Anyone ever clean their throttle buddy?
Discussion in '4th Gen 4Runners (2003-2009)' started by Brainsapped, Dec 6, 2024.
  1. Dec 6, 2024 at 5:01 PM
    Brainsapped
    Brainsapped [OP] New Member
    2003 4Runner 5s
    2003 250k miles. A mechanic I used a couple of times suggested I clean my throttle buddy. I think I’m going to. My buddy’s been there through thick and thin. He deserves a good bath.
    The guy was from the Middle East and so with his accent it sounds like he was saying throttle buddy, and I always got a kick out of that.
    But seriously, should I clean my throttle body? Happy weekend trails!
  2. Dec 6, 2024 at 5:04 PM
    Take the intake off and look.
    Yes I've seen caked on shit all over the inside before. Will you gain anything can't say.
    Brainsapped[OP] likes this.
  3. Dec 6, 2024 at 5:19 PM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    With air intake hose removed you can carefully open the butterfly/damper a small amount and peak inside with a strong light and examine for carbon build up. If there is a carbon ridge at the the meeting of the butterfly/damper and the TB itself you would probably benefit from cleaning.
    The process requires some study and preparation. Perhaps even new gaskets. You do not want to scratch the soft surfaces.
    While doing this job you can evaluate the very delicate Mass Air Flow Sensor. It requires a special cleaner.
  4. Dec 6, 2024 at 5:24 PM
    Its not that delicate
  5. Dec 6, 2024 at 5:49 PM
    Two4Runner
    Two4Runner New Member
    Lance
    4Runner
    I did mine yesterday on my 08 v6. Remove air cleaner hose and 2 bolts hold on intake plenum then move carefully out of the way. Then you can see and clean throttle body. A little awkward but doable. Oh and a couple of plugs and vacuum hose in the back.
  6. Dec 6, 2024 at 6:01 PM
    RepentOrPerish
    RepentOrPerish New Member
    4thGenv8
    Did mine not long ago. I wouldnt recommend taking it competely off unless you have new gasket handy. Can be done as described by just taking the intake hose off. I used a micro fiber cloth and electrical cleaner.
    Expect a higher idle after cleaning until the computer relearns..couple short drives..
  7. Dec 6, 2024 at 6:10 PM
    Bluesky 07
    Bluesky 07 Not a New Member
    Russell
    Northern Georgia
    Silver ‘07 Sport V6 4WD @ 265K miles
    “Deep” Satoshi grille | X-REAS delete / TRD Offroad front springs & Bilstein 4600 shocks + FJC rear springs | Weathertech front & rear mats | Tinted front windows | Floor Armor cargo mat | TPMS bypass | LED interior, tag, & reverse lights | BlueSea Systems console USB power ports | Gentex 453 autodim mirror w/Homelink & compass | Kenwood DDX373BT HU + Audiovox backup camera | Fumoto F-103S | Bazooka tube subwoofer | Kenwood speakers & KAC-M1804 amp | Philips H9/9011 headlight bulbs | Rexing V1 Gen3 dash cam | Map light mod | Breather mod | Off-road Nav Setup | Power Stop Z36 brakes | OBD Fusion diagnostics
    Not a bad idea to clean it now and again. There are videos on YT. Be careful with the screws if you remove it. Don’t over tighten them or they’ll snap off.
  8. Dec 9, 2024 at 7:22 AM
    icebear Recovered Kia Owner
  9. Dec 9, 2024 at 7:50 AM
    Acesandeights
    Acesandeights #34
    2024 ORP
