Alternator not charging battery
Discussion in '5th Gen 4Runners (2010-2024)' started by White500xl, Aug 16, 2024.
  1. Aug 16, 2024 at 1:44 PM
    White500xl
    White500xl [OP] New Member
    2016 Toyota 4Runner
    Removed Alternator on 2016 4Runner, had it tested, ok, reinstalled it still not charging. I have checked all fuses, under hood as well as under leftside of dash. Double checked all 7.5 fuses. Any suggestions?
  2. Aug 16, 2024 at 1:49 PM
    Factory battery?
    If it is its 8 years old.
    Ripper238 likes this.
  3. Aug 16, 2024 at 1:54 PM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    Well if it's not the alternator its the battery. And if your getting voltage its not the fuse.
    When did u change the battery last? What kind of battery?
  4. Aug 16, 2024 at 1:54 PM
    White500xl
    2016 Toyota 4Runner
    New Battery installed first. Removed alternator,had it tested for output; 14.2 volts.
  5. Aug 16, 2024 at 1:56 PM
    White500xl
    2016 Toyota 4Runner
    Brand name of battery is DieHard Gold. 750cca.
  6. Aug 16, 2024 at 1:58 PM
    If your alternator is putting out 14.2V its probably not that.
    By not charging what do you mean? Battery dies quickly? You probably have excessive current draw when its not running.
    Tama1968 and Guppy1301 like this.
  7. Aug 16, 2024 at 1:59 PM
    Ripper238
    2019 TRD OR
    Hmm, well it's not an AGM. Alternator tests fine and new battery.
    If you had it tested off the car you could still very well have a charging system problem. damaged battery cable, either positive or ground side either one, a bad loose or corroded battery cable connection, a bad or loose battery ground. Could also be a terrible parasitic draw.
    Tama1968 likes this.
  8. Aug 16, 2024 at 2:02 PM
    White500xl
    2016 Toyota 4Runner
    Charged up battery to full charge. Current state of charge of battery 12.8 volts . Started vehicle checked charging voltage at battery posts: 12.2. Headlamps on,blower motor cranked up to full load, battery voltage drops to 11.2.
  9. Aug 16, 2024 at 2:06 PM
    White500xl
    2016 Toyota 4Runner
    Also, before starting motor and after fully charged battery was reinstalled, checked for battery light in the instrument cluster . There is no illumination. I do know that if you do not have the battery light does not light up the alternator voltage regulator does not get energized to allow alternator out put.
  10. Aug 16, 2024 at 2:09 PM
    White500xl
    2016 Toyota 4Runner
    Is there a hidden fuse somewhere I could check? I did add 12 volts to the alternator wiring harness 4 pin plug. The battery light in the instrument cluster illuminated.
  11. Aug 16, 2024 at 2:17 PM
    White500xl
    2016 Toyota 4Runner
    I checked all underwood fuses and under dash at leftside. No blown fuses. Battery cables clean and tite. No corrosion at alternator post. Main alternator fuse good.
  12. Aug 16, 2024 at 2:18 PM
    Check grounds
  13. Aug 16, 2024 at 2:21 PM
    White500xl
    2016 Toyota 4Runner
    Checked all body grounds,engine to frame grounds, main negative cable as well.
  14. Aug 16, 2024 at 3:37 PM
    Guppy1301
    Guppy1301 New Member
    Silver 2019 TRD ORP
    Tested ok but still not charging. then it's the alternator. How many miles on your 2016? If over 140K, that's probably it.
  15. Aug 16, 2024 at 4:03 PM
    White500xl
    2016 Toyota 4Runner
    The vehicle has 78k on it. My customer bought it brand new. The alternator is oem. My experience is that most alternators usually last about 100 to 150k. But Asian vehicles have a pretty good track record of manufacturing reliable electrical components. If this tested alternator doesn't charge I will replace it with a Nippendenso alternator. I've never had a issue with them.
    Guppy1301 likes this.
  16. Aug 16, 2024 at 4:56 PM
    Daddykool
    Was gonna ask mileage. Alternator brushes go between 150-200k miles typically.
