Any recommendations on fog light replacement bulbs?
Discussion in '5th Gen 4Runners (2010-2024)' started by 4wheelforlife, Sep 15, 2021.
  1. Sep 15, 2021 at 8:09 AM
    4wheelforlife
    4wheelforlife [OP] New Member
    T
    2021 4Runner
    Hello,
    I want my stock fog light bulbs replaced with yellow due to snow this winter. I have seen the yellow film but I am clueless if that works as well? Should I just seek a yellow bulb instead? Any recommendations will be appreciated. Should you have link please list and I will order ASAP.
  2. Sep 15, 2021 at 8:51 AM
    Did you had any problems with stock white LEDs?
    This is a screenshot of my 2018 with old fog light housing. Visibility was not bad for me to spend for a yellow fog light.
    Update -
    My suggestion is run one winter and see if stock white LEDs are bad or not. If it fails then spend the money. Just a suggestion. I could be wrong.
    4wheelforlife[OP] likes this.
  3. Sep 15, 2021 at 9:12 AM
    4wheelforlife
    T
    2021 4Runner
    I travel for fun to a place called mountain lake. The snow is crazy. I have read that yellow is great when it is snowing hardcore. Thanks for the input maybe I should try stock first.
  4. Sep 15, 2021 at 12:15 PM
    Jjww81
    Jjww81 New Member
    I put diode dynamics pro fog lights on my 21 limited amd they are amazing brighter then my head lights and easy install.
    2018 Limited and Thatbassguy like this.
  5. Sep 15, 2021 at 12:24 PM
    4wheelforlife
    T
    2021 4Runner
    Awesome I’m staying stock led. Just determine to get yellow bulb or yellow lens’s.
  6. Sep 15, 2021 at 12:48 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    There is no bulb to replace in an OEM LED foglight. You would need a selective yellow film placed on top of the outer lens.
    I replaced my stock halogen fog lights with the Toyota LED fog lights. They happen to be listed for the Tundra, and they are slightly oval shaped, but they fit the 4Runner.
    Before installing I put yellow Lamin-x film on them. The Tundra product fit exactly and it works great. I ordered directly from the manufacturer, product number was
    T147Y Toyota Tundra (14- ) Yellow Fog Light Covers
    https://lamin-x.com/toyota-tundra-14-fog-light-covers.html
  7. Sep 15, 2021 at 2:03 PM
    4wheelforlife
    T
    2021 4Runner
    Thanks for tip. I don’t know anything about these but I thought I could use these yellow led bulbs perhaps? Maybe the yellow lens sticker is best.
  8. Sep 15, 2021 at 4:53 PM
    MountainMan
    MountainMan New Member
    Pacific Northwest
    I commute 15 miles one way to work through rural farmland that gets a fair amount of fog and snow a few months out of the year.
    I installed these...
    https://smile.amazon.com/gp/product/B07R7CF9TH?ie=UTF8
    These are brighter than the factory lights, to the point of getting flashed every now and then by sensitive drivers when they are on.
    What I found, is that there is nearly no perceptible difference in the ability to see in heavy fog or heavy snow between these and the low beams.
    For instance, if I'm driving along in heavy fog with my low beams on (because I'm not an idiot who uses high beams in fog like so many these days. "sigh") and I turn on my bright amber "fog" lights, I see very, very little difference in vision. There is an improvement. But it is minuscule. Maybe I am more visible to oncoming traffic with them on?
  9. Sep 15, 2021 at 5:09 PM
    You're correct. It has something to do with higher color temperature (more blue-ish) light reflecting off water more than a lower color temperature (more yellow). I bet someone around here could explain it better.
    It could be that the yellow led drop-ins you're running aren't the ideal color. This could also be why so many people replace their fogs with purpose built yellow fogs like Diode Dynamics SS3's.
  10. Sep 15, 2021 at 11:50 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
  11. Sep 15, 2021 at 11:57 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    If you have the OEM LED fog lights they do not have replaceable “bulbs”.
    Try the Lamin-x, it costs under $20.
  12. Sep 16, 2021 at 2:34 AM
    Matt83
    Matt83 New Member
    Northeast
