay Area, CA
    so by leveling the truck .. this will cause the rear to sag during acceleration? Perhaps I can drop the front to 3” instead of 3.5”
  7. Mar 10, 2021 at 9:51 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    I would second the rake thing. It's apples to oranges but a lot of drag cars and bikes have a significant rake in order to combat this. I kept the factory rake for aero (MPG's) and I don't notice the front end coming up on acceleration.
    jgcaps and Daytonaviolet[OP] like this.
  8. Mar 10, 2021 at 11:43 PM
    Daytonaviolet
    Bay Area, CA
    Yeah the rake thing make sense. But before I had the kings I had the trd pro Bilsteins w/Cornfed spacers. I was also leveled. But seems I have more sag during acceleration now with the kings/icons the Bilsteins. Both setups were both leveled. Other difference is
    Bilsteins 23.25f/23.5r
    Kings 23.5/24r
    here’s the trd pro Bilsteins
  9. Mar 11, 2021 at 3:11 AM
    Between the rack, ladder, and sliders, that's probably over 100# constant weight on the rear springs. If you're using springs designed for standard load, they might be a tad weak for your setup.
    Also, it could be due to the Bilsteins having been digressive valved versus the Kings being Progressive. Progressive shocks will initially feel softer, so they may allow a bit more sag and roll than a digressive shock. This is just a guess, though
  10. Mar 11, 2021 at 3:52 AM
    MI-FL off roader
    Brett
    Merritt Island, FL
    03' SR5 Sport - 12' Limited
    Those #600 springs in the front are new aren't they? They might settle a bit in the next few months. As @Thatbassguy pointed out, your rear springs might be a little under rated.
  11. Mar 11, 2021 at 7:29 AM
    Daytonaviolet
    Bay Area, CA
    I didn’t realize digressive vs progressive made that much sag difference
  12. Mar 11, 2021 at 7:44 AM
    Daytonaviolet
    Bay Area, CA
    Actually my kit came with 550 fronts and found used set of 600 and the rear icons 2” on IG. I wanted to try 600 first as I found a local set cheap.
    my plan was to perhaps change to 650 once low pro winch is installed. So front and rear springs are already settled in.
    i question. What’s the difference between 2” icon 158506 vs 52700. All the icon kits stages 1 thru 7 use 52700 as the rear 2” lift.
    im wondering if 158506 is a softer rear spring but same height ? They look so different.
    158506 (stock vs icon)
    Icon 52700
  13. Mar 11, 2021 at 7:45 AM
    I could be wrong. Don't ever discount the possibility that I am wrong. :D
    I have read that progressive shocks can feel mushy, depending on the valving.
  14. Mar 11, 2021 at 9:00 AM
    koukimonster
    koukimonster DYNO4
    Appalachia
    Midnight Venture
    It's a combination of changing the suspension geometry from stock (leveled it out) which affects it's dynamic characteristics, as well as the change from digressive Bilsteins to progressive KINGS. Just like in side to side handling (body roll), the digressive Bilstein pistons resisted the front to back lean (body pitch) under acceleration and braking more, at least initially and under smaller loads, than the KINGS will. Personally, some pitch and roll is exactly what I'd want from a 3.5" lift.. feels more like a jacked up trophy truck that way, no? Isn't that the look / experience you're gong for?
  15. Mar 11, 2021 at 10:49 AM
    Daytonaviolet
    Bay Area, CA
    I’m just trying to see if the sag can be improved. I don’t have confidence with my current rear icon springs 158506 as I can’t find much info on them. Also seems that the 52700 is the 2” the rear spring icon recommends.
    koukimonster[QUOTED] likes this.
  16. Mar 11, 2021 at 11:18 AM
    newlife
    Knoxville TN
    2021 venture 22 JTR
    All of them.
    Just touching on this since I had the same issue until today. I had front set at 2.5” and rear with icon 2” standard load rear springs. When I’d accelerate the ass would drop enough I could see my headlights come up and right into the rear view mirror of the person in front of me (cars). I had ome heavys installed in anticipation of the rear bumper and now the acceleration sag is gone. At least I can’t feel it like before. This was also happening since the day I installed the icons.
  17. Mar 11, 2021 at 11:20 AM
    Daytonaviolet
    Bay Area, CA
    Which icon springs did you have ? Which ome did you get ?
  18. Mar 11, 2021 at 11:28 AM
    newlife
    Knoxville TN
    2021 venture 22 JTR
    All of them.
    Icon 2” standard load
    And ome
  19. Mar 11, 2021 at 11:30 AM
    Daytonaviolet
    Bay Area, CA
    Ohh ,, those are heavy load springs. You want to sell me your icon 52700 :yes:
  20. Mar 11, 2021 at 11:30 AM
    newlife
    Knoxville TN
    2021 venture 22 JTR
    All of them.
    Also I know the first pic is going to be crappy. But here is a side by side comparison of configuration.
    keep in mind in these pics I have dobinsons drawers in the rear but the issue happened even before the drawers.
  21. Mar 11, 2021 at 11:32 AM
    newlife
    Knoxville TN
    2021 venture 22 JTR
    All of them.
    I gave them to a kid at the shop that helped with the install.
  22. Mar 11, 2021 at 11:50 AM
    Daytonaviolet
    Bay Area, CA
    If I has as much weight as you, I would consider stiffer 2.5-3” springs ..
    thanks
    newlife[QUOTED] likes this.
  23. Mar 11, 2021 at 11:52 AM
    koukimonster
    koukimonster DYNO4
    Appalachia
    Midnight Venture
    Daytona, lots of taller spring options for the rears, if you aren't set on ICON. OME 895e, Dobinsons, and a "heavy load" Bilstein all come to mind. Also I think Wheeler's T12?
  24. Mar 11, 2021 at 12:22 PM
    Daytonaviolet
    Bay Area, CA
    Yes .. I just didn’t want buy another 2” set without asking the experts :spending:
