Are these pin stripes factory or added aftermarket?
Discussion in '5th Gen 4Runners (2010-2024)' started by Austin26, Jun 27, 2023.
  1. Jun 27, 2023 at 4:54 AM
    Austin26
    Austin26 [OP] New Member
    Austin
    5th gen ORP
    I saw another 5th gen without pin stripes and as I bought mine used, do they come with pin stripes from the factory / added by dealer?
    Mine is a 2022 OR.
    Thanks.
  2. Jun 27, 2023 at 5:06 AM
    wdsteven
    wdsteven New Member
    Dealer or after market done
    Austin26[OP] likes this.
  3. Jun 27, 2023 at 5:10 AM
    Oakboro, N.C
    Aftermarket 100%.
  4. Jun 27, 2023 at 5:45 AM
    Austin26
    Austin
    5th gen ORP
    They're well done, don't get me wrong, I'm just have plain tastes and want to keep it looking factory more or less. I'm guessing pin stripes haven't changed much over time and a heat gun applied sparingly will still work?
  5. Jun 27, 2023 at 6:14 AM
    Xombie2000
    Xombie2000 New Member
    2016 4RUNNER trail
    I prefer using a hair dryer over my heat gun. It’s a little slower but safer.
  6. Jun 27, 2023 at 7:07 AM
    Stitches1974
    Stitches1974 New Member
    2023 Nautical Blue TRD ORP
    I used WD-40 for pinstripes, unwanted dealer decals, etc....
    Treggit and Austin26[OP] like this.
  7. Jun 27, 2023 at 7:21 AM
    Austin26
    Austin
    5th gen ORP
    That's a good thing, as my heat gun caught on fire. Thanks, Harbor Freight.
    I had no idea WD-40 could do that. Just spray it on, let it set and wipe? It can't harm the clear coat / paint?
  8. Jun 27, 2023 at 7:26 AM
    Stitches1974
    Spray it on, let it sit for a minute, then peel up with a fingernail or razorblade. WD-40 is water based, so no damage to the paint.
  9. Jun 27, 2023 at 7:46 AM
    Austin26
    Austin
    5th gen ORP
    A razor blade? That sounds like a terrible idea. For glass or bare metal, sure, but the clear coat?
  10. Jun 27, 2023 at 8:00 AM
    Stitches1974
    You're not digging into it. Just enough to get under the item to be pulled up. Why I also stated a fingernail for those not faint of heart. :)
    Austin26[QUOTED][OP] likes this.
  11. Jun 27, 2023 at 12:13 PM
    Austin26
    Austin
    5th gen ORP
    Sorry y'all, I forgot that I live in Texas. On my lunch break I just... Peeled them all off without using anything. I guess I'll get the adhesive residue off another day, ha! Thank y'all.
    08TXRunner and Captain Spalding like this.
  12. Jun 27, 2023 at 12:33 PM
    TCW1184
    TCW1184 New Member
    23’ 4R TRD Pro
    lol. Just dont let the adhesive bake on or it will be harder to remove. You'll need one of those little eraser wheels. Otherwise goo-gone should work for the adhesive.
  13. Jun 28, 2023 at 12:24 PM
    WD-40 is not water based at all. It’s an oil, with some solvent qualities. You might be thinking “water displacement” which is what the story says WD stands for in WD-40.
  14. Jun 28, 2023 at 1:13 PM
    AuSeeker
    AuSeeker Old As Dirt
    Skip
    South Carolina
    2004 Limited
    Just an FYI for future use, I would never use a metal razor blade on a painted surface, one little slip and there's no turning back or re-dos, they do make plastic razor blades for painted surfaces and finished surfaces as in polished metals.
    https://www.bing.com/search?pc=CBHS...NBDF&conlogo=CT3210127&q=plastic+razor+blades
    Captain Spalding likes this.
  15. Jun 28, 2023 at 1:14 PM
    Austin26
    Austin
    5th gen ORP
  16. Jun 28, 2023 at 6:53 PM
    Stitches1974
  17. Jun 28, 2023 at 7:09 PM
    Gamma Ray
    2020 SR5 Barcelona Red
    This guy actually used a heat gun from Harbor Freight and expected anything less than :nuclear:
