Alternator- Is it going?
Discussion in '5th Gen 4Runners (2010-2024)' started by Lc200, May 16, 2024.
  1. May 16, 2024 at 8:20 PM
    Lc200
    Lc200 [OP] New Member
    Pre Facelift SR5P
    So I am still on my OEM alternator. I have read that they are actually good for over 250k miles. I am at 180k right now.
    I was doing regular battery checkup and noticed my battery was at 12.6v resting.
    At idle, it was at 13.8v.
    I then turned on the AC, lights and stereo and it fell to 13.5v. I switched the load off and it showed 13.6v and stayed there. I even gave it throttle to about 2000 rpm, but it stayed at 13.5V/13.6V
    Is the alternator not able to fully charge the battery? I am told it needs to be between 14.1 to 14.7v.
    Signs of eventual failure?
    Battery was changed in 2021 March.
    I do not have any day to day symptoms and the truck runs fine.
  2. May 16, 2024 at 8:25 PM
  3. May 17, 2024 at 6:14 AM
    cbrake
    cbrake New Member
    Cliff
    2019 Silver 4Runner
    Could try cleaning battery terminals and see if that helps. Might also be the battery as it is getting older.
    Just measured mine (2019 SR5, 63K miles, fairly new battery):
    - off: 12.5V
    - idle: 14V
    - idle with lights, radio, and AC: 13.89V
    Lc200[OP] likes this.
  4. May 17, 2024 at 6:34 AM
    Lc200
    Pre Facelift SR5P
    I will clean the terminal again but they look clean with no corrosion. I fluid filmed them last year.
    Strangely , when I checked last week, it showed 14.0v at idle and stayed there. And barely went down with any load.
  5. May 17, 2024 at 7:10 AM
    cbrake
    cbrake New Member
    Cliff
    2019 Silver 4Runner
    One of my someday goals is to build a data-logger for vehicles that will log things like battery voltage, transmission temp, etc. and then graph it. I already do that for computer systems I manage -- would like something similar for vehicles. Already have a start of CAN functionality, but have not tried looking at vehicle data yet:
    https://docs.simpleiot.org/docs/user/can.html
    SlvrSlug likes this.
  6. May 17, 2024 at 7:19 AM
    Daddykool
    The brushes need to be replaced at that mileage. $20 from wherever. Toyota (Denso?) uses the same type brushes across many models. If you're able to remove the alternator, you're able to replace the brushes. It's very simple, and the new brushes will net you an additional 150k-200k miles. The alternator itself will last a long time. But you'll have to order the brushes, as it's unlikely anyone stocks them. I've made this a preventive measure on my vehicles.
  7. May 17, 2024 at 7:40 AM
    Lc200
    Pre Facelift SR5P
    If I have to remove the alternator to replace the brushes, should I not just go ahead and replace the alternator?
    I am going to pay some one as it is to remove the alternator.
  8. May 17, 2024 at 8:02 AM
    Daddykool
    Well, if you have a buddy who can do it for cheap, you could do that. Maybe have him replace the serpentine belt while you're in there, since you have to remove that anyway. People often have trouble with reman alternators. A Toyota reman is around $330, and new is $500+ from what I see. Brushes are $20. My suggestion was based on DIY. I personally haven't had an alternator fail for any other reason, and 180k miles is typical for them to need replacing.
  9. May 19, 2024 at 6:40 AM
    I’m not sure I’d be putting fluid film or (or even dielectric grease) directly on terminals, if that’s what you did. You need clean metal to metal contact.
  10. May 19, 2024 at 6:49 AM
    Have you taken it mudding in those 180k?
  11. May 19, 2024 at 7:34 AM
    CarlP
    CarlP New Member
    Carl
    Phoenix, AZ
    2018 Off Road with KDSS
    I second just replacing the brushes.
  12. May 19, 2024 at 8:53 AM
    Lc200
    Pre Facelift SR5P
    I did put them on the battery connectors directly. A very thin layer last year. I was told it prevents corrosion.
    It's pretty much gone but still looks ' lubed'. I can clean it if required.
  13. May 19, 2024 at 8:56 AM
    Lc200
    Pre Facelift SR5P
    No, only urban driving. But 2 years ago my oil filler gasket leaked and oil dripped out around the filler tube, down close to the idler pulley and next to the alternator. I am thinking maybe that oil seeped in some. Don't know.
    What is surprising is, 4 days ago when I checked, it showed 14v idle and with all the accessories on it still stayed at 14v. But then now it's at 13.6v
  14. May 19, 2024 at 9:17 AM
    Lc200
    Pre Facelift SR5P
    I am told I would still need to remove the alternator to do that work . Since I am going to be paying someone to do it for me, might as well pay for a new alternator.
  15. May 19, 2024 at 5:43 PM
    As others have said. Stop putting anything on the terminals. USUALLY corrosion is the gas leaking from the terminals and is the beginning signs to replace your battery
  16. May 19, 2024 at 5:52 PM
    I would give it a try before spending money on having the alternator replaced. You’d hate to still have the problem after that!
    Lc200[QUOTED][OP] likes this.
