Air not blowing out center vents/buzzing noise from dash
Discussion in '4th Gen 4Runners (2003-2009)' started by Mhendersonn, May 4, 2024.
  1. May 4, 2024 at 2:27 PM
    Mhendersonn
    Mhendersonn [OP] New Member
    2007 Toyota 4 Runner SR5 V6
    Has anyone ever had air not blowing out of the center vents, but blowing out the side vents in the front? It also makes a loud buzzing noise from the dash that lasts about 10 seconds when I crank it up. I’ve seen online it could be a million things, but I’m wondering if anyone on here has had a similar problem that could pin point exactly what I need to look at. TIA!
  2. May 4, 2024 at 2:46 PM
    Fisch
    Fisch New Member
    Jacksonville, Fl
    2018 TRD ORP
    Empty wallet
    Odds are it is your air blend servo motor under the dash. You can usually access them by removing the glove box.
  3. May 4, 2024 at 8:33 PM
    gkomo
    gkomo New Member
    San Diego, CA
    2014 Tacoma AC 4x4
    The 10 second buzzing could just be your electronic brake booster, and not related to your vents, which as previously mentioned is almost 100% one of your hvac servos. There are two on the passenger side and if you have dual climate control another on the drivers side.
  4. May 7, 2024 at 12:33 PM
    Staticline
    Staticline New Member
    2004 4Runner Limited V8 with extras
    Victory front and rear bumpers, Dobinson's MRR suspension, winch, lights, 285 70R17 BFG KO3's
    There are 4 actuators under the dash, 2 on the glove box side and 2 on the drivers side. The one that controls where the air goes is on the glove box side and is a pain in the @#$ to replace.
