Anyone use fuel injector cleaner routinely?
Discussion in '5th Gen 4Runners (2010-2024)' started by rmiked, Mar 18, 2024.
  1. Mar 18, 2024 at 9:02 AM
    rmiked
    rmiked [OP] New Member
    Fort Mill, SC
    I’m normally not keen on putting additives in cars. I have a 2015 Accord with 122,000 miles. My check engine light came on it was the catalytic converter system operating under threshold. I put some Lucas Oil fuel injector cleaner in, after removing the negative battery connection (reset the code, light off). I read the fuel injector cleaner can clean the oxygen sensor and/or catalytic converter and possibly keep the code from setting again. It’s been 2 weeks and the check engine light remained off. The surprise is the car seems to be running much better power-wise, and acceleration. Got me wondering if possibly using the fuel injector as a maintenance item could be useful. Perhaps every oil change? Anyway, can the injector cleaner harm an engine? My 4R is a 2023 and runs great. Don’t want to create a problem. Any thoughts ?
  2. Mar 18, 2024 at 9:12 AM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    I use the good Techron cleaner one bottle a year or when I remember. For your Honda, I have had good luck with those Cat cleaner additives. We had a truck that wouldn't pass smog, did one bottle of cat cleaner and it passed-saved us $7K in new cats.
    Cataclean 120007. Would only use in your Honda's scenario.
    rmiked[QUOTED][OP] likes this.
  3. Mar 18, 2024 at 10:00 AM
    No need. Fuel has detergents in it already. There will be no harm if you do use it.
    Curt73 and 4RunTM like this.
  4. Mar 18, 2024 at 10:02 AM
    TN_FunRunner
    TN_FunRunner New Member
    Jay
    W. TN
    2018 TRD ORP, 2007 SR5 4WD
    I will run a bottle of Techron through it about once a year.
  5. Mar 18, 2024 at 10:19 AM
    Lost Woods
    Lost Woods New Member
    2024 SR5P
    Just use quality fuel like Chevron and Shell and you'll be fine. "Clogged" injectors are either external buildup that the additives in good gas will take care of or it's crap that got past your fuel filter and you have larger problems.
    If you have the 4 cylinder Accord, it's direct injected which is a different animal more prone to injector fouling.
  6. Mar 18, 2024 at 11:18 AM
    Sin4R
    Sin4R New Member
    2024 Underground Limited
    Mall crawling kit.
    I use sea foam (and a hard drive) for cars that sit a lot. Daily driver 4Runner? Not needed.
    For your situation, you might want to look at your spark plugs or maybe bad fuel.
  7. Mar 18, 2024 at 11:25 AM
    Sin4R
    Sin4R New Member
    Mall crawling kit.
    Direct Injected (DI) turbo engines are a pinnacle of unreliability. You can have blow-by and oil consumption, you can have intake valves carbon buildup, you have spark plugs that tend to foul and have to be frequently replaced, you can have turbo issues. Read the code and see what it is, and even if O2 sensor comes up don't assume it is the cause, but just a symptom.
    For DI, I would start with intake chemical treatment and then follow up with an oil change in 100 miles or so. From in-fuel treatments, I recommend BG44K, as you need PEA additive for it to make any difference. Out of cheap injection cleaners, I use Sea Foam but it is nowhere near as effective.
    like2lean likes this.
  8. Mar 18, 2024 at 1:23 PM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    Waste of money on the 4R. Especially one that is so new.
  9. Mar 18, 2024 at 9:09 PM
    Do you think an oil change after a BK44k treatment is also necessary, or just for intake treatments?
  10. Mar 19, 2024 at 5:26 AM
    Sin4R
    Sin4R New Member
    Mall crawling kit.
    Just intake treatments, because they have a good chance to dislodge chunks of carbon and dirt that can end up in oil.
    In general, with DI engines oil changes and oil quality is extremely important. For a naturally aspirated port injected engine, like V6 in our 4Runners, modern oil good enough throughout its life-cycle, not so much for DI. You have higher contamination and a chance of fuel dilution, you have carbon micro particles and chain/bearing wear, you have intake valve buildup. You simply cannot go full 10K oil change interval with DI and not cause some damage. Thing is, this damage is cumulative and it does not manifest while under warranty.
    My recommendation to OP and his Accord is to diagnose this first. He needs to know:
    a. How bad is intake carbon buildup? Use scope to see it, for moderate cases you can use chemical treatment and for far-gone cases you need to do wallnut blasting.
    b. How bad is blow-by, do an oil change with exact volume of oil then drain it at 2.5K and see how much is lost. More oil you burn, more likely you to damage cats.
    c. How much fuel is in the oil. Send used oil to a lab (I use Blackstone) and look in the results for fuel. Fuel in oil dilutes it and reduces lubrication. If it happens a lot, you get bearing damage.
    If any of this comes back as a problem, you need to scope into engine to see if you have cylinder scoring before deciding to repair or dump the car.
    If you are not motivated to deep dive into this, do a chemical intake treatment, change spark plugs, do an oil change right away and then do very frequent oil changes (like 3K miles) after that.
  11. Mar 19, 2024 at 6:29 AM
    like2lean
    like2lean New Member
    So why not just keep new injectors clean instead of waiting for a problem? It's cheap and easy to use a proven product like BG44K once every 15k. Also you can add 1.5oz of Techron to a tank of fuel if you use sub top tier gas like 7-11 or Walmart fuel.
  12. Mar 19, 2024 at 7:24 AM
    catbrown357
    Tempe
    2011 Limited 4WD
    Do what you like. It's your truck. But, I have a 2011 with 180+K on the clock, and have never used anything, and have never had problems. I'd call that hard evidence for waste of money.
    Rocko9999 likes this.
  13. Mar 19, 2024 at 8:35 AM
    3JOH22A Toyota Gigolo
    Do you smell the cleaner in the exhaust when you use it? That stuff can burn up your catalytic converters if used often.
  14. Mar 19, 2024 at 6:45 PM
    bronzestar1
    bronzestar1 New Member
    2023 Limited magnetic gray with redwood interior
    275/55-20s, Airaid CAI, Summit muffler, oil catch can
    I have a '23 Limited, and run a bottle of Lucas cleaner about once a month. I also have an oil catch can, so that fuel system should stay relatively unclogged with low carbon deposits for a good long time.
  15. Mar 19, 2024 at 6:54 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Prolly right especially a 2023
    Me though I have only recently switched solely to top tier. I didn't always have the salary I have now and filled up at many super cheapo gas stations. Every 13,000 kms I started using cleaner :thumbsup:
  16. Mar 20, 2024 at 8:42 AM
    like2lean
    No nothing at all. 0.1 oz of Techron per gallon of fuel is all it takes to make cheap fuel into tier 1 Chevron fuel. My average top off is bout 15 gal so 1.5 oz is a good average and I like knowing I'm getting the additive instead of hoping the truck driver remembered to pour it in the tank. Ford released several bulletins that most rotten egg fuel odors are from the local refineries adding a higher content of sulfur to their fuel, usually a fuel issue not a car issue as many believe. I drive with my back window down all the time and never have any odor at all. If you do try changing brands of fuel.
    I've never been one to think oil changes are the only service needed on a car until something breaks. MANY people I've dealt with over the years only do O/F's and believe all the rest of a cars critical systems (fuel system, brake fluid, coolant, driveline,...etc.) are just magically preserved for life and never degrade or wear. Which is fine it's their car, I've always been interested to hear the logic involved.
  17. Mar 20, 2024 at 10:47 AM
    ^That's because you're using 1/10th as much as the instruction label says on the Techron bottle. The label says to pour the entire contents into the tank and fill with 12 gal of fuel, so 1 oz of cleaner per 1 gallon of fuel. Using the cleaner following Techron's instructions will cause the exhaust to smell funny.
    djwantke likes this.
  18. Mar 26, 2024 at 7:39 AM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    I owned a Austin Healy with side draft carbureators and oil damping pistons when Chevron first introduced Techron to their fuel. It was remarkable how it disolved the usual black carbon inside the carbs I struggled with prior. Made cleaning them a non-issue. It is an amazing product. I do not use Chevron gas daily due to their station locations. So I use a bottle of Techron every 5000 miles in all my vehicles, usually timed with oil change and tire rotation.
