Alignment Issues x2
Discussion in '5th Gen 4Runners (2010-2024)' started by tundradan, Jul 29, 2020.
  1. Jul 29, 2020 at 9:22 PM
    tundradan
    tundradan [OP] New Member
    2013 Silver 4Runner Limited
    Stock....for now
    Recently purchased a 2013 4Runner Limited. The steering wheel was tilting to the right and it was definitely pulling to the right. I took it in to a local alignment shop and they "fixed it". They actually adjusted everything to the correct specs and the steering wheel also was now straight. I took it out on the freeway and it still pulled to the right.
    I took it to my favorite tire shop and they said the inside of my left tire was more worn than the outside. The right tire was fine. So to test the alignment they cross-swapped the front tires. In theory, if the pulling to the right was a tire issue, it should now pull to the left. No luck, still pulling to the right - however not as bad or as fast.
    I took it back to the local alignment shop today and they put it back on the rack to check. All specs were within the correct range. To fix the problem they "Changed the caster to help compensate for the road crown on the freeway without sacrificing tire wear". This actually solved the problem and it now drives straight....but
    I don't know much about tire alignment but it seems that if you are adjusting one thing (in this case the caster) to compensate for something there will be another thing that must give. I would love your input as I don't really want to have unnecessary wear on other parts.
    Thanks for your help!
  2. Jul 30, 2020 at 9:25 AM
    You'll be fine with a higher caster number. Some people with aftermarket UCA's go as high as 5 degrees on our vehicles.
    I'd be willing to bet yours is still within spec, even if it's on the higher end. What caster number did they get you to?
  3. Jul 30, 2020 at 9:45 AM
    How bad is the worn tire?
  4. Jul 30, 2020 at 10:58 AM
    Agent_Outside
    Built 2011 T4R Limited
    Caster to adjust for road crown is common.
    tundradan[OP] likes this.
  5. Aug 9, 2020 at 1:23 PM
    tundradan
    Stock....for now
    Not bad. Inside to outside of the tire was only 2/32 different, but they were fairly new tires.
