Am I crazy to do my rotors/break pads myself?
Discussion in '3rd Gen 4Runners (1996-2002)' started by GoldenGroundSquirrel, Oct 21, 2024 at 1:40 PM.
  1. Oct 21, 2024 at 1:40 PM
    GoldenGroundSquirrel [OP] New Member
    Monday
    2000 4Runner Limited
    None
    My old gal has had a lot of maintenance stack up lately. It's ok, she's old, but the cost of getting it all done at a shop adds up quick.
    Ive put 2k in this car in the last six months, and the last pressing issues are the rotors/break pads and some tie rods. I was looking up some YouTube videos doing the rotors/pads, and it looked pretty easy.
    Id much rather buy the parts and spend a day doing it myself rather than spending the $700 my mechanic wanted. But, I've never done anything mechanical before.
    Would doing it myself be crazy? Although it looks easy enough, the breaks are something I don't want to eff up.
    Bagman likes this.
  2. Oct 21, 2024 at 2:13 PM
    Its not hard do it.
  3. Oct 21, 2024 at 3:02 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    I'd rate pads and rotors as on the easier spectrum of at home jobs.
    Hardest part is usually getting the rotor off the hub.
  4. Oct 21, 2024 at 3:08 PM
    Ironguy New Member
    Welcome!
    Not terribly hard just take your time.
    Bagman likes this.
  5. Oct 21, 2024 at 3:15 PM
    CalcityRenegade
    CalcityRenegade New Member
    Matt
    2023 T4R ORP KDSS
    Super easy, but make to remove the caliper slide pins, clean them up and use new grease. This is often overlooked when doing a brake job. Also make sure to inspect the slid pin boots as they will get dirt in there if torn. This can save you a headache later down the road.
  6. Oct 21, 2024 at 3:52 PM
    Acesandeights
    Acesandeights #34
    2024 ORP
    You don't have to be crazy to do rotors and break <sp> pads, but it helps.
    Mr.DRZ likes this.
  7. Oct 21, 2024 at 4:11 PM
    Bruceski44
    Bruceski44 New Member
    Bruce
    2000 4Runner SR5
    I once told a friend I do simple repairs/maintenance myself, but for something really important, like brakes, I go to a pro.
    He told me that's the same reason he does it himself. It's really important. Youtube is your friend here...
    Tama1968 likes this.
  8. Oct 21, 2024 at 4:23 PM
    Brakes falls under simple.
    Showed my 16 year old how to do one side and he did the other on his own.
  9. Oct 21, 2024 at 4:52 PM
    ThatGuyTheCooler
    ThatGuyTheCooler New Member
    SEPA
    2023 PRO
    Do it yourself. Use a bolt to remove the old rotors
    andrewtheadventurer likes this.
  10. Oct 21, 2024 at 5:08 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    Do the 3rd gens have that hole in the rotor?
  11. Oct 21, 2024 at 5:14 PM
    AuSeeker
    AuSeeker Old As Dirt
    Skip
    South Carolina
    2004 Limited
    Does the 2000 T4R have rear drum brakes or are they disc brakes?
    I ask because drum brakes are a little more difficult to get done correctly, if both front and rear are disc then I say go for it, just double check everything, make sure you torque the bolts properly, etc.
    PVT Pablo likes this.
  12. Oct 21, 2024 at 6:47 PM
    aroyalsfan
    aroyalsfan The Owner
    Kansas City
    The bolt that holds the brake line is the same size bolt needed to release the rotor. You have to remove it anyway, so you'll have it handy.
    Like it was said, just take your time. Who cares if you tell your wife it will take 2 hours and you're still messing with it 10 hours later.
    If you're over 40, be prepared for every muscle from your shoulders to your toes to be sore.
    Though if you're gonna do it, do it right. Get the right tools, breaker bar (big pipe for even more leverage), torque wrench, and a big screen for the garage so you can follow along on YouTube University.
  13. Oct 21, 2024 at 8:23 PM
    that'smy4runner
    that'smy4runner New Member
    I've been effing up brakes for decades and they haven't failed me yet. Do one side, keeping the other intact as a reference, then do the other side. You might even do front and rear on different days, just in case you run into trouble and to keep your anxiety manageable.
  14. Oct 21, 2024 at 9:35 PM
    AuSeeker
    Skip
    South Carolina
    2004 Limited
    Just an FYI the OP is a female, not that it matters for getting the job done!
  15. Oct 21, 2024 at 9:57 PM
    Monday
    None
    A quick google-fu says that the fronts are pad and the rear are drums. I only really need the front right now, though I'm sure the rear needs to be done eventually.
  16. Oct 21, 2024 at 9:59 PM
    Monday
    None
    I'm just a single gal who is tired of putting $$$ into my old car. I also refuse to buy a Honda civic (or an equally boring car, I love my car). I also have always wanted to be more self-sufficient, anyways.
    Noted! I'll be sure to have all the tools/supplies before the wheels are off the car. Thank you!
  17. Oct 21, 2024 at 10:45 PM
    AuSeeker
    Skip
    South Carolina
    2004 Limited
    With drum brakes it's very important to assemble them correctly or they won't work very well or possible fail and also adjustment them properly for proper braking action, that being said I'm sure you can do the drums as well when the time comes, just be sure to take good photos of the shoes/hardware/assembly before you take anything apart so you can refer to them if needed, I also recommend as you take it apart lay out all the parts on a piece of cardboard so you can see how they are oriented as you put it back together again, putting them on the cardboard is so you can slide them out of the way when you are cleaning up everything prior to reassembly.
    Also please post any videos you're going to use to help you do the brakes here in this topic so we can add our 2 cents if needed, in case they miss something or possibly doing something wrong or the hard way, etc.!!
  18. Oct 22, 2024 at 4:30 AM
    PhillySilver
    PhillySilver New Member
    Silver 2020 ORP
    Do it yourself, disc brakes very easy. Drums a little less so but still not hard. If drums involved hardest part is the spring routing and adjustment. As others have posted, do one side and leave other intact for reference. If discs on all 4x corners, super easy job. RockAuto has very good prices on the rotors and pad kits. Pad kit I got came with new clips and slide pins. Definitely clean up the holes for the slide pins. It is a dirty job to be sure but definitely in the range of a DIY person if you take your time. Agree with others also, youtube is your friend.
  19. Oct 22, 2024 at 7:26 PM
    that'smy4runner
    I seem to recall something from the other forum about aftermarket pads or shoes for 3rd gens not fitting properly. Anyone else remember that? I've never had to do the brakes on my 3rd gen but the rear drums are coming up very soon...
  20. Oct 22, 2024 at 7:54 PM
    ziva
    ziva New Member
    2014 SR5
    USE PB BLASTER FOR THE BOLTS!!!!!
    I also highly suggest getting 2 of the M8 1.25 bolts to "pry" your old rotor off instead of dicking around with the e-brake assembly with a flathead (rear only).
    Good luck! It's an awesome feeling to work on your truck instead of over paying for a dealership to do it.
  21. Oct 23, 2024 at 6:47 AM
    that'smy4runner
    Yup, here's one of the posts by Timmy i was thinking about.
    "Yep, that's the main problem. The aftermarket shoes never fit right. It seems pretty ridiculous to make the shoes bigger than OEM because they are adjustable." and for good luck on the rear
    https://www.youtube.com/watch?v=IJkVEBYSecs
  22. Oct 23, 2024 at 1:39 PM
    Mr.DRZ
    Mr.DRZ New Member
    2024 TRD ORP Barcelona Red
    Pads and rotors are not too difficult BUT it all depends on your mechanical experience/ability.
    Based on your post, I recomend at a minimum to have a knowledgeable buddy present for the job. Review multiple sources for the procedure (manual, videos. Forums etc) because sometimes only one of them will have that really helpful tip.
  23. Oct 27, 2024 at 3:07 AM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    Have you measured the rotors to confirm they need changed? Do you have pulsating brake pedal or weird noise?'
    I changed pads on my 2004 Honda Pilot EX -never the rotors- at 240,000 miles rotor thickness still in spec and no weird braking issues.
    Not hard to do with tire jack, stacked bricks or thick wood pieces for safety support. Study on line "How to's" videos.
    This is good time to learn about brake fluid and the caliper bleed valve.
    Suck out old fluid in reservoir, replace with new before starting pads. Watch reservoir fluid level as it will drop when using the caliper bleed valve. Do NOT let it get low!
    Do front pads first as they tend to be easier. Use old pad and C-clamp to push your pistons back into caliper, so new will fit. Clean everything with Brake Cleaner.
    Lube critical spots with special brake lube sparingly.
    Get a buddy with experience to assist.
    Avoid on line purchase of pads-I once got counterfit that wore out in 20,000 miles.
