Are these wheel wells normal?
Discussion in '5th Gen 4Runners (2010-2024)' started by Rnrdani, Sep 16, 2024.
  1. Sep 16, 2024 at 12:53 AM
    Rnrdani
    Rnrdani [OP] New Member
    2024 Off Road Prem, KDSS
    I have brand new 2024 off road. It seems the workmanship and coating is really shotty and skimpy. The front well well has no coating on the top except paint and open holes and bolts sticking through. The rear has a couple holes in the coating which seems like water will get behind it and possibly corrode. The brown is some sort of soft seal between metal.
    Should I have any concerns?
  2. Sep 16, 2024 at 1:19 AM
    Post Covid 5th gens seem to have more quality control issues.
  3. Sep 16, 2024 at 2:49 AM
    Chris In Milwaukee
    Chris In Milwaukee New Member
    Chris
    I s’pose one could get a rattle can of undercoating and fix that up lickity split of there are concerns.
    LCJ77 likes this.
  4. Sep 16, 2024 at 3:41 AM
    Whaler94
    Whaler94 New Member
    Michigan, United States
    2023 ORP white
    My 2023 looks the same way, and I thought the same thing.
    Noodles and Rnrdani[OP] like this.
  5. Sep 16, 2024 at 3:51 AM
    4R4L_2023
    4R4L_2023 New Member
    24' XP UndGrnd 23' XP Mag Grey
    Staying Stock
    My 24' is more evident with skimpy paint/coating than my 23'. I believe it's end of production than post covid problem. I did coat the sheetmetal that OP mentioned with rustoleum and cover the holes with black silicone. Fortunately the only places with skimpy coating are the wheel well area, underside is quite bare on both vehicles so I did spray some fluidfilm.
    [OP] P.S. I believe the hole in the rear wheel well is a vent/drain hole so don't patch it. Spray some fluidfilm in there to prevent rust. However, do patch the screw that penetrated the coating.
    Rnrdani[OP] likes this.
  6. Sep 16, 2024 at 3:55 AM
    The bolts poking through in the rear wheel wells are normal. That's come up here in the past.
    The other holes in the rear wheel wells don't seem normal to me. Edit: it seems that those holes are there on all (or, at least most)5th gens.
    Noodles and Saker like this.
  7. Sep 16, 2024 at 5:33 AM
    jeepster09
    jeepster09 "Old"-Member....
    Twin Cities MN
    4Runner 2008 Sport
    A work in progress.....
    If it were a JEEP you could use DUCK TAPE to fix! :yes:
  8. Sep 16, 2024 at 5:43 AM
    :rimshot:
  9. Sep 16, 2024 at 5:44 AM
    3JOH22A Toyota Gigolo
    This is normal. Front won't rust unless your battery acid spills out. Note the generous amount of seam sealer used. Rear has a rubberized undercoating applied at the factory. The seatbelt bolts poke through the coating. Over time (like 10 years) the undercoating will crack and fall off, revealing rust underneath. You can slow the process down by spraying all the nooks and crannies with cosmoline.
    Rnrdani[QUOTED][OP] likes this.
  10. Sep 16, 2024 at 6:25 AM
    The holes are there for a reason, it seems. All 5th gens have those. Recent thread discussed those at length. Dealer doesn't need to "fix" them.
    https://www.4runners.com/threads/sm...-wheel-well-not-bolt.27733/page-2#post-641032
  11. Sep 16, 2024 at 6:32 AM
    Are you referring to the bolt holes? Or, the other holes? I can't imagine what purpose they would serve. Can you post a link to the thread?
    Edit: thanks for the link. Apparently we all have them, but nobody actually knows why. Weird.
    Picture from the OP. I guess I need to look closer at mine, because I've never noticed them.
  12. Sep 16, 2024 at 6:42 AM
    The other holes. I edited my post to include the thread link.
  13. Sep 16, 2024 at 6:43 AM
    I looked at it. Thank you. Edited my post also.
  14. Sep 16, 2024 at 6:22 PM
    Rnrdani
  15. Sep 16, 2024 at 6:23 PM
    Rnrdani
    I heard bolt was normal but the other things just seemed a little strange and skimpy for a $50k vehicle.
  16. Sep 16, 2024 at 6:28 PM
    Rnrdani
    So yours has no coating on the front at the top? I looked at another today and there’s had more coating and some type of gray/black paint, not the color of their vehicle like mine.
  17. Sep 16, 2024 at 6:32 PM
    Rnrdani
    Thanks for the replys so far. I didn’t check out the front until I cleaned my wheels and noticed the lack of protection on it compared to other vehicles I’ve owned. I thought it odd given it’s an off road truck.
  18. Sep 16, 2024 at 6:47 PM
    Saker New Member
    21 Black T4RORP
    Assembly with bolts after wheel wells were coated and slightly too long bolts!
  19. Sep 16, 2024 at 6:54 PM
    Yeah, the bolts are for the seat belts. Normal or not, I still think it looks shitty. Fortunately, nobody ever looks there anyway.
    Saker[QUOTED] likes this.
  20. Sep 16, 2024 at 7:13 PM
    Nick4RNR
    Nick4RNR New Member
  21. Sep 16, 2024 at 7:25 PM
    mac1usa
    mac1usa New Member
    This pic is my 2021 ORP which has the metal showing in front wheel well (upper portion). Your post prompted me to check.
    The bolts and slits in the rear wheel wells are normal. That slit or cut is a drain for the moonroof which I am told. I put fluid film on my bolts and in the slit with a q tip.
    I never thought about the front wheels or noticed them to be honest. Amazing what an extra set of eyes does. Glad we are all sharing info.
  22. Sep 16, 2024 at 9:01 PM
    Those rubberized looking strips on the top of the front wheel wells? My 2019 is exactly the same. Yours isn't missing anything. No post-Covid shenanigans.
  23. Sep 16, 2024 at 9:02 PM
    Was there supposed to be a pic?
  24. Sep 17, 2024 at 6:40 AM
    Rnrdani
  25. Sep 17, 2024 at 6:40 AM
    Rnrdani
    Were you trying to share a photo?
  26. Sep 17, 2024 at 7:00 AM
    Rnrdani
  27. Sep 17, 2024 at 7:01 AM
    Rnrdani
    So yours is bare metal on top too?
  28. Sep 17, 2024 at 7:26 AM
    mac1usa
    mac1usa New Member
    Sorry guys yes here is the pic I forgot to attached. Almost looks like primer. This is 2021 ORP front drivers wheel well
  29. Sep 17, 2024 at 8:11 AM
    Acesandeights
    Acesandeights #34
    2024 ORP
    No cause for concern. That's undercoating, seam sealer, corrosion protection. Those are all good things to see. I think you're asking about things that stand out because they are better than some of the competition. You're not used to seeing some of this on other vehicles, but not because it's shoddy workmanship. Toyota puts some thick, unattractive seam sealer on there, and that's a good thing.
    It is like questioning why there is this thick brown stuff all over the outside of your chocolate cake, and Toyota puts a darker, thicker layer on their chocolate cake. Oh, it's frosting, no, it's a dark chocolate ganache between the layers with extra frosting on the outside. Huh, I guess they just do shoddy workmanship because I don't see that on Walmart cakes.
  30. Sep 17, 2024 at 8:15 AM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    [​IMG]As seen on TV. I'm only partially kidding. This actually could be an option.
