Amateur Radio in a 5th gen 4Runner (part 2) The power
Discussion in '5th Gen 4Runners (2010-2024)' started by Gostav, Jun 14, 2024.
  1. Jun 14, 2024 at 5:43 PM
    Gostav
    Gostav [OP] New Member
    Glenn
    2013 4Runner Limited
    Bone stock
    I used corded stranded copper 12ga wire and put the fuses as close to the battery terminals as possible. I used a wire insertion tool to push the wire thru the firewall. The tool will hang up a bit when you puncture the inner membrane and insulation. The wire comes out just above the emergency brake bracket, if you choose not to use an insertion tool. I then finished off the job with a grommet (don't forget to put it on. Ask me how I know), and a sparkling new AGM battery and terminals.
    Use wire ties strategically 'cause we will do some shakin'.
    73 Glenn NØIDX
    https://www.amazon.com/dp/B0BKGZ6CBN?ref=ppx_yo2ov_dt_b_product_details&th=1
    https://www.amazon.com/dp/B08T1DPCCS?ref=ppx_yo2ov_dt_b_product_details&th=1
    https://www.amazon.com/dp/B0BZ33QZM6?ref=ppx_yo2ov_dt_b_product_details
    T in Texas and ChessGuy like this.
