Are you using 100% synthetic oil?
Discussion in 'General 4Runner Talk' started by SlvrSlug, Jun 28, 2024.
  1. Jun 28, 2024 at 3:48 PM
    SlvrSlug [OP] Slightly bent.
  2. Jun 28, 2024 at 4:20 PM
    Acesandeights
    Acesandeights #34
    So Oregon
    2024 ORP
    For those of us without Internet, what's it say?
    icebear and djwantke like this.
  3. Jun 28, 2024 at 4:48 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
  4. Jun 28, 2024 at 5:18 PM
    Tama1968
    Tama1968 New Member
    Florida
    T4R SR5 in Classic Silver
    people overthink this stuff. I'm for evidence-based practice. my resident petroleum engineer buys synthetic (or whatever this mechanic says it is) off the shelf, changes every 7-10k or so and his cars go forever. Thus far, mine have done pretty well too. On to the next dumpster fire.
    icebear and TrailSpecial22 like this.
  5. Jun 28, 2024 at 5:20 PM
    Sounds like I'm good since I'm a Pennzoil Platinum guy.
    I predict some Amsoil butthurt coming :yes:
    SlvrSlug[OP], Pentangler and djwantke like this.
  6. Jun 28, 2024 at 5:30 PM
    My input? The newer expensive oils, are not always better. For example: Switched to Motul oil in the Gixxer and it wouldnt shift right, switched back to basic Honda GN4 and shifts smooth as silk.
    I dont run synthetic in my Harley Davidson, but I trust Mobile 1. I found a jug of un opened Castrol on the side of the road. It seemed to run great in the Corolla.
  7. Jun 28, 2024 at 6:22 PM
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    My manual calls for 0W20 which is only available in synthetic, so yes.
  8. Jun 28, 2024 at 8:13 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    I can tell fron the noise the engine makes if the oil has 4k+ mikes. As can I with ever other car I've ever had. Doesn't seem to idle as smooth.
    If changing synthetic every 5k is a waste of money I'd much prefer to err on the side of caution with this sort of thing.
    Pentangler likes this.
  9. Jun 29, 2024 at 5:18 AM
    Rick G.
    The Texas Hill Country
    2022 SR5 Premium 4WD
    I recently changed my oil and filter at home on my 2022 SR5 Premium 4WD. I chose this Valvoline 0W-20 “PREMIUM FULL SYNTHETIC EXTENDED PROTECTION”. Used a Toyota filter purchased from my dealer.
    I’m going to do my intervals at 5,000 miles or 6 months, whichever comes first. I’ll hit 6 months before I hit the 5,000 miles.
    I think I’ll be good. 10,000 miles between oil changes??? NO THANKS.
    Guppy1301 likes this.
  10. Jun 29, 2024 at 11:30 AM
    I’ve said it before I’ll say it again:
    I’m told in Canada change every 5000 Km’s, and if it’s brand new maybe closer to 10000 Km’s.
    BUT Km’s are much different than miles, is it only me who points out that this makes no sense that Canada and USA both say “5000”
  11. Jun 29, 2024 at 6:34 PM
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    I think there is something wrong with your measuring stick... :anonymous:
  12. Jun 29, 2024 at 6:47 PM
    Thats what she said.
    nimby, icebear and 2Toys[QUOTED] like this.
  13. Jun 29, 2024 at 6:50 PM
    2Toys
    Gordon
    2019 4Runner TRDORP
    Roger that, she *might* have said that...
