Any help with a 4 runner question concerning VSS
Discussion in 'New Member Introductions' started by FarmHand48060, Aug 12, 2024.
  1. Aug 12, 2024 at 11:18 AM
    FarmHand48060
    FarmHand48060 [OP] New Member
    Kirk
    2006 $ runner Sport
    stock
    Recently lost the tach,speed, fuel, temp and all digital read-outs on my 2006 4 runner. Got a ABS malfunction fault and a P500 fault. When checking the wiring on the vss for voltage, I found .8 vdc at both terminals of the plug, and a pin probe at the "ECU" also showed .8 vdc on the Red with blue trace as well as the Blue w/ Yellow trace. Both wires showed no shorts opens or grounds. Should the voltage from the "ECU" be in the 10+VDC range? Not sure if I should proceed or button it up, then install a "GPS" speed monitor and maybe a oil pressure and temp gauge, or just drive blind until it no longer wants to move. Any help,suggestions or extra info out there
  2. Aug 12, 2024 at 11:32 AM
  3. Aug 13, 2024 at 3:01 AM
    Welcome from Wisconsin!
